Load sharing between 2 ISP
jeromesky
I've got a Stackwise Virtual Core (VSS) Connected on two separate ASA Firewall and behind the firewalls are my routers that would be connected to ISPs to access the internet.
       INTERNET
ISP1            ISP2
Gi0/0/1       Gi0/0/1
Router 1         Router  2
Gi0/0/0          Gi0/0/0
    outside          outside
  ASA1               ASA2
    inside             inside
      Gi1/1/0/1     Gi2/1/0/1
CORE Switch l3 (stackwise virtual)
I have SVIs on the core, one is on vlan 302 (10.28.2.0/24)
Ip routing is enabled so i dont have any problem with my intervlan routing on other subnets like - vlan 305, vlan 307
My Core switch Gi1/1/0/1 and Gi2/1/0/1 is configure on vlan 302
My ASA1 inside is 10.28.2.10/24, outside 50.50.50.1 /24 (Natted dynamically)
My ASA2 inside is 10.28.2.11/24, outside 60.60.60.1 /24 (Natted dynamically)
Router1 Lan IP thru Gi0/0/0 is 50.50.50.2 /24 (Provided by ISP1)
Router1 WAN IP thru Gi0/0/1 80.80/80.1/24 (Provided by ISP1)
Router2 Lan IP thru Gi0/0/0 is 60.60.60.2 /24 (Provided by ISP2)
Router2 WAN IP thru Gi0/0/1 90.90/90.1/24 (Provided by ISP2)
both ISP advertised internet using static routes.
With this in Hand, what methodology should i use to achieve load sharing between ISP1 and ISP2.
I dont like to use PBR route maps to manually define which source vlans goes to ISP1 and ISP2, as much as possibel I want my topology to decide automatically.
Hope someone can help me, been struggling so badly
6 Replies 6
Deepak Kumar
Before Starting an Answer I have a few questions:
1. Have you configured BGP between ISP and Router or is it a default route?
2. How ASA configured?
But as per your basic diagrams:
As both ASAs are working as standalone devices and handling sperate ISP connections so you have below options:
There are multiple options but I am not recommended to configure any HSPR, VRRP, or GLBP at all. Since firewalls have all sorts of state tables, connection tables, translation tables.
So current design Options:
Option 1:
Design Changes: Both ASAs LAN (Inside) interface will configure in the different subnets as
Current Design:
                         ASA1 (Inside) 10.28.2.10 --->Core Switch VLAN 302
                         ASA2 (Inside) 10.28.2.11 --->Core Switch VLAN 302
Required Design:
                         ASA2 (Inside) 10.28.3.10 --->Core Switch VLAN 303
Configure Two Default route on the Core switch towards to the each Cisco ASA and you must monitor those routes using the IPSLA and Track. So if any of connection or ISP will face downtime then all traffic will redirect on another ISP.
Configuration as below on the Core switch:
IP route 0.0.0.0 0.0.0.0 10.28.2.10 track 1
P route 0.0.0.0 0.0.0.0 10.28.3.11 track 2
ip sla 1
icmp-echo 8.8.8.8 source-interface VLAN 302
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
ip sla 2
icmp-echo 8.8.8.8 source-interface VLAN 303
timeout 1000
threshold 2
frequency 3
ip sla schedule 2 life forever start-time now
track 2 ip sla 2 reachability
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak,
1. I only use default route between router and ISP
2. ASA is only using static and default route
Ex .For Fw1
route outside 0.0.0.0 0.0.0.0 50.50.50.2
route inside 10.28.0.0 255.255.0.0 10.28.2.254
May i know what would be the difference if i change the ASA2 inside with different vlan? other than inside the same subnet of vlan 302?
Actually i tried these two default routes on Core before without IP SLA tracking but is not working, If both static default routes are present on my routing table in core I can only ping ISP 2 and ISP 1 is unreachable since based on my understanding it follows the highest next hop IP address which is the 10.28.2.11
Ip route 0.0.0.0 0.0.0.0 10.28.2.10
Ip route 0.0.0.0 0.0.0.0 10.28.2.11
Actually, With the same VLAN IPSLA will not work properly.  And the same issue will appear which you had faced.
Deepak Kumar
Deepak Kumar,
Hi Deepak,
I tried to change the subnet of firewall 2 to other vlan and also put ip sla’s on my static default routes but still same behavior, if two default routes are present on Core’s routing table i can only ping 1 router which is the router behind fw 1 since it has the higher inside ip which is the next hop of my core switch..
Are you tested with tracert on two different systems to any public IP as 8.8.8.8 and 1.1.1.1? Is ECMP working correctly?
If ECMP is working fine then it seems normal behavior because " default is CEF which load-shares per session( src-dst IP pair)". As some of the IPs or Services are especially available through the Specific Gateway. As  Firewall 2 is only available through Router 2 then there is a specified solution for you.
1.  Assign a Static route on Core switch for particular subnet/IP address (Firewall 2 IP) toward to the Router.
Example:
ip route 10.28.2.0 255.255.255.0 60.60.60.2
2. Go with PBR solution as Well.
Deepak Kumar
Deepak Kumar,
Hello
PBR would be the suggest approach here unless you implement some IGP between the fws and the core and manipulate the metrics for certain prefixes ad desired
Kind Regards
Paul
