Migrating Network Clock Commands from C2900 series to a ISR4351
randyclark
I am having an issue migrating the following commands from a 2900 to an ISR4351. I'm not that familiar with the clocking commands. Can someone provide an example of what I need to use on the ISR?
Routing, ISR 4000 Series
network-clock-participate wic 1
network-clock-select 1 T1 0/1/0
Not sure what to replace the wic 1
network-clock participate ??
When I try to apply the following I get the G.781 message....
network-clock select 1 controller T1 0/1/0
G.781 based clock selection process is enabled Please unconfigure G.781 based configuration before configuring network-clock select config command
Best Regards,
luis_cordova
pieterh
check if command below is present in your configuration
network-clock synchronization automatic
Enables the network clock selection algorithm. (Note that network clock synchronization is disabled by default.) Disables the Cisco-specific network clock process, and turns on the G.781-based automatic clock selection process.
