03-14-2018 07:15 AM - edited 03-05-2019 10:06 AM
Hi.  We need to configure 6 devices in a network /28 to see each other in ISIS.
4 of them have IOS and 2 of them have IOS XR. The interfaces are subinterfaces of a bundle.
And there is a restriction from the Vendor giving us Layer 2 connectivity that MTU size must be 9000, no higher.
However in the Bundle interface of all the 6 devices we have the MTU set to 9216.
There are other subintefaces not in ISIS on that Interface, that are configured to form BGP peering to get GRE tunnels formed above them.
At this moment this is what we have configured:
XR-ROUTER
interface Bundle-Ether10
 bfd address-family ipv4 fast-detect
 mtu 9216
interface Bundle-Ether10.2085
 ipv4 address 10.10.10.1 255.255.255.240
 encapsulation dot1q 2085
router isis CGs
 is-type level-2-only
 net 49.0001.2170.1001.6020.00
 nsf cisco
 log adjacency changes
 address-family ipv4 unicast
  metric-style wide
  redistribute connected route-policy CONN2ISIS
  circuit-type level-2-only
   metric 10000000
IOS-ROUTER
interface Port-channel10
 mtu 9216
 no ip address
 load-interval 30
end
interface Port-channel10.2085
 encapsulation dot1Q 2085
 ip address 10.10.10.2 255.255.255.240
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 ip router isis
 isis metric 10000000
end
router isis
 net 49.0001.2170.1001.6031.00
 area-password NT$ucks
 metric-style wide
 no hello padding
 redistribute static ip
 passive-interface Loopback0
With that configuration the neighbors are stuck in INIT.  And we saw that they are sending larger packets (9213) from one end that are not received from the other.
CET: ISIS-Adj: Sending L2 LAN IIH on Port-channel10.2085, length 9213
If we added the command "clns mtu 9000" in the IOS subinterface in two IOS ends, the ISIS neighbor came up.
 clns mtu 9000
But this command is not available in IOS XR.  There is a command "lsp-mtu" at router ISIS level
RP/0/RSP0/CPU0:cg1.prv2(config-isis)#lsp-mtu ?
  <128-4352>  Max LSP size in bytes
At the time of testing the IOS XR interface was down, so we are not sure if the neighboring would have came up with IOS interface with clns mtu set.  Do you know if it should work?
1) Can you help us to determine if these "clns mtu" in the IOS subinterfaces would make the ISIS neigh come up in the other IOS neigh as well as in XR neigh and that won´t affect any other ISIS neigh on other networks or configurations of other subinterfaces?
2) Also, we think that a proper fix would be to change the Interface MTU to 9000 but that will affect the BGP sessions for the GRE tunnels.
Do you know if changing the MTU only on our side (we don´t have managment of the other end of those tunnels) can make the tunnels go down and never come up?
BTW ip tcp path-mtu-discovery is enabled.
 mtu 9216
 no ip address
 load-interval 30
end
interface Port-channel10.2500
 encapsulation dot1Q 2500
 ip vrf forwarding VRF10155
 ip address 10.254.6.241 255.255.255.254
 no ip redirects
 no ip proxy-arp
 ip flow ingress
interface Tunnel2500
 ip address 172.29.0.1 255.255.255.252
 ip mtu 1450
 ip tcp adjust-mss 1300
 ip policy route-map zscaler-tunnels
 load-interval 30
 keepalive 10 3
 tunnel source 10.254.6.241
 tunnel destination 10.136.41.41
 tunnel vrf VRF10155
SH ip bgp vpnv4 vrf VRF10155 neigh 10.254.6.240 | b Datagrams
Datagrams (max data segment is 9130 bytes):
Rcvd: 5780031 (out of order: 0), with data: 3078735, total data bytes: 58497713
Sent: 5722167 (retransmit: 17), with data: 2761066, total data bytes: 52460280
(c1r1.kis1.se) sescqrt01nt01fm#
(c1r1.kis1.se) sescqrt01nt01fm#ping vrf VRF10155 10.254.6.240 size 9000
Sending 5, 9000-byte ICMP Echos to 10.254.6.240, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/24/24 ms
(c1r1.kis1.se) sescqrt01nt01fm#ping vrf VRF10155 10.254.6.240 size 9130
Sending 5, 9130-byte ICMP Echos to 10.254.6.240, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Thanks in advance for your help!
04-10-2018 07:07 AM
We have changed the MTU size of the Portchannel interfaces in all 6 devices, but ISIS neighbours only came up between IOS neigh and between IOS XR neighbors, but not IOS and IOS XR.
