port security action on 3750 - requesting new feature maybe :)
cchartouny
Hi, I was wondering if there is a workaround to have a mac access-list bond to a port security violation action
our need is the following: we have a range of 10 mac addresses that can use any port on the 3750, we only want to allow those ones yet we also need to tak action if a denied mac appears on any port of the switch.
the only work around I found is to basically go into a port-rage mode and list all the allowed mac addresses under all the ports of the switch. I would also add to that a port violation action. did not test it but should work. problem is, it would be a huge config.
I did read that we can create a mac access list and then bind that mac to physical ports wich will actually simplify our solution yet I did not find a way to bind the mac list with a port violation action.
thanks for the feedback
Nandan Mathure
As you said you can do this by using port-security with default action shutdown, by allowing specfic 10 mac-addresses per port or if shutting the port is not neccessary then by simply using VLAN filter by calling vlan access-maps which will allow only those 10 mac addresses to communicate on that VLAN and silently drop other hosts.
Nandan Mathure
