mLACP Question
Dears
Would like your assistance please regarding MC-LAG
According to below diagram, are both links are active at same time , or one active and the other is standby ?
I believe below how it works .. please correct me If I am wrong
- Both modes are supported only If we used LACP between CE & 7600 thanks to LACP command "lacp max-bundle"
- This command will restrict 1 link only from both 7600 to be active at a time
- If we used static LAG (no negotiation), then by default all links will be active
- If I am correct in above, do I need to configure "lacp max-bundle" on CE side also or 7600s side only will be enough ?
Unfortunately I have no lab to test .. however I am sure you would provide me with good answers
rsimoni
yes only the links toward a PoA (7600) are active while the link(s) toward the other PoA are in standby.
lacp max-bundle is needed on 7600 only.
A lab to test this is not that simple as you need particular hardware (ES20/40 cards) I know.
More info here:
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap4.html#wpxref85507
Riccardo
Thanks Ricacardo for your reply
- Is there a possibility for active-active mode ?
- Also what is the use for "lacp max-bundle" since mLACP works in active-standby mode ?
   Or It use will be for links @ active POA only ?
For ES20/40 ... This is v.bad news :-)
An IMP question Ricacardo please
I was able to test MC-LAG in a 7600 lab with ES cards .... And what surprized me that it seems that MC-LAG does not work with L2 (switchport) or even with a L3 .... It only works with "service instance command" pseudo wires , correct  ?
Many Thanks
