MP-BGP Lab configuration not working
afgitdepartment
I am trying to learn about MP-BGP and the example configurations I find on the net are not working in my dynamips lab.
I have two routers (EAST and WEST) connected via their fa0/0 interfaces with 10.0.9.0/30 subnet between them.
version 12.4
hostname EAST
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf VRF1
rd 209:1
route-target export 209:1
route-target import 209:1
ip vrf VRF2
rd 209:2
route-target export 209:2
route-target import 209:2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Loopback100
ip vrf forwarding VRF1
ip address 100.103.196.1 255.255.255.252
interface Loopback200
ip vrf forwarding VRF2
ip address 200.103.196.1 255.255.255.252
interface FastEthernet0/0
ip address 10.0.9.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 1
passive-interface default
no passive-interface FastEthernet0/0
network 1.1.1.1 0.0.0.0
network 10.0.9.0 0.0.0.3
no auto-summary
router bgp 209
bgp log-neighbor-changes
neighbor 1.1.1.2 remote-as 209
neighbor 1.1.1.2 update-source Loopback0
address-family ipv4
  neighbor 1.1.1.2 activate
  neighbor 1.1.1.2 send-community extended
  no auto-summary
  no synchronization
exit-address-family
address-family ipv4 vrf VRF2
  redistribute connected
  no synchronization
exit-address-family
address-family ipv4 vrf VRF1
  no synchronization
exit-address-family
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
version 12.4
hostname WEST
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf VRF1
rd 209:1
ip vrf VRF2
rd 209:2
interface Loopback0
ip address 1.1.1.2 255.255.255.255
ip address 109.103.196.1 255.255.255.252
ip address 209.103.196.1 255.255.255.252
ip address 10.0.9.1 255.255.255.252
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 1.1.1.2 0.0.0.0
no auto-summary
router bgp 209
neighbor 1.1.1.1 remote-as 209
neighbor 1.1.1.1 update-source Loopback0
address-family ipv4
  neighbor 1.1.1.1 activate
  neighbor 1.1.1.1 send-community extended
  no auto-summary
  no synchronization
exit-address-family
  no synchronization
exit-address-family
  no synchronization
exit-address-family
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
WEST# SHOW IP Bgp SUmmary
BGP router identifier 1.1.1.2, local AS number 209
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
1.1.1.1         4   209      10      10        1    0    0 00:07:13        0
EAST#SH IP BGp SUmmary
BGP router identifier 1.1.1.1, local AS number 209
1.1.1.2         4   209      10      10        1    0    0 00:07:02        0
EAST#SHOW IP BGp VPNv4 ALL
BGP table version is 5, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 209:1 (default for vrf VRF1)
*> 100.103.196.0/30 0.0.0.0                  0         32768 ?
Route Distinguisher: 209:2 (default for vrf VRF2)
*> 200.103.196.0/30 0.0.0.0                  0         32768 ?
WEST#SHOW IP BGp VPNv4 ALL
BGP table version is 8, local router ID is 1.1.1.2
*> 109.103.196.0/30 0.0.0.0                  0         32768 ?
*> 209.103.196.0/30 0.0.0.0                  0         32768 ?
I am expecting on both routers to see these prefixes in the VRFs that are tied to the loopbacks
What am I missing?
2 Accepted Solutions
Raju Sekharan
You have not configured "address-family vpnv4" under bgp
Raju
Giuseppe Larosa
the exchange of VPNv4 routes requires the configuration of address-family vpnv4 you have to replicate the configuration for address-family ipv4 under family vpnv4
the key commands are neigh activate and neigh send-community extended to be given under af
Hope to help
Giuseppe
Raju Sekharan
Raju
thanks. that did the trick.
Giuseppe Larosa
Hope to help
Giuseppe
