MPLS encap is not supported on this circuit
Atif Siddiqui
Here is the situation:
7606-s
12.2(33)SRE1
xconnect with MPLS encap not configuring
PE4#sh run int g2/1.828
Building configuration...
Current configuration : 65 bytes
interface GigabitEthernet2/1.828
encapsulation dot1Q 828
end
PE4(config)#int g 2/1.828
PE4(config-subif)#xconnect 10.10.10.130 123125 pw-class en-mpls
PE4(config-subif)#
We were able to configure it initially. Now it is giving us an error.
interface GigabitEthernet2/2
 no ip address
 speed 1000
interface GigabitEthernet2/2.3508
 encapsulation dot1Q 3508
 xconnect 10.10.10.133 123123 pw-class en-mpls
PE4#show module
Mod Ports Card Type                              Model              Serial No.
  2   20  7600 ES+                               7600-ES+20G3C
  3   20  7600 ES+                               7600-ES+20G3C
  4    0  4-subslot SPA Interface Processor-400  7600-SIP-400
 5    2  Route Switch Processor 720 (Active)    RSP720-3C-GE
  6    2  Route Switch Processor 720 (Hot)       RSP720-3C-GE
anyone expereinced this?
Atif
antasson
Hi Atif,
if you enable "service internal", is the problem still there?
Let me know,
Antonio
