Monitoring shaping - 1841 router
LucaSalvatore_2
I have the following very simple policy configured on a Cisco 1841.
policy-map Shape-2Mb
class class-default
  shape average 2000000
interface FastEthernet0/1
  ip address 165.xx.xx.xx.xxx 255.255.255.252
ip access-group BLOCK-LOGIN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no mop enabled
service-policy output Shape-2Mb
I'd just like some clarification on the best ways to monitor this.
Looking at the 'sh policy-map int fa0/1' i get this:
FastEthernet0/1
  Service-policy output: Shape-2Mb
    Class-map: class-default (match-any)
      376798 packets, 513067020 bytes
      5 minute offered rate 1121000 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
          2000000/2000000   12500  50000     50000     25        6250
        Adapt  Queue     Packets   Bytes     Packets   Bytes     Shaping
        Active Depth                         Delayed   Delayed   Active
        -      0         376463    513036870 95056     121786479 yes
But some of the sections don't make much sence to me.... Can someone explain the output of that command, or point me in the direction of some doco?
thanks.
rstanisl
HI,
The below URL does explain the show policy-map command that you see.
http://www.cisco.com/en/US/customer/docs/ios/qos/command/reference/qos_s4.html#wp1119758
let me know if that is the info you are looking for and hope it helps clarify your questions
Raymond
Router# show policy-map interface serial3/2 output
 Serial3/2
  Service-policy output: p1
    Class-map: c1 (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: ip precedence 0
      Traffic Shaping
        Target    Byte   Sustain   Excess    Interval  Increment Adapt
        Rate      Limit  bits/int  bits/int  (ms)      (bytes)   Active
        320000    2000   8000      8000      25        1000      -
        0         0         0         0         0         no
      0 packets, 0 bytes
      Match: any
Table 195 describes significant fields commonly shown in the displays. The fields  in the table are grouped according to the relevant QoS feature.
Table 195     show policy-map interface Field Descriptions1
Field
Description
Fields Associated with Classes or Service Policies
Name of the output service policy applied to the specified interface or VC.
Class-map
Class of traffic being displayed. Output is displayed for each  configured class in the policy. The choice for implementing class  matches (for example, match-all or match-any) can also appear next to  the traffic class.
packets and bytes
Number of packets (also shown in bytes) identified as belonging to the class of traffic being displayed.
offered rate
Rate, in kbps, of packets coming in to the class.
Note If  the packets are compressed over an outgoing interface, the improved  packet rate achieved by packet compression is not reflected in the  offered rate. Also, if the packets are classified before they enter a combination of tunnels (for example, a generic routing  encapsulation (GRE) tunnel and an IP Security (IPSec) tunnel), the  offered rate does not include all the extra overhead associated with  tunnel encapsulation in general. Depending on the configuration, the  offered rate may include no overhead, may include the overhead for only one tunnel encapsulation, or may include the overhead for all tunnel encapsulations. In most of the GRE and IPSec tunnel  configurations, the offered rate includes the overhead for GRE tunnel  encapsulation only.
drop rate
Rate, in kbps, at which packets are dropped from the class. The drop  rate is calculated by subtracting the number of successfully transmitted  packets from the offered rate.
Note In  distributed architecture platforms (such as the Cisco 7500 series  platform), the value of the transfer rate, calculated as the difference  between the offered rate and the drop rate counters, can sporadically  deviate from the average by up to 20 percent or more. This can occur  while no corresponding burst is registered by independent traffic  analyser equipment.
Match
Match criteria specified for the class of traffic. Choices include  criteria such as IP precedence, IP differentiated services code point  (DSCP) value, Multiprotocol Label Switching (MPLS) experimental (EXP)  value, access groups, and QoS groups. For more information about the  variety of match criteria that are available, see the "Classifying  Network Traffic" module in the Cisco IOS Quality of Service Solutions Configuration Guide.
