Missing OSPF routes to subnets [GNS3]
AK0
I created a little topology in GNS3 with 3 routers. And the routing tables on R1 and R3 should have two routes to a subnet:
  • R1 should have two equal cost routes to subnet 10.1.5.0/24
  • R3 should have two equal cost routes to subnet 10.1.4.0/24
R1 routing table:
R1#sh ip route ospf
     10.0.0.0/24 is subnetted, 6 subnets
O       10.1.3.0 [110/65] via 10.1.6.3, 00:06:29, Serial0/1
O       10.1.2.0 [110/65] via 10.1.4.2, 00:05:45, Serial0/0
O       10.1.5.0 [110/128] via 10.1.4.2, 00:05:45, Serial0/0
R3 routing table:
R3#sh ip route ospf
O       10.1.2.0 [110/65] via 10.1.5.2, 00:05:37, Serial0/1
O       10.1.1.0 [110/65] via 10.1.6.1, 00:06:13, Serial0/0
O       10.1.4.0 [110/128] via 10.1.5.2, 00:05:37, Serial0/1
R2 routing table:
R2#sh ip route ospf
O IA    10.1.3.0 [110/65] via 10.1.5.3, 00:05:37, Serial0/1
O IA    10.1.1.0 [110/65] via 10.1.4.1, 00:05:37, Serial0/0
O IA    10.1.6.0 [110/128] via 10.1.5.3, 00:05:37, Serial0/1
                         [110/128] via 10.1.4.1, 00:05:37, Serial0/0
R2 does have two equal cost routes to 10.1.6.0/24. Why don't R1 and R3 have two equal cost routes to 10.1.5.0/24 and 10.1.4.0/24 respectively, but instead have only one? Network topology screenshot is included.
From R2 view it see 10.1.6.0 from two routers lsa3 in same area
But for R1/3 it see 10.1.4/5.0 from two routers in different area
Area 0 and Area 1
And ospf prefer prefix intra area  lsa1 over inter area lsa3.
So R1/2 prefers prefix via area 1 and hence there is no equal cost multi path
MHM
10 Replies 10
Area 0 and Area 1
MHM
Ok that was simple. Thanks for the explanation.
Hi @MHM Cisco World ,
Just one small precision. It is the route via area 1 that will be preferred as this is the one seen as an intra area route. The route via area 0 is seen as an inter area route.
I See below so it intra area not inter area inter area must be O IA not O
MHM
Exactly my point. R1 sees the route to 10.1.5.0/24 as an intra area route via R2. R1 sees the same route via R3 as inter area and therefore prefers the one via R2.
That what I was explain to Mr @AK0
R1/2 see prefix 10.1.4/5.0 one time via lsa1 and other via lsa3 and ospf always prefer lsa1 over lsa3. That why he see one path not two.
My comment came from what you said here.
So R1/2 prefers prefix via area 0 and hence there is no equal cost multi path
R1 and R3 do not prefer the path via area 0, but rather the one via area 1.
Sorry it typo I correct it.
MHM
Yes I understand now. The "O" in R1 routing table next to 10.1.5.0/24 means INTRA-area route, I explain it to myself as: the subnet is part of an area of which the local router (R1) is part of.
In this case 10.1.5.0/24 is part of Area 1, and next-hop 10.1.4.2 (R2) is also in Area 1, so to reach a subnet in Area 1, stay in Area 1, no need to forward to another area (no need to forward to Area 0 first, and then back into Area 1).
No need config friend I see what @Harold Ritter meaning it typo and correct it.
Thanks all
MHM
