Migration from VLAN 1 to another VLAN
Samy87
Hi Guys,
I am planning on migration of LAN setup from default VLAN 1 to VLAN 100, i got VLAN 1 with 30.x.x.x network and VLAN 100 with 10.x.x.x, i had planned to migrate IP as well, so my setup is like SW trunk interface port connected to Riverbed and the riverbed inpath interface connected to WAN router, all are in VLAN 1(30.x.x.x) IP range, i need to migrate all of them from VLAN 1 to VLAN 100 and also change IP as well, to be note i am not removing VLAN 1, need steps to be taken care before going for changes, since its a production environment.
Switch configuration is like:
interface GigabitEthernet4/0/48
description RB inpath3_0
switchport mode trunk
speed 100
duplex full
Router interface connecting to Riverbed is like:
interface GigabitEthernet0/1
description LAN
no ip address
duplex full
speed 100
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 30.x.x.x 255.255.252.0
no ip redirects
ip directed-broadcast
ip pim sparse-mode
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.x.x.x 255.255.252.0
no ip redirects
ip pim sparse-mode
8 Replies 8
Hello
@Samy87 wrote:
Hi Guys,
Not clear!
What ip address are you wanting to use for vlan 100 and also what happens to existing  addressing for vlan10?
Kind Regards
Paul
Hi Paul,
I am using only VLAN 1 and VLAN 100, my VLAN 100 ip falls on range 10.1.1.1/22, since i had default vlan 1, on the switch trunk port connecting the router whether i need to specify "switchport trunk native vlan 100" on the SW config to assign the VLAN 100 IP on the router interface.
Hello
@Samy87 wrote:
Hi Paul,
Only need to specify vlan 100 as native if you want vlan 100 to be native and have utagged traffic -
Now its still unclear to me why you need to migrate addressing from vlan 1 to vlan 100 and what is going to happen to the current vlan 100 addressing
Kind Regards
Paul
Jaderson Pessoa
@Samy87 ,
Basically you need check three thing to check before changing your network.
1. Check if your dhcp scope are configured properly
2. Check if your trunks ports and access ports are configured properly and dont forget to create and check if yours vlans are UP/UP.
3. Check if your router has a nat configuration allowing this 10.x.x.x network to internet
Jaderson Pessoa
*** Rate All Helpful Responses ***
Thanks for your reply, yes already i had done all the given points and migrated other L3 switches and user VLAN on network and assigned the IP's on 10x range, my query is whether i need to configure switchport trunk native vlan 100 on switch trunk port connecting to router and make router subinterface config as encapsulation dot1q native 100, since i am still using VLAN 1 on network.
As per your configuration:
Interface GigabitEthernet0/1.1
no ip redirects
ip pim sparse-mode
no ip redirects
ip pim sparse-mode
VLAN 1 is native VLAN and VLAN 100 must be tagged VLAN. So your switch port configuration will look like:
interface  GigabitEthernet x/x/x
switchport trunk allowed vlan add 1,100
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
@Deepak Kumar
Deepak Kumar
No need to specify native vlan 1 its default
@Samy87
int x/x
ip directed broadcast -  no need for directed broadcast so this isn't applicable
Kind Regards
Paul
Yes, not is necessary specify vlan 1 as native.
Jaderson Pessoa
