Multicast issues
JohnPepBoy
We are having Muslticast issues with some routers and switches, we attempt to muslticast group 224.0.1.90 and the server on switch a or switch b will receive it but not both.
Router Configuration
sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report,
       Z - Multicast Tunnel, z - MDT-data group sender,
       Y - Joined MDT-data group, y - Sending to MDT-data group,
       V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.255.255.253), 00:16:01/00:01:59, RP 172.21.12.67, flags: SP
Incoming interface: Serial0/3/0.1, RPF nbr 10.33.7.230
Outgoing interface list: Null
(*, 239.255.255.250), 00:14:54/00:01:00, RP 172.21.12.67, flags: SJC
   BVI3, Forward/Sparse-Dense, 00:02:00/00:01:00
   BVI1, Forward/Sparse-Dense, 00:02:58/00:00:01
(*, 224.1.2.3), 00:08:06/00:00:50, RP 172.21.12.67, flags: SP
(*, 224.0.1.22), 1w5d/00:02:58, RP 172.21.12.67, flags: SJC
   BVI3, Forward/Sparse-Dense, 10:40:26/00:02:58
(*, 224.0.1.55), 00:29:45/00:01:12, RP 172.21.12.67, flags: SJC
   BVI3, Forward/Sparse-Dense, 00:01:47/00:01:12
(*, 224.0.1.39), 15w5d/stopped, RP 0.0.0.0, flags: D
Incoming interface: Null, RPF nbr 0.0.0.0
   Serial0/3/0.1, Forward/Sparse-Dense, 15w5d/00:00:00
(172.21.12.66, 224.0.1.39), 00:00:39/00:02:20, flags: PT
(*, 224.0.1.40), 15w5d/stopped, RP 0.0.0.0, flags: DCL
   BVI1, Forward/Sparse-Dense, 15w5d/00:00:00
(172.21.12.66, 224.0.1.40), 2w6d/00:02:51, flags: LT
   BVI1, Forward/Sparse-Dense, 2w6d/00:00:00
(172.21.13.2, 224.0.1.40), 2w6d/00:02:51, flags: LT
(172.21.200.51, 224.0.1.40), 2w6d/00:02:51, flags: LT
(172.21.12.67, 224.0.1.40), 2w6d/00:02:11, flags: LT
(172.21.13.3, 224.0.1.40), 2w6d/00:02:11, flags: LT
(172.21.200.52, 224.0.1.40), 15w5d/00:02:11, flags: LT
(*, 224.0.1.92), 00:16:01/00:01:58, RP 172.21.12.67, flags: SP
(*, 224.0.1.88), 01:04:55/stopped, RP 172.21.12.67, flags: SJC
   BVI1, Forward/Sparse-Dense, 00:01:01/00:01:58
(172.21.12.76, 224.0.1.88), 00:16:45/00:00:40, flags: JT
   BVI1, Forward/Sparse-Dense, 00:01:02/00:01:58
(*, 224.0.1.91), 00:29:56/00:00:57, RP 172.21.12.67, flags: SJC
   BVI3, Forward/Sparse-Dense, 00:02:02/00:00:57
(*, 224.0.1.90), 00:28:02/00:02:58, RP 172.21.12.67, flags: SJC
   BVI3, Forward/Sparse-Dense, 00:00:01/00:02:58
interface BVI1
ip pim sparse-dense-mode
end
interface BVI3
end
interface Serial0/3/0.1 point-to-point
end
sh run | in pim
ip pim autorp listener
show ip pim rp mapping
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
RP 172.21.12.67 (--OMITTED--), v2v1
   Info source: 172.21.12.67 (--OMITTED--), elected via Auto-RP
         Uptime: 2w6d, expires: 00:02:33
sh ip igmp groups
Group Address   Interface             Uptime    Expires   Last Reporter   Group
239.255.255.250 BVI3                     00:00:59 00:02:00 10.1.180.239
239.255.255.250 BVI1                     00:01:56 00:01:03 10.1.180.43
224.0.1.22            BVI1                     00:03:00 now         10.1.180.6
224.0.1.22            BVI3                     09:31:25 00:02:58 10.1.180.243
224.0.1.55            BVI3                     00:01:49 00:01:10 10.1.180.235
224.0.1.40           BVI1                     2y22w     00:02:08 10.1.180.1
224.0.1.92            BVI3                     00:02:56 00:00:03 10.1.180.133
224.0.1.91            BVI3                     00:01:00 00:01:59 10.1.180.134
224.0.1.90            BVI3                     00:02:58 00:00:01 10.1.180.133
You can see from the above that 224.0.1.90 is about to expire.
