Telnet and SSH stopped working after configuring static NAT on router
djulien357
Hi everyone,
I am having weird problem with my edge routers .Everything was working perfectly before I configured NAT forwarding but  stopped allowing incoming telnet and ssh sessions from the internet the second  it was implemented . I have added an access-list allowing telnet and ssh to the interface facing the internet but no go , I turned on debug and tried telnetting to the router but for some reason the router is still not allowing the session even though an access-list is allowing telnet and ssh so therefore debug is not reporting anything being initiated . Anyone experienced a simailar problem like that before ?
16 Replies 16
cadet alain
did you NAT forward the telnet and ssh traffic  leaving the external port as default ? in which case can you modify your static PAT using another port as external port and tell us if it works after.
Alain
Hi Alain,
Thank you for the reply .Before posting my question  I did try doing a NAT forward to the inside interface using port 1022 and 1023 on the WAN interface (outside) forwarding to port 22 and 23 on the LAN interface (inside), I evenned try to forward it to a loopback interface as well  but no joy. That's why I decided to write the ACLs . Again this is a weird one.
could you post your sanitized config ?
Alain
I agree with Alain that it would help if we could see the config. In particular I am interested in how the address translation was set up and whether it uses an extended access list that permits something to any. I have seen situations where telnet and SSH access was impacted when address translation used an ACL that included the any parameter in the permit statement.
Rick
Rick
Ok guys,
Below is the config but I had to change the ip addresses for security purposes but this should still give you an idea on how the router is configured .
version 15.1
hostname XXX-RTR01-A
boot-start-marker
boot-end-marker
enable secret 5 $1$Dnm5$VdB8npWyjSfkt4zu/Xxgx.
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name xxxx.com
ip name-server 1.1.1.1
login block-for 180 attempts 4 within 60
login delay 5
login quiet-mode access-class telnet_access
no ipv6 cef
ip ssh version 2
user device admin privilege 15 secret @@@@@@@@@
voice-card 0
archive
log config
  hidekeys
vtp mode transparent
track 1 ip sla 1 reachability
class-map match-any voice
match protocol h323
policy-map voice
class voice
  set dscp ef
interface FastEthernet0/0
description uplink to Cbeyond Internet
ip address 163.215.76.181 255.255.255.240
ip nat outside
ip virtual-reassembly in
duplex full
speed auto
service-policy output voice
interface FastEthernet0/1
description uplink Charter Internet
ip address 204.108.10.69  255.255.255.248
ip nat outside
duplex full
speed auto
interface FastEthernet0/0/0
description Inside LAN
ip address 1.1.1.1  255.255.255.224
ip nat inside
ip policy route-map Miami
duplex full
speed auto
ip local policy route-map business_app_failover
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static udp 1.1.1.5 500 interface FastEthernet0/0 500
ip nat inside source static udp 1.1.1.5 4500 63.215.76.186 4500 extendable
ip nat inside source route-map cbeyond interface FastEthernet0/0 overload
ip nat inside source route-map charter interface FastEthernet0/1 overload
ip nat inside source static tcp 1.1.1.10 21 163.215.76.182 21 extendable
ip nat inside source static tcp 1.1.1.10 80 163.215.76.182 80 extendable
ip nat inside source static tcp 1.1.1.10 443 163.215.76.182 443 extendable
ip nat inside source static tcp 1.1.1.11 443 163.215.76.183 443 extendable
ip nat inside source static tcp 1.1.1.12 80 163.215.76.184 80 extendable
ip nat inside source static tcp 1.1.1.13 80 163.215.76.185 80 extendable
ip nat inside source static tcp 1.1.1.13 8000 163.215.76.185 8000 extendable
ip nat inside source static tcp 1.1.1.5 25 163.215.76.186 25 extendable
ip nat inside source static tcp 1.1.1.5 110 163.215.76.186 110 extendable
ip nat inside source static tcp 1.1.1.5 22 163.215.76.186 1022 extendable
ip nat inside source static tcp 1.1.1..5 10000 163.215.76.186 10000 extendable
ip nat inside source static tcp 1.1.1.16 80 163.215.76.188 80 extendable
ip nat inside source static tcp 1.1.1.16 443 163.215.76.188 443 extendable
ip nat inside source static tcp 1.1.1.17 443 163.215.76.189 443 extendable
ip route 0.0.0.0 0.0.0.0 163.215.76.81 track 1
