vrf and bgp in core
suthomas1
Level 6
Level 6
the network has 3 vlans - wireless , users & printers on the core switch.  The Core switch is connected to its uplink wan router for internet access.
Core switch - 10.58.21.2/30 and router - 10.58.21.1/30
The requirement is to run vrf/bgp between this core and the upstream router.
router bgp 65001
bgp log-neighbor-changes
network 10.50.20.0 mask 255.255.255.0
network 10.58.10.0 mask 255.255.255.128
neighbor 10.58.21.1 remote-as 65005
no auto-summary
interface gig0/2
ip address 10.58.21.2 255.255.255.252
description Uplink to router
Currently the uplink is connected via a layer3 interface on the core switch. However, there will be a second uplink connected to the router from core switch.
I am not very consistent on vrf. Please help me on how the configuration should be for this, including the individual vlans and with two uplinks.
The upstream routes need to work with vrf.
Appreciate all help!
10 Replies 10
mahmoodmkl
Level 7
Level 7
You can create a new VRF and assign gig0/2 in that VRF but remember that you will not able reach this IP from global routing table unless you have routing between them.
ip vrf VRFNAME
and then under the interface
ip forwarding vrf VRFNAME
Thanks. Since there are two uplinks from this Core switch, we were thinking of creating a /30 vlan interface connecting the switch and upstream router.
So, lets say vlan 21 ,
int vlan 21
ip vrf VRFNAME
So on both the physical interfaces on Core switch , can i use below configuration:-
int gi0/2
desc uplink1 to router
sw mode trunk
int gi0/3
sw mode trunk
Will this suffice? and also do i need to put ip vrf VRFNAME under each of the other wireless, users & printers vlans.
Thanks in advance !
mahmoodmkl
Level 7
Level 7
i suggest to use physical interface like a point to point link instead of vlan interface
make the physical interface on which the router is connected as a routed port n assign the ip n vrf info
Ok. in that case , since we have two physical interfaces from the core switch towards the uplink router, how do i configure two different physical interfaces with one /30 ip address?
and also how will the vrf configuration look like for this?
Since your running ebgp.. can you just have a second /30 for the second uplink, and stick to routed interfaces?
I wonder if this would work..  please try in a lab first or in GNS3..
switch
ip routing
ip vrf wireless
rt 1:1
ip vrf users
rt 1:2
ip vrf printers
rt 1:3
int vlan 1
ip address 10.0.1.1 255.255.255.0
ip vrf forwarding wireless
no shut
int vlan 2
ip address 10.0.2.1 255.255.255.0
ip vrf forwarding users
no shut
int vlan 3
ip address 10.0.3.1 255.255.255.0
ip vrf forwarding printers
no shut
int gi0/2
desc first uplink router
no shut
int gi0/3
ip address 10.58.21.6 255.255.255.252
desc second uplink router
no shut
router bgp 65001
address-family ipv4
neighbor 10.58.21.7 remote-as ???
no auto-summary
address-family vpnv4 wireless
network 10.0.1.0 mask 255.255.255.0
address-family vpnv4 users
network 10.0.2.0 mask 255.255.255.0
address-family vpnv4 printers
network 10.0.3.0 mask 255.255.255.0
router
ip vrf wireless
rt 1:1
ip vrf users
rt 1:2
ip vrf printers
rt 1:3
int gi0/2
ip address 10.58.21.1 255.255.255.252
no shut
interfaces for vrfs if any ....
router bgp 65005
address-family ipv4
neighbor 10.58.21.2 remote-as 65001
no auto-summary
network or redistribute from outside..
of course the disclaimer....
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
If i am to use vlan svi , can i still use a /30 for the routed link upstream and still do vrf with the two interfaces part of the routed uplink?
mahmoodmkl
Level 7
Level 7
if u use svi with /30 it will give u two ips which will not be enough for three devices
swith n two routers
hence have separate p2p ips for u r routers n switch
yes that is correct.
so , in that case if i use a /28 to interconnect the switch and router, what option should be best :-
1. to create an SVI
2. to create an L3 Portchannel
mahmoodmkl
Level 7
Level 7
i suggest to go with L3 links
