MSDP session source IP and RP
sarahr202
Level 5
Level 5
Hi everyone.
Please consider the following example:
(LO:1.1.1.1 )R1-12.12.12.1---12.12.12.2 R2 (LO:2.2.2.2)
Above we are setting MSDP session between R1 and R2. This is what I see:
Case 1:
R1 has a loopback0 : 1.1.1.1/32
ip pim rp-address 1.1.1.1
ip msdp peer 2.2.2.2
I see :
 R1 will not initiate TCP session for MSDP
Case2:
ip msdp peer 2.2.2.2 connect-source loopback 0
I see:
R1  initiates TCP session for MSDP.
That tells me MSDP session SRC IP must be same as  RP's address on R1
is it normal behavior or am I seeing GNS3 bug?
Additional info:
RFC 3618 does not say anything about SOURCE IP of MSDP session should be same as RP's IP address on the originating peer.
R1#show version
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)S3, RELEASE SOFTWARE (fc1)
Thanks and have a nice weekend!!
Reza Sharifi
Hi Sarah,
Long time no see here.
As long as the source is a loopback address but I don't think the source has to be the RP's IP address.
ip msdp peer 2.2.2.2 connect-source loopback 1 (3.3.3.3)
interface loopback1
ip address 3.3.3.3
Reza Sharifi
Hi Sarah,
interface loopback1
ip address 3.3.3.3
Thanks Reza, nice to hear from you old friend:)