ip route 0.0.0.0 0.0.0.0 204.108.10.69 20
ip access-list standard telnet_access
permit 1.1.1.5
permit 1.1.1.30
permit 216.7.100.92
ip access-list extended business-app
permit ip host 1.1.1.5 any
ip access-list extended router-f
permit ip any any
ip access-list extended users-traffic
permit ip host 1.1.1.30 any
ip sla 1
icmp-echo 8.8.8.8 source-interface FastEthernet0/0
threshold 2
ip sla schedule 1 life forever start-time now
logging esm config
access-list 110 permit ip 1.1.0.0 0.0.255.255 any
route-map Miami permit 10
match ip address business-app
set ip next-hop 163.215.76.181
route-map Miami permit 20
match ip address users-traffic
set ip next-hop 204.108.10.69
route-map Miami permit 30
route-map business_app_failover permit 10
match ip address router-f
set ip next-hop verify-availability 8.8.8.8 10 track 1
route-map cbeyond permit 10
match ip address 110
match interface FastEthernet0/0
route-map charter permit 10
match interface FastEthernet0/1
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
access-class telnet_access in
password 7 xxxxxxxxxxxxxxx
login
transport input all
scheduler allocate 20000 1000
ntp update-calendar
ntp server 98.175.203.200
end
Here is the access list that you are using for address translation
I suggest that you change it and make it a standard access list, perhaps
access-list 10 permit 1.0.0.0 0.0.255.255
and then change both route maps cbeyond and charter to match ip address 10.
Give it a try and let us know if it makes any difference.
Rick
Rick
I tried changing the access-list and update the route-map  as suggested but still no go . I am still unable to telnet or ssh to the device .
In taking another look at the config I notice that your access list telnet_access is permitting only 3 hosts (of which 2 appear to be inside and 1 appears to be outside). I wonder if this is part of your issue. As a way to investigate I suggest that you add a line to the access list so that it would look like this
permit 1.1.1.5
permit 1.1.1.30
permit 216.7.100.92
deny any log
I would also ask whether the problem is affecting telnet and ssh from sources inside the network or outside of the network or both?
And a copy of the updated config might be helpful.
Rick
Rick
Correct me if I am wrong the explicit deny in the access-list will deny anything else that do not match those 3 hosts in the
telnet_access list therefore adding deny any log will not make a difference . Those 3 hosts are the only one by design that should be able to access the router . They worked before without any problems but stopped working the second I configured the NAT forwarding statements.
Yes if those 3 hosts are intentionally the only hosts allowed telent or SSH access then adding the deny statement in the ACL would have no effect (other than to demonstrate if someone else did attempt access).
Does it make any difference in the problem whether the telnet/SSH request comes from inside the network or outside? Does it make any difference in the problem if the telnet/SSH request is to an outside facing interface or the inside facing interface?
Rick
Rick
Yes it does . I only want to allow telnet and ssh access to two workstations on the local network and to my remote home office just in case I have to access the router remotely (backdoor) in case of the firewalls behind those routers fail without having to use VPN. The access-class statement under the line vty should allow access either way. Thats why I said it was a weird problem.
Was this ever resolved?
We often have situations where route-maps are requires on 1-1 NAT translations to forward a range of specific ports to a certain local IP address. Please see below for an example of our configuration, IP addresses have been masked for security purposes.
ip nat inside source static 1.0.0.1 2.2.2.1 route RTP ext
access-list 131 permit udp host 1.0.0.1 any range 10020 10532
route-map RTP permit 10
 match ip address 131
In all instances where this is used we're unable to access the routers via telnet or SSH using the public interface (2.2.2.1) as soon as the route-map is applied.
Shaun
We've found a work around, creating specific NAT translations to an internal interface for the ports which need to be externally accessible on the Cisco, before we create the 1-1 NAT using a route-map resolves the issue.
could you try with this local PBR disabled like this :
no ip local policy route-map business_app_failover.
Alain
