NAT, Firewall, Security [ISR 886VA]
Exonix
I've got an email from our ISP, that our router is in danger... They found that the router has SNMP port opened. After that, I scanned our router I found more opened ports: UDP 161, 123, 500 (it is OK, the router does S2S).
Could you please check my configuration.
1) It is OK to be secured from external access?
2) Why UDP ports 161 and 123 are opened?
sh run
Building configuration...
Current configuration : 8466 bytes
! Last configuration change at 11:16:15 UTC Tue Jan 29 2019 by admin
! NVRAM config last updated at 11:17:21 UTC Tue Jan 29 2019 by admin
version 15.4
service password-encryption
hostname router.dyndns.org
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.154-3.M10.bin
boot-end-marker
aqm-register-fnf
enable secret 5 00000000000000000000000
aaa new-model
aaa session-id common
clock timezone UTC 2 0
ip flow-cache timeout active 1
ip domain name domain.com
ip ddns update method dyndns
 HTTP
  add http://user:password@members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
 interval maximum 1 0 0 0
ip cef
no ipv6 cef
cts logging verbose
license udi pid C886VA-K9 sn FCZ2044B08C
username admin privilege 15 secret 5 00000000000000000000000000000
controller VDSL 0
 firmware filename flash:VA_B_38V_d24m.bin
class-map match-all Mikrotik-Dev
 match access-group 102
policy-map Hosts
 class Mikrotik-Dev
crypto isakmp policy 50
 encr aes 256
 authentication pre-share
 group 5
 lifetime 28800
crypto isakmp key 00000000000 address XXX.XXX.XXX.XXX
crypto ipsec transform-set VPN-TS esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map VPN-CM 10 ipsec-isakmp
 description VPN to CITY Office
 set peer XXX.XXX.XXX.XXX
 set transform-set VPN-TS
 set pfs group5
 match address VPN2CITY
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface ATM0.1 point-to-point
 pvc 1/32
  pppoe-client dial-pool-number 1
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 description WAN
 no ip address
 ip nbar protocol-discovery ipv4
 service-policy input Hosts
interface Ethernet0.7
 description VDSL VLAN 7 tagged
 encapsulation dot1Q 7
 pppoe enable group global
interface FastEthernet0
 description Trunk
 switchport mode trunk
 no ip address
interface FastEthernet1
 description WAN
 switchport access vlan 4
 no ip address
 shutdown
 duplex full
interface FastEthernet2
 description DMZ
 switchport access vlan 3
 no ip address
interface FastEthernet3
 description LAN
 no ip address
 duplex full
interface Vlan1
 description LAN
 ip address 10.254.1.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in max-reassemblies 64
interface Vlan2
 description Guest WiFi
 ip address 10.254.2.1 255.255.255.0
 ip access-group 104 in
 ip helper-address 10.254.1.13
 ip flow ingress
 ip nat inside
interface Vlan401
 description LAN
 ip address 10.254.100.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Vlan402
 description TEST
 ip address 10.254.200.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Vlan403
 description LAN
 ip address 10.254.3.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Vlan404
 ip address 10.254.4.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Vlan405
 description Corporate WiFi
 ip address 10.254.5.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Vlan406
 description DMZ
 ip address 10.254.6.1 255.255.255.0
 ip mtu 1492
 ip flow ingress
 ip nat inside
interface Dialer0
 description VDSL TELEKOM
 ip ddns update hostname router.dyndns.org
 ip ddns update dyndns
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 load-interval 30
 dialer pool 1
 dialer-group 1
 no keepalive
 ppp authentication pap callin
 ppp pap sent-username ------------------------@t-online.de password 7 ------------------------
 ppp ipcp dns request
 ppp ipcp mask request
 ppp ipcp route default
 no cdp enable
 crypto map VPN-CM
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source Vlan1
