mroute questions
gongya001
mroute.PNGOn R5, I can ping 239.1.1.1
R5(config)#do ping 239.1.1.1
Sending 1, 100-byte ICMP Echos to 239.1.1.1, timeout is 2 seconds:
Reply to request 0 from 1.1.1.1, 1 ms
But the mroute table does not have the route
R5#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
       N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
       Q - Received BGP S-A Route, q - Sent BGP S-A Route,
       V - RD & Vector, v - Vector, p - PIM Joins on route,
       x - VxLAN group
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
 Timers: Uptime/Expires
 Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 00:06:06/00:02:40, RP 0.0.0.0, flags: DCL
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Ethernet0/0, Forward/Dense, 00:06:06/stopped
On R4, I have
R4#show ip mroute
       x - VxLAN group
(*, 239.1.1.1), 00:06:13/stopped, RP 0.0.0.0, flags: D
    Ethernet0/2, Forward/Dense, 00:06:13/stopped
    Ethernet0/0, Forward/Dense, 00:06:13/stopped
    Ethernet0/1, Forward/Dense, 00:06:13/stopped
(172.31.1.5, 239.1.1.1), 00:00:59/00:02:00, flags: T
  Incoming interface: Ethernet0/2, RPF nbr 172.31.1.5
    Ethernet0/1, Prune/Dense, 00:00:59/00:02:00
    Ethernet0/0, Forward/Dense, 00:00:59/stopped
(*, 224.0.1.40), 00:08:53/00:02:56, RP 0.0.0.0, flags: DCL
    Ethernet0/2, Forward/Dense, 00:07:24/stopped
    Ethernet0/0, Forward/Dense, 00:08:53/stopped
    Ethernet0/1, Forward/Dense, 00:08:53/stopped
Anything  have I missed here ?
thanks !!
Jon Marshall
R5 is acting as the source for the multicast stream so it is not routing it, that only happens when the packets are received by R4.
I think the confusion is due to the fact you are using a router as a source as a test but usually the source would be a server and you would not expect that to participate in multicast routing.
Jon
Jon Marshall
Jon
thanks !
When R5 ping 239.1.1.1, does it use routing table or it send ping as multicast ?  if R5 has multiple interfaces, how does it decide which interface it should use to send ping ?
thanks so much !!
