MPLS with 2 ISPs
We have a customer currently running MPLS across all remote sites approx 40+ sites and growing. Customer is building a DR Site across a different geographic location to provide full failover to remote sites in case of an outage back at CORE. This DR site will also have an internet connection to a different ISP Provider than what is currently used at their CORE Site. We are looking for a solution to automatically route Internet Traffic to DR site in case of an outage at CORE site. Since customer is running MPLS there is no way to inject a failover default route to remote sites since the next hop is AT&T's Routers. Can you please provide some documentation or PDF we can reference to fully accomplish this task. Customer does not want to use BGP or have their own AS # as of right now. Is there another way we can accomplish true failover between CORE and DR sites in case of Internet Connectivity outage at CORE through an MPLS network,
5 Replies 5
shivlu jain
Level 5
Level 5
check this may be this can help you
http://www.cisco.com/warp/public/459/hsrp_bgp.html
regards
shivlu
This is using BGP. I am looking for a solution not involving BGP. This is 2 Sites in 2 different Geographic areas.
Joseph W. Doherty
Customer is running full MPLS end-to-end, no CE-PE handoff?
That is correct full MPLS
If no helpful posts in this forum, you might try the MPLS forum.
