MTU is 9196 (9170 is available to IP)
kuriakose1
When I did this command  on a ASR 9904 , p#sh ipv4 interface bundle-ether 11, got below output
trying to figure out , how come this is possible to work. I believe  there has to be min (40 ) difference between IP MPTU and MTU . IP header =20, TCP header 20 =40 .
second question is:  When one of the interface from this ASR  get connect to a switch , what should be the MTU setting on the other end device ? 9196 9170 or some thing else,  will there be   performance issue i use different setting on th eother end device . if then why ?
rais
Level 7
Level 7
9170 available to IP means that full IP packet [including its overhead etc.] could be 9170 octets. The rest 9196-9170=26 is to be used by layers below. Ethernet uses 18 octets and the remaining 8 are preamble bits for a total of 26.
HTH.
how the router calculate the 9170 is hard since even small tag can effect bytes calculation.
but for other side what you must config sure it 9196  not 9170.