Do you have any suggestion on what to test?  What might be wrong or missing either in IOS or XR?
Please find the devices output.
IOS XR
RP/0/RSP0/CPU0:cg1.prv2#sh run int BE10.2085
Tue Apr 10 14:56:11.888 CEST
 description One in DK
 mtu 9000
 ipv4 address 85.x.x.x 255.255.255.240
RP/0/RSP0/CPU0:cg1.prv2#sh run int Bundle-Ether10
Tue Apr 10 14:56:21.076 CEST
 description
 mtu 9000
 load-interval 30
RP/0/RSP0/CPU0:cg1.prv2#sh isis neigh
Tue Apr 10 14:56:03.800 CEST
IS-IS CGs neighbors:
System Id      Interface        SNPA           State Holdtime Type IETF-NSF
dkccqrt09nt00fm Te0/2/1/3        001b.0def.9380 Up    21       L2   Capable
cg2.bal6       BE10.2085        70e4.224d.0b93 Up    22       L2   Capable
Total neighbor count: 2
RP/0/RSP0/CPU0:cg1.prv2#sh isis int Bundle-Ether10.2085
Tue Apr 10 14:56:42.227 CEST
Bundle-Ether10.2085         Enabled
  Adjacency Formation:      Enabled
  Prefix Advertisement:     Enabled
  IPv4 BFD:                 Disabled
  IPv6 BFD:                 Disabled
  BFD Min Interval:         150
  BFD Multiplier:           3
  Circuit Type:             level-2-only
  Media Type:               LAN
  Circuit Number:           5
  Level-2
    Adjacency Count:        1
    LAN ID:                 cg1.prv2.05
    Priority (Local/DIS):   64/64
    Next LAN IIH in:        2 s
    LSP Pacing Interval:    33 ms
    PSNP Entry Queue Size:  0
  CLNS I/O
    Protocol State:         Up
    MTU:                    8979
    SNPA:                   78ba.f92d.11bb
    Layer-2 MCast Groups Membership:
      All Level-2 ISs:      Yes
  IPv4 Unicast Topology:    Enabled
    Adjacency Formation:    Running
    Prefix Advertisement:   Running
    Metric (L1/L2):         0/10000000
    Weight (L1/L2):         0/0
    MPLS Max Label Stack:   3
    MPLS LDP Sync (L1/L2):  Disabled/Disabled
  IPv4 Address Family:      Enabled
    Protocol State:         Up
    Forwarding Address(es): 85.89.227.81
    Global Prefix(es):      85.89.227.80/28
  LSP transmit timer expires in 0 ms
  LSP transmission is idle
  Can send up to 9 back-to-back LSPs in the next 0 ms
RP/0/RSP0/CPU0:cg1.prv2#SH IM DAtabase int Bundle-Ether10.2085
Tue Apr 10 15:20:17.235 CEST
View: OWN - Owner, L3P - Local 3rd Party, G3P - Global 3rd Party, LDP - Local Data Plane
      GDP - Global Data Plane, RED - Redundancy, UL - UL
Node 0/RSP0/CPU0 (0x41)
Interface Bundle-Ether10.2085, ifh 0x08000160 (up, 9000)
  Interface flags:          0x00000000000205d7 (REPLICATED|IFINDEX
                            |SUP_NAMED_SUB|BROADCAST|VIRTUAL|CONFIG|VIS|DATA
                            |CONTROL)
  Encapsulation:            dot1q
  Interface type:           IFT_VLAN_SUBIF
  Control parent:           Bundle-Ether10
  Data parent:              Bundle-Ether10
  Views:                    UL|GDP|G3P|L3P|OWN
  Protocol        Caps (state, mtu)
  None            vlan_jump (up, 9000)
  None            dot1q (up, 9000)
  arp             arp (up, 8982)
  clns            clns (up, 8982)
  ipv4            ipv4 (up, 8982)
IOS
(c1r1.kis1.se) sescqrt01nt01fm#sh run int Port-channel10
Building configuration...
