MULTICAST issue
annirajput
Can any one tell me how I can disable fast switching on ISR4331-DC/K9.
I am facing issue multicast packets dropped
(10.71.6.246, 239.255.255.253), 00:02:03/00:00:56, flags: T
Incoming interface: Vlan100, RPF nbr 10.70.126.1
Outgoing interface list:
GigabitEthernet0/0/0, Forward/Dense, 00:02:03/stopped
GigabitEthernet0/0/1, Forward/Dense, 00:02:03/stopped
Vlan700, Prune/Dense, 00:02:03/00:00:56
18 Replies 18
johnd2310
Level 8
Level 8
Can you provide more details. What issues are you having with multicast? What is you multicast configuration?
**Please rate posts you find helpful**
annirajput
ip multicast-routing distributed
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim query-interval 1
ip pim dense-mode
ip authentication mode eigrp 70 md5
ip authentication key-chain eigrp 70 RIDEII
no ip mfib cef input
ip pgm router
ip access-group 161 in
standby 1 ip 10.70.101.1
standby 1 priority 110
standby 1 preempt
ip igmp version 3
media-type rj45
negotiation auto
annirajput
interface GigabitEthernet0/0/1
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim dense-mode
ip pgm router
standby 1 preempt
ip igmp version 3
media-type rj45
negotiation auto
What\where is the multicast source and receiver? what happens with the multicast traffic? Does it start flowing and stops or does it not start at all?
thanks
annirajput
Hi I have changed router Cisco 2851 to cisco ISR4331-DC/K9 and on new router only ip multicast-routing distributed available and fast switching enable but on old router  ip multicast-routing only with process switching.
now on new router multicast packet discarded
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Default
26 routes, 11 (*,G)s, 2 (*,G/m)s
Group: 224.0.0.0/4
RP-tree,
SW Forwarding: 0/0/0/0, Other: 0/0/0
HW Forwarding: 0/0/0/0, Other: 5/5/0
Group: 224.0.1.40
RP-tree,
HW Forwarding: 0/0/0/0, Other: 0/0/0
Group: 239.253.0.61
RP-tree,
Group: 239.253.0.62
RP-tree,
Group: 239.253.0.63
RP-tree,
Source: 10.70.6.32,
SW Forwarding: 245/0/70/0, Other: 33/33/0
HW Forwarding: 50/0/390/0, Other: 7/7/0
Totals - Source count: 1, Packet count: 295
Group: 239.255.255.250
RP-tree,
HW Forwarding: 0/0/0/0, Other: 101/101/0
Source: 10.70.6.5,
Source: 10.70.6.7,
Source: 10.70.6.8,
Source: 10.70.6.31,
SW Forwarding: 0/0/0/0, Other: 1/0/1
HW Forwarding: 4/0/385/0, Other: 12/12/0
Source: 10.70.6.33,
HW Forwarding: 4/0/385/0, Other: 10/10/0
Source: 10.70.6.35,
Source: 10.70.6.37,
Source: 10.70.6.95,
Source: 10.70.6.196,
Source: 10.70.6.198,
Source: 10.71.6.196,
Source: 10.71.6.246,
Totals - Source count: 12, Packet count: 8
Group: 239.255.255.253
RP-tree,
Groups: 6, 2.16 average sources per group
How I can disabled fast switching ?. below commands not taken
no ip route-cache cef
no ip route-cache
no ip mroute-cache
Can you draw a diagram of your multicast setup. Where is the source and where is the receiver? Do you have switches connected to the router?
