MPLS LDP Xconnect interface not forwarding traffic
adamspera
Hello! I am trying to set up the following topology, where the devices on the ends do not know the three middle devices are there.
Device #1 <> NCS5001 <> NCS5001 <> NCS5001 <> Device #2
I have set up OSPF on the NCS's to enable communication between them, and enabled MPLS LDP communication through OSPF. I have also created a Xconnect p2p group that is registering as UP UP. Though the end devices cannot communicate. I have attached some output relevant to the issue, as well as a text file with abbreviated running configs.
I believe the source of the issue is that the interface Ge0/0/0/0 on edgemost NCS's that connect to the client devices, are not transmitting any traffic, yet are receiving it? Interesting issue.
Thanks for any help or thoughts!
DEVICE #1 (leftmost)
RP/0/RP0/CPU0:ios#show mpls forwarding
Wed May 17 02:12:49.061 UTC
Local  Outgoing    Prefix             Outgoing     Next Hop        Bytes
Label  Label       or ID              Interface                    Switched
24000  Pop         PW(2.2.2.2:100)    Gi0/0/0/0    point2point     0
24001  Pop         2.2.2.2/32         Gi0/0/0/15   10.0.0.2        27414
24002  Pop         10.0.1.0/24        Gi0/0/0/15   10.0.0.2        0
24003  24001       3.3.3.3/32         Gi0/0/0/15   10.0.0.2        0
RP/0/RP0/CPU0:ios#sh l2vpn xconnect
Wed May 17 02:13:06.317 UTC
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready, (PP) = Partially Programmed,
        LU = Local Up, RU = Remote Up, CO = Connected, (SI) = Seamless Inactive
XConnect                   Segment 1                       Segment 2
Group      Name       ST   Description            ST       Description            ST
test       p2p        UP   Gi0/0/0/0              UP       2.2.2.2         100    UP
RP/0/RP0/CPU0:ios#sh int Gi0/0/0/0
Wed May 17 02:13:27.200 UTC
GigabitEthernet0/0/0/0 is up, line protocol is up
  Interface state transitions: 1
  Hardware is GigabitEthernet, address is 00bc.60eb.7bc6 (bia 00bc.60eb.7bc6)
  Layer 2 Transport Mode
  MTU 1514 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 1000Mb/s, TFD, link type is force-up
  output flow control is off, input flow control is off
  Carrier delay (up) is 10 msec
  loopback not set,
  Last link flapped 01:25:18
  Last input 00:00:00, output never
     628 packets input, 72700 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 14 broadcast packets, 103 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
RP/0/RP0/CPU0:ios#sh mpls l?
label  lctrl  ldp  lib
lsd
RP/0/RP0/CPU0:ios#sh mpls ldp forwarding
Wed May 17 02:19:04.337 UTC
Codes:
  - = GR label recovering, (!) = LFA FRR pure backup path
  {} = Label stack with multi-line output for a routing path
  G = GR, S = Stale, R = Remote LFA FRR backup
  E = Entropy label capability
Prefix          Label   Label(s)       Outgoing     Next Hop            Flags
                In      Out            Interface                        G S R E
2.2.2.2/32      24001   ImpNull        Gi0/0/0/15   10.0.0.2
3.3.3.3/32      24003   24001          Gi0/0/0/15   10.0.0.2
10.0.1.0/24     24002   ImpNull        Gi0/0/0/15   10.0.0.2
DEVICE #2 (middle)
  Encapsulation ARPA,
  loopback not set,
label  lctrl  ldp  lib
lsd
Codes:
DEVICE #3 (rightmost)
Wed May 17 02:35:51.858 UTC
24001  24000       1.1.1.1/32         Gi0/0/0/15   10.0.1.2        0
24002  Pop         10.0.0.0/24        Gi0/0/0/15   10.0.1.2        0
24003  Pop         2.2.2.2/32         Gi0/0/0/15   10.0.1.2        34998
24005  Pop         PW(2.2.2.2:100)    Gi0/0/0/0    point2point     0
Wed May 17 02:35:58.768 UTC
Wed May 17 02:36:05.159 UTC
  Interface state transitions: 3
  Hardware is GigabitEthernet, address is c472.95a7.b206 (bia c472.95a7.b206)
  Encapsulation ARPA,
  loopback not set,
  Last link flapped 01:26:55
  Last input 00:00:00, output 01:26:57
     703 packets input, 84207 bytes, 0 total input drops
     19 drops for unrecognized upper-level protocol
     Received 6 broadcast packets, 123 multicast packets
     28 packets output, 5389 bytes, 0 total output drops
     Output 5 broadcast packets, 23 multicast packets
Wed May 17 02:36:18.018 UTC
Codes:
1.1.1.1/32      24001   24000          Gi0/0/0/15   10.0.1.2
2.2.2.2/32      24003   ImpNull        Gi0/0/0/15   10.0.1.2
10.0.0.0/24     24002   ImpNull        Gi0/0/0/15   10.0.1.2
Thanks again!
Harold Ritter
Hi @adamspera ,
You need to run the pseudowire between the two end NCS devices, not to the middle one.
DEVICE #1 RUNNING (left)
l2vpn
 xconnect group test
  p2p p2p
   interface GigabitEthernet0/0/0/0
   neighbor ipv4 3.3.3.3 pw-id 100
 DEVICE #3 (right most) running
l2vpn
 xconnect group test
  p2p p2p
   neighbor ipv4 1.1.1.1 pw-id 100
Harold Ritter
Hi @adamspera ,
l2vpn
 xconnect group test
  p2p p2p
l2vpn
 xconnect group test
  p2p p2p
