MPLS LDP command
asim.mz99
"MPLS LDP" command is not working on ASR9906 router.
Even I cannot see tunnel-te is not there.
Harold Ritter
Hi @asim.mz99 ,
You probably don't have the MPLS and MPLS TE RSVP packages activated.
You can see which packages you have activated with the following command:
RP/0/RP0/CPU0:ios#sh install active
Mon Mar 6 02:14:36.341 UTC
Label : 7.4.1-0
Node 0/RP0/CPU0 [RP]
Boot Partition: xr_lv0
Active Packages: 11
xrv9k-xr-7.4.1 version=7.4.1 [Boot image]
xrv9k-mpls-te-rsvp-3.1.0.0-r741
xrv9k-m2m-2.0.0.0-r741
xrv9k-eigrp-1.0.0.0-r741
xrv9k-isis-2.1.0.0-r741
xrv9k-mgbl-3.0.0.0-r741
xrv9k-mpls-2.1.0.0-r741
xrv9k-ospf-2.0.0.0-r741
xrv9k-bng-1.0.0.0-r741
xrv9k-mcast-3.0.0.0-r741
xrv9k-k9sec-3.1.0.0-r741
You can also do "show install inactive" to  and see, which packages are available and not active and then use the "install activate <package name>" to activate the package. Don't forget to do a "install commit" at the end.
balaji.bandi
You need to give more information -
"MPLS LDP" command is not working on ASR9906 router.  - what error are you getting what IOS XR running ?
Even I cannot see tunnel-te is not there.  - what syntax are you using what is the error?
some reference for ASR
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/mpls/command/reference/b-mpls-cr-asr9000/mpls-traffic-engineering-commands.html
BB
Harold Ritter
Hi @asim.mz99 ,
Label : 7.4.1-0
Active Packages: 11