sh ip igmp groups
239.255.255.250 BVI3                     00:01:01 00:01:58 10.1.180.239
239.255.255.250 BVI1                    00:01:58 00:01:01 10.1.180.43
224.0.1.22            BVI3                     09:31:27 00:02:57 10.1.180.243
224.0.1.55            BVI3                     00:01:51 00:01:08 10.1.180.235
224.0.1.40            BVI1                     2y22w     00:02:06 10.1.180.1
224.0.1.92            BVI3                     00:02:58 00:00:01 10.1.180.133
224.0.1.91            BVI3                     00:01:01 00:01:58 10.1.180.134
You can see from the above that 224.0.1.90 is no longer on the list; it will remain off the list until 224.0.1.55 expires than it will re establish the connection.
sh ip igmp groups
239.255.255.250 BVI3                     00:01:05 00:01:54 10.1.180.239
239.255.255.250 BVI1                     00:02:03 00:00:56 10.1.180.43
224.0.1.22            BVI3                     09:31:32 00:02:52 10.1.180.243
224.0.1.55            BVI3                     00:01:56 00:01:03 10.1.180.235
224.0.1.40            BVI1                    2y22w     00:02:59 10.1.180.1
224.0.1.91            BVI3                     00:01:06 00:01:53 10.1.180.134
You can see from the above that 224.0.1.92 is no longer on the list; we think it may have something to do with 239.255.255.253
sh ip igmp groups
239.255.255.253 BVI3                     00:00:03 00:02:56 10.1.180.140
239.255.255.250 BVI3                     00:02:01 00:00:58 10.1.180.239
239.255.255.250 BVI1                     00:02:58 00:00:01 10.1.180.43
224.0.1.22            BVI3                     09:36:27 00:02:58 10.1.180.243
224.0.1.55            BVI3                     00:02:56 00:00:03 10.1.180.235
224.0.1.40            BVI1                    2y22w     00:02:04 10.1.180.1
224.0.1.92            BVI3                     00:00:00 00:02:59 10.1.180.133
224.0.1.88            BVI1                     00:00:55 00:02:04 10.1.180.2
224.0.1.91            BVI3                     00:02:02 00:00:57 10.1.180.134
You can see from the above that 224.0.1.55 is about to expire and 239.255.255.253 came back also 224.0.1.92 is back on the out put
sh ip igmp groups
239.255.255.253 BVI3                     00:00:04 00:02:55 10.1.180.140
239.255.255.250 BVI3                     00:02:02 00:00:57 10.1.180.239
239.255.255.250 BVI1                     00:02:59 00:00:00 10.1.180.43
224.0.1.22            BVI3                    09:36:29 00:02:57 10.1.180.243
224.0.1.55            BVI3                     00:02:57 00:00:02 10.1.180.235
224.0.1.92            BVI3                     00:00:01 00:02:58 10.1.180.133
224.0.1.88            BVI1                     00:00:56 00:02:03 10.1.180.2
224.0.1.91            BVI3                     00:02:03 00:00:56 10.1.180.134
224.0.1.90            BVI3                     00:00:00 00:02:59 10.1.180.133
You can see from the above that 224.0.1.55 timer is back and all Multicast IP’s are back online however we can not Multicast to the switches that the servers are sitting on.
