MPLS LDP Session Establishment failed
Steve
i have tried to connect an
ASR1004(RP2,ESP20,SIP10) and a C6504E(VS-S720-10G)
over 10G direct links.
10G port on C6504E
is located on a
WS-X6708-10GE ( with WS-F6700-DFC3C)
linecard. Both interfaces are
MPLS enabled via mpls ip
IP connectivity between the
mpls loopbacks
of the routers is working fine, can ping with max
MTU 9216 and df-bit set
The tcpdump (via monitor session) from the interface on the
C6504E
shows "LDP Hello Messages" from both routers.
ASR1004
which has the higher
LSR-ID
initiates the LDP TCP Connection to
C6504E
but connection is refused on
C6504E
by sending  TCP (RST,ACK).
What could be the reason for dropping the connection ? i have attached a zip with the pcap trace from interface traffic
ASR1004 loopback1 172.16.217.254/32
C6504E loopback1 172.16.211.254/32
ASR1004 te1/0/0 172.16.220.14/30
C6504E te2/1 172.16.220.13/30
Global setting on both routers:
mpls ldp router-id Loopback1 force
C6504E#ping 172.16.220.14 size 9216 df-bit source lo1 repeat 10
Sending 10, 9216-byte ICMP Echos to 172.16.220.14, timeout is 2 seconds:
Packet sent with a source address of 172.16.211.254
Packet sent with the DF bit set
Success rate is 100 percent (10/10), round-trip min/avg/max = 1/2/4 ms
ASR1004#ping 172.16.220.13 source lo1 size 9216 df-bit repeat 10
Sending 10, 9216-byte ICMP Echos to 172.16.220.13, timeout is 2 seconds:
Packet sent with a source address of 172.16.217.254
Success rate is 100 percent (10/10), round-trip min/avg/max = 2/2/3 ms
Steve
hi all,
i restarted the module in slot 2 on
C6504E  with hw-module module 4 reset
but nothing changed. so i decided to reboot the entire
C6504E
and now all is working.
C6504E#sh mpls ldp neighbor te2/1
Peer LDP Ident: 172.16.217.254:0; Local LDP Ident 172.16.211.254:0
TCP connection: 172.16.220.14.52729 - 172.16.220.13.646
State: Oper; Msgs sent/rcvd: 67/12; Downstream
Up time: 00:03:59
LDP discovery sources:
Thanks all to you for input
41 Replies 41
show mpls ldp neighbor
I need to see this
on
C6504E
there are other LDP Sessions active which i won't post here - so i have selected the affected interface
C6504E#
ASR1004#sh mpls ldp neighbor
ASR1004#
As there is no LDP Session established we won't see here anything (i think)
Some more infos
ASR1004#sh mpls ldp discovery detail
Local LDP Identifier:
172.16.217.254:0
Discovery Sources:
Interfaces:
TenGigabitEthernet1/0/0 (ldp): xmit
Enabled: Interface config
Hello interval: 5000 ms; Transport IP addr: 172.16.217.254
Clients: IPv4, mLDP
C6504E#sh mpls ldp discovery detail
172.16.211.254:0
Discovery Sources:
Interfaces:
TenGigabitEthernet2/1 (ldp): xmit
Hello interval: 5000 ms; Transport IP addr: 172.16.211.254
Clients: IPv4, mLDP
Udp port 646 is open or not ?
Yes
 no access-lists
on interfaces
ASR1004#telnet 172.16.211.254 646 /source-interface lo1
Trying 172.16.211.254, 646 ...
% Connection refused by remote host
As you can see TCP connection is refused - so port should be open
In the meanwhile i have done some more connectivity tests and it seems there is packetloss on the link. 10 pings was not enough to loose packets
ASR1004#ping 172.16.211.254 size 1500 df-bit repeat 100 source lo1
Sending 100, 1500-byte ICMP Echos to 172.16.211.254, timeout is 2 seconds:
Success rate is 92 percent (92/100), round-trip min/avg/max = 1/1/1 ms
i will have to fix this before we can follow up - will take some time (until next week) as this is a remote site  - thanks for your help
I think I found issue here
I see in ldp discovery thst you use multiPoint Ldp (mLDP) not LDP
This change source destination of ldp packet.
Disbale mldp under interface.
This doesn't change anything
interface TenGigabitEthernet2/1
mtu 9216
ip address 172.16.220.13 255.255.255.252
no ip redirects
no ip proxy-arp
no mpls mldp
mpls ip
C6504E#sh mpl ldp discovery detail | begin 2/1
Clients: IPv4, mLDP
Maybe this indicates only interface is capable of mLDP or it refers to this
Directly Connected MPLS LDP Sessions
If a label switch router (LSR) is one hop from its neighbor, it is directly connected to its neighbor. The LSR sends out Label Distribution Protocol (LDP) link Hello messages as User Datagram Protocol (UDP) packets to all the devices on the subnet (multicast). A neighboring LSR may respond to the link Hello message, allowing the two devices to establish an LDP session. This is called basic discovery.
you disable it in C6000 side, disable it in ASR1K side
Sorry my answer was too inaccurate - it was changed on both sides
ASR1004#sh run int te1/0/0
Building configuration...
