MPLS BGP routing issue
mayureshgangal
All experts
We have MPLS connectivity (running BGP)between the DC and remote locations.now a days we are facing problem with remote location reachability.
When we try to trace the remote location from DC ,
path should be DC-----MPLS CLOUD---remote location ip
but now when traced,it shows DC---some other remote location ip--MPLS cloud  then the actual remote location ip which we are trying to trace
Why it is not reaching directly from DC to remote locations.
what could be the problem
any suggestions will be really helpful
with regards
mayuresh
Marwan ALshawi
Hi mayuresh
this can be because of many reasons can you help by providing the info bellow
- is the MPLS owned by your company or it si a service PRvider MPLS cloud ?
- what routing protcol you run between the DC and MPLS cloud
- what routing protocl you run between remote sites and MPLS cloud
- how many links the DC use to peer with MPLS cloud
- how many links th eremote sites use to peer with MPLS cloud
do you have sample topology of your network showing the the logical routing in your network ?
once you provide the above we can narrow down the reason
Hi marwanshawi
Thanks for the reply
Please find the details below
1) MPLS is owned by service provider
2)Between DC and MPLS cloud running BGP
3)between remote locations and MPLS cloud running BGP
4)currently only one link to peer with MPLS cloud
5) remote locations are also having only one link to peer with MPLS cloud
6) All remote locations are having ISDN as backup connectivity which is running EIGRP process
please find the attach diagram
with regards
mayuresh
ok can you provide the bellow show command for the destination IP you did trace route to
show ip route x.x.x.x   where x.x.x.x is the remote IP/network you did trace route to
provide the above from the DC router and from the router that act as transit before to reach the actual IP
