Mini project
Stefanokj
Community Member
Hi guys, I should help a friend of mine with a small project but now my packettracer memory is a bit out of date.
He should create a small network in a building, there are 5 floors: 4 offices (one per floor) and a secretariat (on the ground floor), from each office it must be possible to connect to the internet and contact the secretariat (and vice versa), it must not be possible to communicate between offices.
What do you recommend? I was thinking of using class C networks, I created a mini model on PT by putting 2 PCs and and a switch per office with a router in the center.
My question is how do I comply with them?
Giuseppe Larosa
Hello @Stefanokj ,
you are required to build a network where any to any connectivity is not permitted.
Each floor / office must be able to :
go to the internet
reach the secretariat subnet
but it is not allowed to speak with other offices.
Going to the internet =  needs for NAT Network address Translation
We can use Private IP addresses from RFC 1918 like 192.168.X.0/24
Floor 1:  192.168.1.0/24
Floor 2: 192.168.2.0/24
Floor 3: 192.168.3.0/24
Floor 4: 192.168.4.0/24
For the Secretary network we can use another subnet like
192.168.17.0/24
We leave space for additional floors or offices
To avoid communication between offices we can use extended ACLs
Example:
For office 1:
access-list 101 remark for office 1
! traffic to the secretariat allowed
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.17.0 0.0.0.255
! traffic to other offices denied a single line matches all other offices
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.15.255
! traffic to internet allowed
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
on the router interface to office 1
interface gi0/0
description office 1
ip accesss-group 101 in
A similar ACL should be configured for office 2 and so on.
In real world we use VLANs and VLAN based subinterfaces to avoid the need of a dedicated interface for each subnet.
A router with VLAN based subinterfaces can connect to a switch where different VLANS are defined
on switch side you define the VLANs
For example the following ones
conf t
 vlan 10
name office1
exit
vlan 20
name office2
exit
vlan 30
name office3
exit
vlan 40
name office4
exit
vlan 170
name secretary
exit
int gi0/24
desc to router:gi0/0
switchport
switchport mode trunk
switchport trunk allowed vlans 10,20,30,40,170
on router side
interface gi0/0
desc to switch gi0/24
no ip address
interface gi0/0.10
enc dot1q 10
ip access-group 101 in
exit
interface gi0/0.20
enc dot1q 20
ip address 192.168.2.1 255.255.255.0
ip access-group 102 in
exit
interface gi0/0.30
enc dot1q 30
ip address 192.168.3.1 255.255.255.0
ip access-group 103 in
exit
interface gi0/0.40
enc dot1q 40
ip address 192.168.4.1 255.255.255.0
ip access-group 104 in
exit
nterface gi0/0.170
enc dot1q 170
ip address 192.168.17.1 255.255.255.0
exit
No ACL is needed on the subinterface for the secretariat as it can speak with anyone
ACL 102-104 are made like ACL 101 but the source address is changed in 192.168.2.0 0.0.0.255 for ACL 102, 192.168.3.0 0.0.0.255 for ACL 103 and so on
Hope to help
Giuseppe
