Moving Static to Eigrp
taimoor khan
Guys I need little help in moving from static route to eigrp. Here is the problem, I moved all static route to eigrp so as a result internet of Calgary side was down and toronto was up. I used no auto-summary command , redistribute command but problem was not solved. everything was working in calgary like servers, email except internet. Is there any other command please help me ?
Giuseppe Larosa
Hello Taimoor,
more informations would be needed to provide real help
However, to access internet you need a default route and appropriate NAT statements.
so you need to verify what is different in the two sites:
- where the default route is pointing ? ( if any is present with EIGRP looks for a route flagged with D  * initial code )
- are NAT rules present also for the IP subnets of the other site?
if you have joined two sites your network may be trying to exit to internet from site1 using site2's internet link. So site2 requires additional NAT rules covering site1 IP subnets.
Hope to help
Giuseppe
Thanks for help Giuseppe
I changed the static route to eigrp and everything is wokring fine but now router is very slow. Could you please tell me how to handle that problem.