Current configuration : 302 bytes
interface TenGigabitEthernet1/0/0
mtu 9216
ip address 172.16.220.14 255.255.255.252
no ip redirects
no ip proxy-arp
load-interval 30
mpls ip
no mpls mldp
172.16.217.254:0
Discovery Sources:
Interfaces:
Clients: IPv4, mLDP
Hi @Steve ,
For the output you provided, it looks like neither router receive the LDP hellos from the neighbour, as both of them show as
xmit
 when they should as
xmit/recv
Hello Harold,
i think until LDP session isn't established interface will always be
xmit
 If you check the the pcap file you can see hellos from both routers. i have enabled debug on
ASR1004
and there you can see hello is working and
ASR1004
(Router with the higher LSR-ID) tries to establish a TCP connection (LDP Session) to
C6504E
On
ASR1004
MPLS ldp:
LDP transport events debugging is on for interface
LDP transport connection events debugging is on for interface
*Jun 7 22:11:31.010: ldp: Send ldp hello; TenGigabitEthernet1/0/0, src/dst 172.16.220.14/224.0.0.2, inst_id 0
*Jun 7 22:11:34.993: ldp: Rcvd ldp hello; TenGigabitEthernet1/0/0, from 172.16.220.13 (172.16.211.254:0), intf_id 0, opt 0xC
*Jun 7 22:11:34.993: ldp: ldp Hello from 172.16.220.13 (172.16.211.254:0) to 224.0.0.2, opt 0xC
*Jun 7 22:11:34.993: ldp: New adj 0x7F19D75FA358 for 172.16.211.254:0, TenGigabitEthernet1/0/0
*Jun 7 22:11:34.993: ldp: adj_addr/xport_addr 172.16.220.13/172.16.211.254
*Jun 7 22:11:34.993: ldp: Request adj send hello back on TenGigabitEthernet1/0/0 to (xport addr 172.16.211.254) in 50 msec
*Jun 7 22:11:34.993: ldp: local interface = TenGigabitEthernet1/0/0, holdtime = 15000, peer 172.16.220.13 holdtime = 15000
*Jun 7 22:11:34.993: ldp: Link intvl min cnt 2, intvl 5000, interface TenGigabitEthernet1/0/0
*Jun 7 22:11:34.993: ldp: Opening ldp conn; adj 0x7F19D75FA358, 172.16.217.254 <-> 172.16.211.254; with normal priority
*Jun 7 22:11:34.993: ldp: :{ldp conn 172.16.217.254:64033=>172.16.211.254:646}: Registered tcb 0x7F19CA59D528 [key 48199] with LDP TCB database, total 1
*Jun 7 22:11:34.994: ldp: Conn failed (TCP connect notify)!; adj 0x7F19D75FA358, 172.16.220.13
*Jun 7 22:11:34.994: ldp: : rx_notify tcp_rc 5, adj_state 3
*Jun 7 22:11:34.994: ldp: {ldp conn 172.16.217.254:64033=>172.16.211.254:646} (Te1/0/0) (adj 0x7F19D75FA358): processing transport close request
*Jun 7 22:11:34.994: ldp: Unregistered from LDP TCB database tcb 0x7F19CA59D528 [key 48199], total 0
*Jun 7 22:11:34.994: ldp: Close tcp connection to 172.16.211.254
*Jun 7 22:11:34.994: ldpx_tcp: {ldp conn 172.16.217.254:64033=>172.16.211.254:646}: client requesting close of tcb
*Jun 7 22:11:34.994: ldp: Adj 0x7F19D75FA358; state set to closed
*Jun 7 22:11:35.043: ldp: Send ldp hello; TenGigabitEthernet1/0/0, src/dst 172.16.220.14/224.0.0.2, inst_id 0
*Jun 7 22:11:35.553: ldp: Scan listening TCBs
Hi @Steve ,
xmit
This
xmit/rcvd
state only pertains to LDP hellos. So the
show mpls ldp dis det
output you provided clearly state that the routers did not consider to have two way reachability.
Hi @Steve ,
You probably want to run the same debug command on the 6500 side to see what it says.
Hi @Harold Ritter
this is a little bit strange now - the debug on
C6504E
shows no receiving hello messages but if i check the pcap trace i can see it. The trace is taken from
C6504E
with a monitor session (source is te2/1 in both directions).
As @MHM Cisco World noted earlier 'is port udp 646 open'  - is there a way to check this ? ( i only have verified tcp)
Below the captured hello packet on
C6504E
which was sent from ASR1004 and the debug log from
C6504E
DEBUG LOG from C6504E (no received ldp hello packets)
031445: Jun 8 11:14:47.821 CEST: ldp: Send ldp hello; TenGigabitEthernet2/1, src/dst 172.16.220.13/224.0.0.2, inst_id 0
031446: Jun 8 11:14:51.617 CEST: ldp: bytes_written = 34, at offset = 160
031447: Jun 8 11:14:51.617 CEST: ldp: Send ldp hello; TenGigabitEthernet2/1, src/dst 172.16.220.13/224.0.0.2, inst_id 0
031448: Jun 8 11:14:55.474 CEST: ldp: bytes_written = 34, at offset = 160
031449: Jun 8 11:14:55.474 CEST: ldp: Send ldp hello; TenGigabitEthernet2/1, src/dst 172.16.220.13/224.0.0.2, inst_id 0
031450: Jun 8 11:14:59.430 CEST: ldp: bytes_written = 34, at offset = 160
031451: Jun 8 11:14:59.430 CEST: ldp: Send ldp hello; TenGigabitEthernet2/1, src/dst 172.16.220.13/224.0.0.2, inst_id 0
i have cross checked the debug command on a different interface (on the same Linecard) which has a working LDP Session and there i can see received and send hello packets.
So it seems C6504E is receiving the hello packets from ASR1004 but it drops it
