MULTICAST issue
annirajput
Can any one tell me how I can disable fast switching on ISR4331-DC/K9.
I am facing issue multicast packets dropped
(10.71.6.246, 239.255.255.253), 00:02:03/00:00:56, flags: T
Incoming interface: Vlan100, RPF nbr 10.70.126.1
Outgoing interface list:
GigabitEthernet0/0/0, Forward/Dense, 00:02:03/stopped
GigabitEthernet0/0/1, Forward/Dense, 00:02:03/stopped
Vlan700, Prune/Dense, 00:02:03/00:00:56
18 Replies 18
annirajput
yes dense mode enabled
Hello
Check your receiving hosts, make sure there are open to receive MC if so , test the routing path from MC receiver to MC source, do you have reachability
Also on the HSRP group for the rtrs which participate in MC pim, you could manually set the DR for the
subnet, if priority’s are the same (defaults set to 1) highest ip address wins election
primary
atandby 1 ip 10.70.101.1
standby 1 priority 110
standby 1 name DATA1
ip pim redundancy DATA1 dr-priority priority 255
secondary
standby 1 ip 10.70.101.x
standby 1 priority <lower than 110>
Scratch the above, just realised your using igmpv3-apologies
Kind Regards
Paul
did you checked below output
Lan interface is gi/o/o/1 but not joined igmp group
interconnect interface joined multicast group
GigabitEthernet0/0/1 is up, line protocol is up >> this is LAN facing interface
  Internet address is 10.70.101.4/24
  IGMP is enabled on interface
  Current IGMP host version is 3
  Current IGMP router version is 3
  IGMP query interval is 60 seconds
  IGMP configured query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP configured querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 920 joins, 915 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 10.70.101.4 (this system)
  IGMP querying router is 10.70.101.3
  No multicast groups joined by this system
GigabitEthernet0/0/0 is up, line protocol is up >>> this interface is interconnect with 2nd router
  Internet address is 10.70.100.1/26
  IGMP activity: 3 joins, 2 leaves
  Multicast designated router (DR) is 10.70.100.2
  IGMP querying router is 10.70.100.1 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)
Hello
Yes i have, which suggest those interfaces have stop receiving any membership request for any MC group.
Do you have a topology of your network.
Kind Regards
Paul
