mpls nhrp vs mpls bgp forwarding
mmaamm238
I run MPLS/VPN to separate my different services.
1. What is the difference between "mpls nhrp" and "mpls bgp forwarding"?
2. If a router has two uplinks (a serial and a DMVPN over an ethernet link), is it possible to use "mpls ip" on serial and "mpls bgp forwarding" on tunnel interface?
DMVPN is over metro Ethernet and Serial is direct from branch to HQ.
Mpls bgp forwarding <- this make bgp send label for each prefix
Mpls nhrp<- this as I know use only for flexvpn.
For your topolgy it not so clear
Are you use dmvpn over mpls
And serial interface connect to mpls SP?
MHM
I run mpls myself not with SP.