ip flow-export version 9
ip flow-export destination 10.254.1.7 2055
ip flow-top-talkers
 top 10
 sort-by bytes
ip nat translation tcp-timeout 14400
ip nat inside source static tcp 10.254.1.56 8080 interface Dialer0 8080
ip nat inside source static tcp 10.254.1.8 3389 interface Dialer0 3389
ip nat inside source static udp 10.254.1.8 4500 interface Dialer0 4500
ip nat inside source static udp 10.254.1.8 1701 interface Dialer0 1701
ip nat inside source static tcp 10.254.2.23 8080 interface Dialer0 8081
ip nat inside source list NAT interface Dialer0 overload
ip route 10.254.10.0 255.255.255.0 10.254.1.4
ip route 10.255.9.11 255.255.255.255 10.254.1.4
ip route 172.66.0.0 255.255.255.0 10.254.1.4
ip access-list extended NAT
 remark --- exclude S2S trafic ---
 deny   ip 172.66.0.0 0.0.0.255 10.253.3.0 0.0.0.255
 deny   ip 172.66.0.0 0.0.0.255 10.253.1.0 0.0.0.255
 deny   ip 172.66.0.0 0.0.0.255 10.253.5.0 0.0.0.255
 deny   ip 10.254.1.0 0.0.0.255 10.253.3.0 0.0.0.255
 deny   ip 10.254.1.0 0.0.0.255 10.255.10.0 0.0.0.255
 deny   ip 10.254.3.0 0.0.0.255 10.253.3.0 0.0.0.255
 remark --- Office CITY2NAT ---
 permit ip 10.254.1.0 0.0.0.255 any
 permit ip 10.254.2.0 0.0.0.255 any
 permit ip 10.254.3.0 0.0.0.255 any
 permit ip 10.254.4.0 0.0.0.255 any
 permit ip 10.254.5.0 0.0.0.255 any
 deny   ip any any
ip access-list extended VPN2CITY
 permit ip 10.254.1.0 0.0.0.255 10.253.3.0 0.0.0.255
 permit ip 172.16.0.0 0.0.0.255 10.253.3.0 0.0.0.255
 permit ip 172.16.0.0 0.0.0.255 10.253.1.0 0.0.0.255
 permit ip 172.16.0.0 0.0.0.255 10.253.5.0 0.0.0.255
logging source-interface Vlan1
logging host 10.254.1.7
snmp-server community ------------ RO 2
snmp-server community ------------ RO 4
snmp-server location CITY2
snmp-server contact HelpDesk
access-list 2 permit 10.254.0.0 0.0.0.255
access-list 2 permit 10.254.1.0 0.0.0.255
access-list 2 deny   any
access-list 4 permit 10.254.0.0 0.0.0.255
access-list 4 permit 10.254.1.0 0.0.0.255
access-list 4 deny   any
access-list 22 permit 10.254.1.0 0.0.0.255
access-list 102 permit tcp host YYY.YYY.YYY.YYY eq 8888 host CCC.CCC.CCC.CCC eq 8888
access-list 102 deny   tcp any host YYY.YYY.YYY.YYY eq 8888
access-list 102 permit ip any any
access-list 104 permit udp host 10.254.1.13 eq bootps 10.254.2.0 0.0.0.255 eq bootps
access-list 104 permit udp host 10.254.1.13 eq bootpc 10.254.2.0 0.0.0.255 eq bootpc
access-list 104 permit udp host 10.254.1.13 eq bootps 10.254.4.0 0.0.0.255 eq bootps
access-list 104 permit udp host 10.254.1.13 eq bootpc 10.254.4.0 0.0.0.255 eq bootpc
access-list 104 permit udp host 10.254.1.13 eq bootps 10.254.5.0 0.0.0.255 eq bootps
access-list 104 permit udp host 10.254.1.13 eq bootpc 10.254.5.0 0.0.0.255 eq bootpc
access-list 104 deny   ip 10.254.4.0 0.0.0.255 10.254.1.0 0.0.0.255
access-list 104 deny   ip 10.254.4.0 0.0.0.255 172.66.0.0 0.0.0.255
access-list 104 deny   ip 10.254.2.0 0.0.0.255 10.254.1.0 0.0.0.255
access-list 104 deny   ip 10.254.2.0 0.0.0.255 172.66.0.0 0.0.0.255
access-list 104 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 vstack
line con 0
 password 7 00000000000000000000
 no modem enable
line aux 0
line vty 0 4
 access-class 22 in
 exec-timeout 30 0
 logging synchronous
 transport input ssh
line vty 5 189
 exec-timeout 30 0
 logging synchronous
 transport input ssh
scheduler allocate 20000 1000
ntp server 10.254.1.9
end
Thank you in advance!
Thats ok.
ip access-list extended SNMP_LAN
permit udp 10.254.0.0 0.0.0.255 x.x.x.x(IP OF YOUR SNMP SERVER) 0.0.0.0 eq snmp
permit udp x.x.x.x(IP OF YOUR SNMP SERVER) eq snmp 10.254.0.0 0.0.0.255
deny udp any eq snmp any
pertmit ip any any
try apply it on wans interfaces.
Jaderson Pessoa
*** Rate All Helpful Responses ***
12 Replies 12
Jaderson Pessoa
Guy your configurations it is ok and ports 123 has been opened because you are setting a NTP server and 161 because you are using SNMP.