Current configuration : 119 bytes
 description  In SE
 mtu 9000
 no ip address
 load-interval 30
end
(c1r1.kis1.se) sescqrt01nt01fm#sh run int Po10.2085
Current configuration : 252 bytes
 description SE
 ip address 85.x.x.x 255.255.255.240
 no ip redirects
 no ip proxy-arp
 ip flow ingress
 ip router isis
end
(c1r1.kis1.se) sescqrt01nt01fm#sh isis neig
System Id      Type Interface   IP Address      State Holdtime Circuit Id
cg1.prv2       L2   Po10.2085   85.89.227.81    INIT  9        cg1.prv2.05
cg2.bal6       L2   Po10.2085   85.89.227.82    INIT  20       cg2.bal6.05
cp5.kis1       L2   Gi6/1       85.89.240.30    UP    29       sescqrt01nt01f.01
cp6.sol1       L2   Gi6/2       85.89.240.38    UP    28       sescqrt01nt01f.02
fiheqrt01nt00fmL2   Po10.2085   85.89.227.85    UP    23       fiheqrt02nt00f.04
fiheqrt02nt00fmL2   Po10.2085   85.89.227.86    UP    7        fiheqrt02nt00f.04
sescqrt02nt01fmL2   Po10.2085   85.89.227.84    UP    29       fiheqrt02nt00f.04
(c1r1.kis1.se) sescqrt01nt01fm#sh clns int Port-channel10.2085
Port-channel10.2085 is up, line protocol is up
  Checksums enabled, MTU 8997, Encapsulation SAP
  ERPDUs enabled, min. interval 10 msec.
  CLNS fast switching enabled
  CLNS SSE switching disabled
  DEC compatibility mode OFF for this interface
  Next ESH/ISH in 9 seconds
  Routing Protocol: IS-IS
    Circuit Type: level-1-2
    Interface number 0x2, local circuit ID 0x3
    Level-2 Metric: 10000000, Priority: 64, Circuit ID: fiheqrt02nt00f.04
    DR ID: fiheqrt02nt00f.04
    Level-2 IPv6 Metric: 10
    Number of active level-2 adjacencies: 3
    Next IS-IS LAN Level-2 Hello in 2 seconds
    No hello padding
04-10-2018 11:59 AM
It looks like you still have a MTU mismatch.
Could you please collect show ipv4 int from the XR, and a show ip int on the IOS device?
The MTU values should match, but the XR takes into account the 14 bytes IOS won't consider. So, if you have a MTU of 1500 in the IOS box, you should have 1514 in the XR, for example.
04-11-2018 04:57 AM
04-11-2018 06:01 AM
Hi Maria,
Now we can clearly see the MTU setting differs:
XR:
MTU is 9000 (8982 is available to IP)
clns clns (up, 8982) <<
IOS:
  Checksums enabled, MTU 8997 <<
How is the actual MTU configured in the IOS device? check it with a show ip int Port-channel10.2085, then tune it up until you see the same value on both ends.
Regarding this message, i have only seen those in loop scenarios (where a multicast sent by a router would come back in a different interface), but this is not related to adj establishment.
This message says that a system id of 2170.1001.6020 (which is our local ID) was seen in the hello packets, coming from the node with SNPA (typically the mac-address) of 78ba.f92d.11bb
Check the neighbor's SNPA with the command show clns neighbor.
04-11-2018 06:50 AM
04-11-2018 07:07 AM
Okay, so stepping back a little, you said that you need to have at most 9000 MTU in this L2, right?
Being so, you can go with the following:
XR
MTU 9014 - this would give us 9000 for both CLNS and IPv4
IOS
MTU 9003 - This, by default, would give an IP mtu of 9003 and 9000 for CLNS. You can also set IP mtu for 9000 and manually set the clns MTU if you want.
To understand better the log messages, a debug or packet capture would be the best way to move on.
04-11-2018 01:39 PM
Ok, I will need a window to do the tests and debugs. There is another link with issues which is also running ISIS so it might be disturbing the troubleshooting. I will post the results when I can do the tests.
Thank you very much for your help and time!
04-17-2018 06:31 AM
Hello Maria,
You are very welcome. Please let me know the results.
05-07-2018 05:34 AM
Hello Maria, how are you doing?
Do you can do this test? Because I'm with the same problem here....
Thks!
05-07-2018 09:48 AM
Hi there,
just today I was able to do the tests. The Duplicated ID message disappeared as soon the provider shut down one of the interfaces going to their devices which was part of our bundle. We have two interfaces in a bundle in the same devices (XR) going to two different Juniper devices at the providers end. So, this mean there was a loop at the provider ends.
And today, (with that link down still), I added "clns mtu 8982" to the subinterface po10.2085 in the IOS devices and the ISIS neighbors came up. So, we have "mtu 9000" in XR Bundle interface and "clsn mtu 8982" in the IOS subinterface. And ISIS is up!!
Hope this works for you as well!