Hello
Not surprised as you are running pim-dense mcast, this will flood your whole network and then slowly prune unwarranted pim interfaces with no mc receivers, plus the fact if you don't have igmp snooping enabled on the switches  mc traffic will be hitting every access port on the switch's in relation to each broadcast domain(vlan)  you have pim enabled for
Incoming interface: Vlan100, RPF nbr 10.70.126.1  <---- MC coiming in from vla 700 via  10.70.126.1
Vlan700, Prune/Dense, 00:02:03/00:00:56  <---- prune has been received from vlan 700
Can you do the following and post the results:
mtrace 10.70.126.1
sh ip rpf 10.70.126.1
sh ip route 10.70.126.1
Kind Regards
Paul
HI,
I replaced cisco 2851 to cisco 4331 . there is no issue with old router but on new router  Multicast routing: enabled
Multicast switching: fast
Multicast packets in/out: 136238/266471
Multicast TTL threshold: 0
Multicast Tagswitching: disabled
and old router
Multicast switching: process
Multicast packets in/out: 146673/115602
below commands are missing on new router when i am trying to put these command then new router not accepting
no ip route-cache
no ip mroute-cache
Routing entry for 10.70.126.0/30
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 70
Routing Descriptor Blocks:
* directly connected, via Vlan100
Route metric is 0, traffic share count is 1
mtrace 10.70.126.1
Mtrace from 10.70.126.1 to 10.70.126.2 via RPF
From source (?) to destination (?)
Querying full reverse path...
0 10.70.126.2
-1 10.70.126.2 ==> 10.70.126.2 PIM_MT [10.70.126.0/30]
-2 10.70.126.1
sho ip rpf 10.70.126.1
RPF information for ? (10.70.126.1)
RPF interface: Vlan100
RPF neighbor: ? (10.70.126.1) - directly connected
RPF route/mask: 10.70.126.0/30
RPF type: multicast (connected)
Doing distance-preferred lookups across tables
RPF topology: ipv4 multicast base
Hello
So the RPF and unicast routing have parity ,  and it looks like you have an active host on vlan 700, as you are receiving  a prune and expecting the next join/prune message in 56 secs
GigabitEthernet0/0/0 - 1  also seem to have any downstream activity.
What exactly your issue with your Multicast?
if you wish to disable fast switching for multicast then the command should be:
inx/x
no ip mroute-cache
Kind Regards
Paul
no ip mroute-cache this command not running on ISR 4331
I think command is inx/x
ip multicast process-switching  and one more thing router lan facing interface not join multicast group may be this is the issue.
interconnect interface joined multicast group
GigabitEthernet0/0/1 is up, line protocol is up >> this is LAN facing interface
  Internet address is 10.70.101.4/24
  IGMP is enabled on interface
  Current IGMP host version is 3
  Current IGMP router version is 3
  IGMP query interval is 60 seconds
  IGMP configured query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP configured querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 920 joins, 915 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 10.70.101.4 (this system)
  IGMP querying router is 10.70.101.3
  No multicast groups joined by this system
GigabitEthernet0/0/0 is up, line protocol is up >>> this interface is interconnect with 2nd router
  Internet address is 10.70.100.1/26
  IGMP activity: 3 joins, 2 leaves
  Multicast designated router (DR) is 10.70.100.2
  IGMP querying router is 10.70.100.1 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)
Hello
      224.0.1.40(1)
I can see igmp joins on those interfaces, but not specific mc group which suggests those interface are not requesting mc traffic any more
On thier  directly connected upstrean pim neigbours can you show the mroute table and check for specific (S,G) entries i doubt you will see any?
Kind Regards
Paul
Hello
@annirajput wrote:
(*, 239.253.0.62), 1d00h/00:02:06, RP 0.0.0.0, flags: D
Incoming interface: Null, RPF nbr 0.0.0.0
Vlan700, Forward/Dense, 1d00h/stopped
Vlan100, Forward/Dense, 1d00h/stopped
GigabitEthernet0/0/1, Forward/Dense, 1d00h/stopped
GigabitEthernet0/0/0, Forward/Dense, 1d00h/stopped
(10.70.6.32, 239.253.0.63), 1d02h/00:01:16, flags: T
GigabitEthernet0/0/0, Prune/Dense, 14:00:22/00:02:58, A
GigabitEthernet0/0/1, Forward/Dense, 1d02h/stopped, A
Vlan700, Prune/Dense, 1d02h/00:02:58
You can see from this output MC changed to a source tree but states it has NO group members to connect to, so it seems as  stated previously no hosts for this group are interested.
Also assert flags are set, are those two interfaces sharing local subnets, Lasty do you just have dense mode and not sparse-dense mode enabled?
Kind Regards
Paul
