Multi-Protocol BGP
ixholla69
With IPv6 Coming i've been tasked with implimenting M-BGP on our 7200VXR running 12.4 and was wondering if someone could point me to either a good reference to configuring this or possibly shooting me an example config.
Little to nothing is my expertise in this area of the BGP protocol so don't be shy.
Thank you!
2 Accepted Solutions
Great question! That command does NOT have any effect on BGP operation, it simply changes IPv4 global configuration style to address-family ipv4 configuration style. I highly recommend configuring that command. It will make configs cleaner.
Message was edited by: Roman Rodichev Added "NOT"
You can run IPv4 and IPv6 bgp routing in the same time, but for only one AS. You can bypass this limit by using vrf and local-as feature. Here is an exemple :
router bgp
no bgp default ipv4-unicast
neighbor remote-as
neighbor remote-as
address-family ipv4
     neighboor activate
address-family ipv6
     neighboor activate
The statement "no bgp default ipv4-unicast" is generally use to disable automatic peering with IPv4 neighboor (use in MPLS network with vpnv4 family section). But if you use this command, you have to activate all your neighboor before prefix exchange.
Like the precedent post, I recommend to use it.
I hope I can help you.
5 Replies 5
Just one thing that bothers me.......
Is there no way to run IPv4 and IPv6 together/parralel/simultaneously??
I have a very large IPv4 BGP network.
router bgp
neighbor remote-as
neighbor remote-as
address-family ipv4
     neighboor activate
address-family ipv6
     neighboor activate
Awesome, thanks guys.... that puts me more at ease lol.
