Mix of E1 and E3 in a Channelized STM-1/OC-3 model SPA-1XCHSTM1/OC3 ?
albert_coll
The 1-Port Channelized STM-1/OC-3 Shared Port Adapter data sheet states that it supports:
Up to 84 T1 (or 3 T3) or 63 E1 (or 3 E3) ports
Up to 1022 nxDS-0 channels (where n is 1 to 24) with no T3 configured
Up to 400 nxDS-0 channels (where n is 1 to 24) with one or more T3 configured
Is possible a combination of both: E1 and E3 concurrently?
Data Sheets reports combinations with T1 and T3, but does not include anything regarding E1 and E3.
Giuseppe Larosa
Hello Albert,
I think you can use a mix of E1 and E3 this is provided by SDH standards
-Port Channelized STM-1/OC-3 SPA Interface Specifications
The framer processes incoming and outgoing SONET or SDH frames. The framer operates at OC-3c/STM-1 line rates (155.52 Mbps).
Packet data is transported with a user-configured encapsulation (such as Point-to-Point Protocol [PPP]) and is mapped into the STS-3c/STM-1 frame.
The 1-Port Channelized STM-1/OC-3 SPA interface is compliant with RFC 1619, PPP over SONET/SDH, and RFC 1662, PPP in HDLC-like Framing. The 1-Port Channelized STM-1/OC-3 SPA also provides support for SNMP v1 agent (RFC 1155-1157), and Management Information Base (MIB) II (RFC 1213).
this is an example taken from cisco IOS XR for GSR but the module is the same:
The following example shows SDH AU-4 configuration.
RP/0/0/CPU0:router# configure
RP/0/0/CPU0:router(config)# controller sonet 0/1/0/0
RP/0/0/CPU0:router(config-sonet)# clock source internal
RP/0/0/CPU0:router(config-sonet)# framing sdh
RP/0/0/CPU0:router(config-sonet)# au 1
RP/0/0/CPU0:router(config-auPath)# mode tug3
RP/0/0/CPU0:router(config-auPath)# width 3
RP/0/0/CPU0:router(config-auPath)# tug3 1
RP/0/0/CPU0:router(config-tug3Path)# mode e3
RP/0/0/CPU0:router(config-tug3Path)# root
RP/0/0/CPU0:router(config)# controller e3 0/1/0/0/0/0
RP/0/0/CPU0:router(config-e3)# mode e1
RP/0/0/CPU0:router(config-e3)# root
RP/0/0/CPU0:router(config)# controller E1 0/1/0/0/0/0/0/0
RP/0/0/CPU0:router(config-e1)# channel-group 0
RP/0/0/CPU0:router(config-e1-channel_group)# timeslots 1-12
RP/0/0/CPU0:router(config-e1-channel_group)# show configuration
RP/0/0/CPU0:router(config-e1-channel_group)# root
RP/0/0/CPU0:router(config)# interface serial 0/1/0/0/0/0:0
Router(config-if)# encapsulation frame-relay | hdlc | ppp
Router(config-if)# ip address 10.10.10.10 255.255.255.255
Router(config-if)# no shutdown
RP/0/0/CPU0:router(config-sonet)# commit
RP/0/0/CPU0:router# show controllers sonet 0/1/0/0
see
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.6/interfaces/configuration/guide/hc36chst.html#wp1094814
Hope to help
Giuseppe
Giuseppe,
Thank you for your valuable reply.
