MPLS Redistribution between BGP and OSPF
Evlaa2021
In my lab configuration i am not able to redistribute between BGP and OSPF in an MPLS type setup, i've attached a topology diagram and full configs for reference. On my PE routers i can see that they are learning routes from the CE/CPE routers via OSPF, example below. Routes are being redistributed into BGP but then at the remote side of the MPLS VPN they do not get put back into OSPF.
PE1#show ip route vrf MFT_CORP 192.168.200.0
Routing entry for 192.168.200.0/32, 1 known subnets
Redistributing via bgp 50
O 192.168.200.1
[110/2] via 192.168.1.2, 00:06:12, GigabitEthernet3/0.100
This is a loopback interface on CPE 1
The routes are being learned across the BGP neighborship and passed to PE2 but not redistributed back into OSPF.
PE1#show run | sec router
router ospf 100 vrf MFT_CORP
router-id 55.55.55.55
log-adjacency-changes
redistribute bgp 50 subnets
router ospf 20 vrf HSCN
router-id 5.5.5.5
router ospf 1
mpls ldp autoconfig
router bgp 50
no synchronization
bgp log-neighbor-changes
bgp redistribute-internal
neighbor 10.0.0.6 remote-as 50
neighbor 10.0.0.6 update-source Loopback0
no auto-summary
address-family vpnv4
neighbor 10.0.0.6 activate
neighbor 10.0.0.6 send-community extended
exit-address-family
address-family ipv4 vrf MFT_CORP
redistribute ospf 100 vrf MFT_CORP
no synchronization
exit-address-family
address-family ipv4 vrf HSCN
redistribute ospf 20 vrf HSCN
no synchronization
exit-address-family
mpls ldp router-id Loopback0
PE2(config-router)#do show run | sec router
router-id 66.66.66.66
router-id 6.6.6.6
router ospf 1
mpls ldp autoconfig
router bgp 50
no synchronization
neighbor 10.0.0.5 remote-as 50
neighbor 10.0.0.5 update-source Loopback0
no auto-summary
neighbor 10.0.0.5 activate
neighbor 10.0.0.5 send-community extended
exit-address-family
no synchronization
exit-address-family
no synchronization
exit-address-family
Recently added command 'bgp redistribute-internal' as i read iBGP learned routes will not redistribute into an IGP, i've never had to add this command before though?
17 Replies 17
Harold Ritter
Hi @Evlaa2021 ,
Can you post the output from these commands from PE2:
show bgp vpnv4 uni vrf MFT_CORP
Hi Harold,
Thanks for assisting, please see below:
PE2#show bgp vpnv4 uni vrf MFT_CORP
BGP table version is 60, local router ID is 10.0.0.6
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65000:100 (default for vrf MFT_CORP)
*>i10.0.101.0/24 10.0.0.5 0 100 0 ?
*> 10.0.102.0/24 0.0.0.0 0 32768 ?
*> 172.16.0.1/32 192.168.21.2 2 32768 ?
*> 172.16.3.1/32 192.168.21.2 2 32768 ?
*>i172.16.4.1/32 10.0.0.5 2 100 0 ?
*>i192.168.1.0/30 10.0.0.5 0 100 0 ?
*> 192.168.21.0/30 0.0.0.0 0 32768 ?
PE2#show ip route vrf MFT_CORP 192.168.200.0
Redistributing via ospf 100
B 192.168.200.1 [200/2] via 10.0.0.5, 00:00:26
PE2#
Sorry there was some output missing on that:
BGP table version is 62, local router ID is 10.0.0.6
*>i192.168.200.1/32 10.0.0.5 2 100 0 ?
PE2#
Hi @Evlaa2021 ,
Can you also provide the output for the following command from PE2:
show ip ospf 100 database
PE2#show ip ospf 100 database
OSPF Router with ID (66.66.66.66) (Process ID 100)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
8.8.8.8 8.8.8.8 1332 0x8000000C 0x001C13 4
66.66.66.66 66.66.66.66 1346 0x8000000C 0x004520 3
192.168.31.2 192.168.31.2 3730 0x80000005 0x008693 1
Summary Net Link States (Area 0)
10.0.101.0 66.66.66.66 353 0x80000001 0x006AD8
172.16.4.1 66.66.66.66 353 0x80000001 0x009659
192.168.1.0 66.66.66.66 353 0x80000001 0x0079D1
192.168.200.1 66.66.66.66 353 0x80000001 0x00F588
Hi @Evlaa2021 ,
As you can see in the output, the route (192.168.200.1) is indeed redistributed in ospf. Are you not seeing it being installed on CPE2? If not, can you share CPE2 configuration?
Hi Harold,
It all seems to be working on the PE routers but not being installed into the routing table on the CPE side:
CPE2#show ip route vrf MFT_CORP
Routing Table: MFT_CORP
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 2 subnets
C 172.16.0.0 is directly connected, Loopback0
C 172.16.3.0 is directly connected, Loopback2
192.168.21.0/30 is subnetted, 1 subnets
C 192.168.21.0 is directly connected, GigabitEthernet1/0.100
10.0.0.0/32 is subnetted, 1 subnets
O 10.0.102.1 [110/2] via 192.168.21.1, 00:55:25, GigabitEthernet1/0.100
CPE2#
Full CPE config is below:
CPE2#show run
Building configuration...