But its recommended that use SNMPv3 > more security. If its not possible, you can use acl's to maximize security.
About your NTP, if this ports werent open to world (INTERNET) you dont have problem.
your configuration : ntp server 10.254.1.9 < its internal address > (i think.)
Jaderson Pessoa
Hello Jaderson,
thank you for your answer.
yes, I use SNMP. But I limited SNMP with ACLs 2 and for internal IPs only, didn't I? By the way, my scanner didn't use any community names, it just connected to 161 port.
snmp-server community --------- RO 2
snmp-server community --------- RO 4
snmp-server location City
snmp-server community wewdwsd RO ?
<1-99>       Std IP accesslist allowing access with this community string
I configured Cisco to use NTP server 10.254.1.9. Yes, this is an internal server, but why I can see this port on the external interface?
Could you please advice me an ACL to close undesired ports? Thank you!
yes, I use SNMP. But I limited SNMP with ACLs 2 and 4 for internal IPs only, didn't I? By the way, my scanner didn't use any community names, it just connected to 161 port.
R: Yes, you did it. :)
R: If your router has a public ip address on any interface, it will be accessible from it.
Check if address its ok.
vlan access-map MAP-SNMP
match ip address SNMP_LAN
action forward
vlan filter SNMP_LAN vlan-list 1,2,3,4,5-6 (YOUR VLANS)
its for SNMP, but you can use it for block other thing that you need, like ntp, ftp, tftp.. or something like that.
More information about:https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_nx-os-cfg/sec_vlanacls.pdf
Jaderson Pessoa
I'm sorry Jaderson, but ISR 886VA doesn't have such commands like vlan access-map:
#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
(config)#ip access-list extended SNMP_LAN
(config-ext-nacl)#$ 0.0.0.255 10.254.1.7 0.0.0.0 eq snmp
(config-ext-nacl)#$ 0.0.0.0 eq snmp 10.254.1.0 0.0.0.255
(config-ext-nacl)#exit
(config)#
(config)#
(config)#vlan access-map MAP_SNMP
% Invalid input detected at '^' marker.
(config)#vlan access-map ?
  <cr>
(config)#vlan acce?
WORD
(config)#vlan acce
(config)#vlan ?
  WORD        ISL VLAN IDs 1-4094
  accounting  VLAN accounting configuration
  dot1q       dot1q parameters
  group       Create a vlan group
  ifdescr     VLAN subinterface ifDescr
#sh version
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.4(3)M10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 08-Aug-18 06:30 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
Thats ok.
pertmit ip any any
Jaderson Pessoa
Thank you Jaderson!
I applied this rule:
ip access-list extended FireWall
 deny   udp any any eq snmp
 deny   udp any any eq ntp
 permit ip any any
it works:
PORT    STATE         SERVICE VERSION
123/tcp closed        ntp
161/tcp closed        snmp
123/udp open|filtered ntp
161/udp open|filtered snmp
I have only one question: how it works? I allow all traffic with rule "permit ip any any" but at the same time the router is secured... Is it because of NAT?
Dear Exonix,
permit udp 10.254.0.0 0.0.0.255 x.x.x.x(IP OF YOUR SNMP SERVER) 0.0.0.0 eq snmp >> will allow snmp from your snmp-server to your lan. .
permit udp x.x.x.x(IP OF YOUR SNMP SERVER) eq snmp 10.254.0.0 0.0.0.255 >> will alow snmp from your lan to your snmp-server
deny udp any eq snmp any >> will block any other snmp traffic.
pertmit ip any any >> allow any other traffic.
Acls are read in order thats was applied. So, before alllow other traffic, snmp will blocked.
Nat's configuration on your router its just translate your internal ip for one or pool of public ip address.
Jaderson Pessoa
Hello Jaderson,
My question isn't about the SNMP now.
My question is - I allow all traffic on WAN interface: permit ip any any - is it secure? Why?
Your wan interface needs access internet right? Baseline in acl works like it:
If you dont allow any traffic its will be block for default.
Só if you remove this command from your acl .> pertmit ip any any
Any devices in your network wont have internet access or other thing that you need access on this interface.
Jaderson Pessoa
would be it better to allow established TCP only and all UDP?
would a way, but if you want controll traffic on your network by acl, will be demand a lot of time and you router will increscent cpu usage. But, you can do it without problem.
Jaderson Pessoa
Please, if possible, rate this as helpful too..
Thanks in advance.
Jaderson Pessoa
