Missing ADSL (Annex B) support on ISR1100 (GFAST model)
filopeter
I have C1112-8PLTEEA router connected to an ADSL line, but it does not work. The ADSL line is ok, VPI/VCI settings are also ok, the whole configuration was tested successfully with different model (C876). I would like to know if someone has the same bad experience. I have used IOS versions 16.8.2 and 16.9.1 for testing purposes.
Layer 1 on C1112 is up
C1112#show controllers vdsl 0/3/0
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.992.5 (ADSL2+) Annex J
Modem FW Version: 4.16L.05
Modem PHY Version: B2pvfbH043j.d26r
Layer 2 is up
interface ATM0/3/0
no ip address
no atm ilmi-keepalive
no atm enable-ilmi-trap
pvc 1/32
pppoe-client dial-pool-number 1
C1112#sh int atm0/3/0
ATM0/3/0 is up, line protocol is up
Hardware is C1112-GFAST-BJ, address is 780c.f0c0.1018 (bia 780c.f0c0.1018)
MTU 1800 bytes, sub MTU 1800, BW 572 Kbit/sec, DLY 100 usec,
Encapsulation ATM, loopback not set
Keepalive not supported
Encapsulation(s): AAL5
8 maximum active VCs, 0 current VCCs
ATM Dynamic Bandwidth Enabled.
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
2 carrier transitions
Last input never, output never, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
but the input/output packet counters do not increment. VPI/VCI settings are correct.
Debug of pppoe events provides following output
C1112#debug pppoe events
PPPoE protocol events debugging is on
C1112#
*Feb 11 08:30:45.600: PPPoE:ATM0/3/0 1/32, Got ATM VC Event[4]
*Feb 11 08:30:46.599: PPPoE:ATM0/3/0 1/32, Got ATM VC Event[4]
*Feb 11 08:30:46.657: padi timer expired
Best Regards,
Peter
I have solved this problem with a small configuration change.
Instead of ATM physical interface configuration, I have created an ATM subinterface and specified VPI/VCI and PPPoE client configuration under this subinterface.
Non-working configuration
interface ATM0/3/0
no ip address
pvc 1/32
Working configuration
interface ATM0/3/0
no ip address
interface ATM0/3/0.10 point-to-point
pvc 1/32
This new configuration brought up the Virtual-Access interface bound to Dialer interface.
*Feb 12 15:21:36.829: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Feb 12 15:21:36.833: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Feb 12 15:21:37.108: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
The “show interface atm” command output now shows 1 active VCC, before it was 0.
  8 maximum active VCs, 1 current VCCs
Best Regards,
Peter
8 Replies 8
post the full configuration of the router (show run)...
Also, who is your ISP ?
Please find attached following output
show running-config
show version
show interface atm0/3/0
show dialer 1
show atm pvc 1/32
what are your controller options ?
C112(config-controller)# operating mode ?
And who is your ISP ?
Here are the options:
C1112(config-controller)#operating mode ?
adsl1 ITU G.992.1
adsl2 ITU G.992.3
adsl2+ ITU G.992.5
auto auto detect mode
etsi ETSI TS 101 388 V1.3.1 Annex C
vdsl2 ITU G.993.2
My ISP is Slovak Telekom, member of DT group - https://www.telekom.sk/about/
try to set the operating mode manually (try adsl2, adsl2+, and vdsl2). Also, complete the configuration (see below, additions marked in bold).
I have looked at the Slovak Telekom site, and the Cisco is not specifically listed as a supported device. That might not mean much but there is always a chance that their DSLAM is not compatible with the chipset in your router. Check with them to be sure...
https://www.telekom.sk/wiki/zariadenia/modemy-a-routre
Current configuration : 4222 bytes
! Last configuration change at 09:46:00 UTC Mon Feb 11 2019
version 16.8
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname C1112
boot-start-marker
boot-end-marker
no aaa new-model
subscriber templating
license udi pid C1112-8PLTEEA sn FGL223695QA
no license smart enable
diagnostic bootup level minimal
redundancy
mode none
controller Cellular 0/2/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
controller VDSL 0/3/0
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Cellular0/2/0
ip address negotiated
ipv6 enable
interface Cellular0/2/1
no ip address
shutdown
interface ATM0/3/0
no ip address
pvc 1/32
interface Ethernet0/3/0
no ip address
no negotiation auto
interface Vlan1
ip nat inside
ip address x.x.x.x y.y.y.y
interface Dialer1
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username ... password ...
ppp ipcp dns request accept
ppp ipcp route default
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
access-list 1 permit any
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
one more thing, are you sure that Telekom uses PAP ? Just to be sure they don't use CHAP, try the config below (changes marked in bold):
version 16.8
hostname C1112
boot-start-marker
boot-end-marker
no aaa new-model
redundancy
mode none
no ip address
shutdown
negotiation auto
ipv6 enable
no ip address
shutdown
interface ATM0/3/0
no ip address
pvc 1/32
no ip address
no negotiation auto
interface Vlan1
ip nat inside
interface Dialer1
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer idle-timeout 600
dialer-group 1
no keepalive
ppp authentication chap callin
ppp chap hostname xxxxxxxxxx@xxxxxx
ppp chap password 7 xxxxxxxxxxxxxxx
ppp ipcp mask request
no cdp enable
no cdp enable
ip http server
--> no ip route 0.0.0.0 0.0.0.0 Dialer1
control-plane
line con 0
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
interface ATM0/3/0
no ip address
pvc 1/32
interface ATM0/3/0
no ip address
pvc 1/32
Best Regards,
Peter
