Eliminate existing CSU/DSU device..
abdulrasheeth
Currently i am having a cisco 7513 router with FSIP controller connected to Paradyne Comsphere 3000 CSU/DSU via serial cable. The remote site is connected via T1 dedicated line and a small paradyne modem connects to cisco 2600 router. Now i am planning to use purely cisco devices and eliminate the paradayne CSU/DSU and the modems. What routers should i buy for HO and branch office with what interface cards?
paolo bevilacqua
The smaller you can use is a 1841 with HWIC-1DSU-T1. However, a 1941 would be "better".
Thanks for your reply. Can i connect now the T1 directly to the router. Also can you brief about HWIC-1DSU-T1 and a sample configuration. Thank again in advance.
Can you suggest some modules that can fit in 6500 switch for the above scenario?