Fields Associated with Queueing (if Enabled)
Output Queue
The weighted fair queueing (WFQ) conversation to which this class of traffic is allocated.
Bandwidth
Bandwidth, in either kbps or percentage, configured for this class and the burst size.
pkts matched/bytes matched
Number of packets (also shown in bytes) matching this class that were  placed in the queue. This number reflects the total number of matching  packets queued at any time. Packets matching this class are queued only  when congestion exists. If packets match the class but are never queued  because the network was not congested, those packets are not included in  this total. However, if process switching is in use, the number of  packets is always incremented even if the network is not congested.
depth/total drops/no-buffer drops
Number of packets discarded for this class. No-buffer indicates that no memory buffer exists to service the packet.
Fields Associated with Weighted Random Early Detection (WRED) (if Enabled)
exponential weight
Exponent used in the average queue size calculation for a WRED parameter group.
mean queue depth
Average queue depth based on the actual queue depth on the interface and  the exponential weighting constant. It is a fluctuating average. The  minimum and maximum thresholds are compared against this value to  determine drop decisions.
class
IP precedence level.
Transmitted pkts/bytes
Number of packets (also shown in bytes) passed through WRED and not dropped by WRED.
Note If there is insufficient memory in the buffer to accommodate the packet, the packet can be dropped after the packet passes through WRED. Packets dropped because of insufficient  memory in the buffer (sometimes referred to as "no-buffer drops") are  not taken into account by the WRED packet counter.
Random drop pkts/bytes
Number of packets (also shown in bytes) randomly dropped when the mean  queue depth is between the minimum threshold value and the maximum  threshold value for the specified IP precedence level.
Tail drop pkts/bytes
Number of packets dropped when the mean queue depth is greater than the  maximum threshold value for the specified IP precedence level.
Minimum thresh
Minimum threshold. Minimum WRED threshold in number of packets.
Maximum thresh
Maximum threshold. Maximum WRED threshold in number of packets.
Mark prob
Mark probability. Fraction of packets dropped when the average queue depth is at the maximum threshold.
Fields Associated with Traffic Shaping (if Enabled)
Target Rate
Rate used for shaping traffic.
Byte Limit
Maximum number of bytes that can be transmitted per interval. Calculated as follows:
((Bc+Be) /8) x 1
Sustain bits/int
Committed burst (Bc) rate.
Excess bits/int
Excess burst (Be) rate.
Interval (ms)
Time interval value in milliseconds (ms).
Increment (bytes)
Number of credits (in bytes) received in the token bucket of the traffic shaper during each time interval.
Queue Depth
Current queue depth of the traffic shaper.
Packets
Total number of packets that have entered the traffic shaper system.
Bytes
Total number of bytes that have entered the traffic shaper system.
Packets Delayed
Total number of packets delayed in the queue of the traffic shaper before being transmitted.
Bytes Delayed
Total number of bytes delayed in the queue of the traffic shaper before being transmitted.
Shaping Active
Indicates whether the traffic shaper is active. For example, if a  traffic shaper is active, and the traffic being sent exceeds the traffic  shaping rate, a "yes" appears in this field.
1 A  number in parentheses may appear next to the service-policy output  name, class-map name, and match criteria information. The number is for  Cisco internal use only and can be disregarded.
 Serial3/2
      0 packets, 0 bytes
      Traffic Shaping
        0         0         0         0         0         no
      0 packets, 0 bytes
      Match: any
Field
Description
Class-map
packets and bytes
offered rate
drop rate
Match
Output Queue
Bandwidth
exponential weight
mean queue depth
class
Minimum thresh
Maximum thresh
Mark prob
Target Rate
Byte Limit
((Bc+Be) /8) x 1
Sustain bits/int
Excess bits/int
Interval (ms)
Increment (bytes)
Queue Depth
Packets
Bytes
Packets Delayed
Bytes Delayed
Shaping Active
