Router interface won't come up if plugged into another router
Turbow5
I bought two 1841 routers as a lab and the setup is basic. Just these two routers, no switches yet. I plug them into each other and nothing happens. Not even a link light blink. Tried several wires and both ports on both routers. Nothing. I plug them both into my home router and they both come up instantly. I'm stumped on why when they are plugged into each other, they don't come up.
Ideas?
R1:
Current configuration : 744 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$1P0/$ZkrLsG8MiRjq2epmfyji51
no aaa new-model
ip cef
interface FastEthernet0/0
ip address 10.0.0.17 255.255.255.240
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.1 255.255.255.240
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password CCNP
logging synchronous
login local
transport input telnet
line vty 5 807
logging synchronous
login
scheduler allocate 20000 1000
end
R2:
R2#show run
Building configuration...
Current configuration : 610 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip address 10.0.0.65 255.255.255.240
duplex auto
speed auto
ip address 10.0.0.33 255.255.255.240
duplex auto
speed auto
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
logging synchronous
login
end
Leo Laohoo
What cable are you using? Cross over or straight?
6 Replies 6
Leo Laohoo
I'm shaking my head because I didn't think about that. Yeah it's a straight through.  Is there a way for the router to switch it logically? If I'm not mistaken, I think switches can do that logically?..
Hi @Turbow5 ,
Everything indicates that it is a cable problem.
Surely, your home router supports MDIX.
I suggest you modify one of your cables and convert it to cross over cable to rule out that possibility.
Obviously, you can also get a cross over cable to try.
So I looked up commands for MDIX  and I can only conclude the 1841 doesn't do MDIX because nothing shows at all. :(
Thank you very much for helping me figure this out. Learned something new today.
ISR G1 doesn't support MDI/MDI-X.
You need a cross-over cable.
smufarhan
Hi,Router <======> Router Connection. You need Cross-Over Cable.
Old devices do not support MDI/MDI-X
