05-27-2010 12:24 AM - edited 03-04-2019 08:36 AM
i want to change one mpls-vpn spoke site to hub site .Whate are the config changes required for this at PE an CE
please explain
thanks
05-27-2010 03:17 AM
Hi Vicky
What kinda change you are planning out for ? you need to make sure that your SP is aware and updated on that.
Since the routing is taken care by the SP, you need to consult with them before you do any changes which can very well affect your connectivity.
regds
05-27-2010 04:53 AM
I explained the change Am looking for .My current network is not Hub-Spoke MPLS-VPN.I have configured 2 site are HUB already and 10 sites as spoke. ineed to convert one mpore spoke site as HUB.So what ould be the config changes required at CE and at Service provider PE in terms of VRF ,RT etc ... I would liekt o know
thanks