Switch A Configuration
show arp (From Router)
Internet XXXXXXXXX           0   000c.297f.569c ARPA   BVI3
Internet XXXXXXXXX           1   000c.29fe.f81e ARPA   BVI3
sh mac address-table | in 000c.297f.569c
999   000c.297f.569c   DYNAMIC     Po1 ••ß this is on Switch B
sh mac address-table | in 000c.29fe.f81e
999   000c.29fe.f81e   DYNAMIC     Fa0/15
sh ip igmp filter
IGMP filter enabled
sh ip igmp snooping querier
Vlan     IP Address     IGMP Version       Port
997       10.1.180.1      v2                 Switch
999       10.1.180.129   v2                 Switch
sh ip igmp snooping group
Vlan     Group         Version     Port List
997       224.0.1.22                 Po1
997       224.0.1.88                 Fa0/15
999       224.0.1.22                 Po1
999       224.0.1.55                 Fa0/3
999       224.0.1.90                 Po1
999       224.0.1.91                 Po1
999       224.0.1.92                 Po1
999      239.255.255.250       Fa0/4
999      239.255.255.253       Po1
sh ip igmp snooping mrouter
Vlan   ports
997   Fa0/1(dynamic)
999   Fa0/1(dynamic)
sh ip igmp snooping vlan 999
Global IGMP Snooping configuration:
IGMP snooping             : Enabled
IGMPv3 snooping (minimal) : Enabled
Report suppression         : Enabled
TCN solicit query         : Disabled
TCN flood query count     : 2
Last member query interval : 1000
Vlan 999:
Immediate leave                     : Disabled
Multicast router learning mode     : pim-dvmrp
Source only learning age timer     : 10
CGMP interoperability mode         : IGMP_ONLY
sh ip igmp snooping vlan 997
Vlan 997:
Switch B Configuration
999   000c.297f.569c   DYNAMIC     Fa0/15
999   000c.29fe.f81e   DYNAMIC     Po1 ••ß this is on Switch A
sh ip igmp filter
IGMP filter enabled
997       224.0.1.22     v2         Fa0/4
999       224.0.1.22     v2         Fa0/13, Fa0/17, Po1
999       224.0.1.90     v2         Fa0/15
999       224.0.1.91     v2         Fa0/15
999       224.0.1.92     v2         Fa0/15
999      239.255.255.253         Fa0/15
Vlan   ports
997   Po1(dynamic)
999   Po1(dynamic)
Vlan 999:
Vlan 997:
Hello, John.
Could you please draw the diagram of device (including multicast source, destination, RP, MA) interconnection. Please add to the diagrams all the IP-addresses we could see over "sh ip mroute" and "sh ip pim rp map".
Sorry, I didn't understand the problem. What is not working?
You wrote: "... however we can not Multicast to the switches that the servers are sitting on", but I thought server is supposed to be a multicast source... not the destination!
Servers are sitting on Switch A and Switch B on ports fa0/15; we need to send the multicast to both servers using 224.0.1.90 but only Switch A will receive the multicast. My biggest concern is why the Uptime is not incrementing on the sh ip igmp groups, the servers that are working on both Switches A and B the Uptime is incrementing, which is on another router example:
Group Address   Interface               Uptime   Expires   Last Reporter   Group Accounted
239.255.255.253 BVI3                     14w1d     00:02:41 10.0.219.140
239.255.255.250 BVI3                     2d22h     00:02:37 10.0.219.239
239.255.255.250 BVI1                     2w5d     00:02:28 10.0.219.53
224.0.1.22       BVI1                     14w1d     00:02:22 10.0.219.6
224.0.1.22       BVI3                     14w1d     00:02:38 10.0.219.240
224.0.1.55       BVI3                     5d06h     00:02:44 10.0.219.237
224.0.1.40       BVI1                     11w6d     00:02:23 10.0.219.1
224.0.1.92       BVI3                     14w1d     00:02:39 10.0.219.133
224.0.1.88       BVI1                     3d13h     00:02:29 10.0.219.2
224.0.1.91       BVI3                     14w1d     00:02:37 10.0.219.134
224.0.1.90       BVI3                     14w1d     00:02:40 10.0.219.134
Here is the network you requested