Current configuration : 2112 bytes
version 12.4
hostname CPE2
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no ip icmp rate-limit unreachable
ip cef
ip tcp synwait-time 5
ip vrf HSCN
ip vrf MFT_CORP
no ip domain lookup
interface Loopback0
ip vrf forwarding MFT_CORP
ip address 172.16.0.1 255.255.255.0
ip ospf 100 area 0
interface Loopback1
ip vrf forwarding HSCN
ip ospf 20 area 0
interface Loopback2
ip address 172.16.3.1 255.255.255.0
ip ospf 100 area 0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface GigabitEthernet1/0
no ip address
negotiation auto
interface GigabitEthernet1/0.20
description HSCN
encapsulation dot1Q 20
ip address 192.168.31.2 255.255.255.252
ip ospf network point-to-point
ip ospf 20 area 0
interface GigabitEthernet1/0.100
description MFT_CORF
encapsulation dot1Q 100
ip address 192.168.21.2 255.255.255.252
ip ospf 100 area 0
interface GigabitEthernet2/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet4/0
no ip address
shutdown
negotiation auto
router-id 88.88.88.88
redistribute connected subnets
redistribute static subnets
router-id 8.8.8.8
router ospf 1
no ip http server
no ip http secure-server
logging alarm informational
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
CPE2#
I can see that routes have been recieved from PE 2 but not installed in the routing table, even when setting the metric specifically (redistribute bgp 50 metric 100 metric-type 1 subnets) :
CPE2# show ip osp 100 database
OSPF Router with ID (8.8.8.8) (Process ID 100)
8.8.8.8 8.8.8.8 1470 0x8000000D 0x001A14 4
66.66.66.66 66.66.66.66 1516 0x8000000D 0x004321 3
10.0.101.0 66.66.66.66 238 0x80000002 0x004A94
172.16.4.1 66.66.66.66 238 0x80000002 0x006C20
192.168.1.0 66.66.66.66 238 0x80000002 0x00598D
192.168.200.1 66.66.66.66 238 0x80000002 0x00CB4F
CPE2#show ip osp 100 database summary 192.168.200.1
LS age: 276
Options: (No TOS-capability, DC, Downward)
LS Type: Summary Links(Network)
Link State ID: 192.168.200.1 (summary Network Number)
Advertising Router: 66.66.66.66
LS Seq Number: 80000002
Checksum: 0xCB4F
Length: 28
Network Mask: /32
TOS: 0 Metric: 100
One thing i wasn't totally sure on is if i need any route-target import or export setting on the CE/CPE side, i've tried combinations of with and without without any luck. Can you advise?
Hi @Evlaa2021 ,
The reason the route is not installed on the CPE is that you configured ospf with VRF lite. In this type of configuration, you need to configure the following command on the CPE for the route to be installed.
capability vrf-lite
This should fix the issue.
Hello @Evlaa2021 , @MHM Cisco World ,
capability vrf-lite
solves the issue of the original poster because it disables the check of the DOWN bit in the LSA.
When coming from MP BGP the re-constructed LSA has a flag set called DN down bit so that the route cannot be re-injected via another PE or VRF lite device.
So no need for import/export commands on CPE2 just to disable the check of the DN bit.
see
https://datatracker.ietf.org/doc/html/rfc4577
Hope to help
Giuseppe
As Mr.Harold mention you need capability vrf-lite,
Also I think he need route import-export in each CE since we push the VRF from PE toward CE.
Hi @MHM Cisco World ,
VRF lite does not require the configuration of any route-target import/export.
Mr.Harold And Mr.Giuseppe
You Are My network Wikipedia,
thanks for sharing knowledge with us.
I see many Lab about VRF-lite with OSPF and MPLS and as I mention before since we push the VRF separation into CE then we need route import/export under VRF.
please see the lab below and I wait your opinion.
 https://sites.google.com/site/amitsciscozone/mpls/multi-vrf-or-vrf
Thanks for the kind words.
The route-target is only used when importing or exporting routes to VPNv4 to VPNv6 for L3VPN. Configuring the RT import/export on the CE will not break anything, but it will not have any effect on which routes will be present in a given VRF.
What keeps the isolation between the VRFs in the VRF lite context is the configuration of multiple sub interfaces each belonging to a separate VRF.
Hello @MHM Cisco World ,
thanks for your kind words    we have simply working experience in the service provider context.
About the lab  you have mentioned:
I agree with @Harold Ritter multi VRF CE or VRF lite is a subset of a standard PE node with MP BGP signaling plane but it is missing the MPLS forwarding plane.
As a result of this the PE - CE link has to use a dedicated subinterface one for each customer to achieve connectivity.
A standard PE node requires a single link with MPLS IP on it to serve N different VRF customers.
VRF lite or multi VRF CPE are useful for service providers to offer value added services like a managed multi tenant CPE serving multiple customers in the same building.
Hope to help
Giuseppe
