monitoring traffic on T1
fprime7
I have a 7204 Cisco Router with T1 inteface and the traffic is supposed to
to outputing to the Fastethernet port
I was trying to monitor the traffic
I have looked at the
sh int
sh int stat
sh int accounting
and I see a different in the in the traffic counts
Is there any utility in IOS that can
capture the actual traffic on both links
Frank
mmorris11
Level 4
Level 4
You can use SPAN on the switch port that the FE port is connected to and use a software sniffer to capture the traffic on that interface. You can follow this guide for pretty well any Cisco IOS switch:
http://www.cisco.com/en/US/customer/products/hw/switches/ps5528/products_configuration_guide_chapter09186a00803a9a86.html
Once you designate a destination port for your span source (your 7204 fe port for ex.) you can connect a PC/laptop to that destination port and run ethereal, or whatever sniffer software you like and see a full dump of all traffic.
HTH pls rate!
