Influence route in OSPF intra-area
OMAR CANDARAVE
Hi all,
I would like to know if it is possible to influence the traffic for a network to take one next hop if I have 2 routes with the same cost in OSPF? in a BMA environment.
R10#sh ip route  1.1.1.1
Routing entry for 1.1.1.1/32
  Known via "ospf 1", distance 110, metric 21, type intra area
  Last update from 10.10.10.2 on FastEthernet0/0, 00:40:09 ago
  Routing Descriptor Blocks:
  * 10.10.10.3, from 1.1.1.1, 00:40:09 ago, via FastEthernet0/0
      Route metric is 21, traffic share count is 1
    10.10.10.2, from 1.1.1.1, 00:40:09 ago, via FastEthernet0/0
I want to send the traffic to 1.1.1.1 through 10.10.10.2 and keep 10.10.10.3 as a backup.
They are Intra Area routes and both neighbors are learned by the same interface BMA.
R10#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
20.20.20.2        1   FULL/BDR        00:00:32    10.10.10.2      FastEthernet0/0
30.30.30.2        1   FULL/DR         00:00:38    10.10.10.3      FastEthernet0/0
I tried to change the metric with distrubute and a route map but no luck
any ideas?
Please  let me know if you need more details.
Hi Omar,
you could change the network type to "point-to-multipoint non-broadcast".
A very interesting option especially for this type is that you can assign cost on a per-neighbor basis on a multiaccess interface:
(config-rtr)# neighbor [cost <1-65535>]
Optionally, you may want to change the timers (default: 30/120s).
Compared to Broadcast network type, Point-to-Multipoint Non-Broadcast
  • sends unicast hellos to every neighbor
  • transmits more OSPF traffic (no DR)
  • is less efficient in LSBD representation
  • installs host-routes for every router (for the spoke's reachability in frame-relay hub & spoke topologies)
However, if you have only 3-4 routers in the subnet, the advantages of Broadcast over Point-to-Multipoint shouldn't keep you from using that network type if you want to be able to influence the forwarding paths in a multiaccess network. I've already done this in production networks to overcome undesired adjacencies in a VPLS and implement backup-paths as well.
Rolf
7 Replies 7
CSCO11508096
increase the cost of the connected neighbour router interface, at which IP 10.10.10.3 is configured using (ip ospf cost "value") at interface configuration mode.
Shashi
Hi Omar,
Rolf
Thank you Rolf your solution worked for me to influce a path for an especific neighbor as next hop.
Thank you ALL I appreciate your comments
daniel.dib
Level 7
Level 7
Change the cost. Draw a topology and provide more information if you want a more detailed answer. Remember that cost is calculated inbound.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Besides Rolf's solution, another option might be to adjust interface cost, or interface costs, on one of either of the two adjacent (common network) routers.  As OSPF intra-area costs are cumulative, this make the two paths costs unequal.
waqas younas
just change the cost and you are done one path will be backup and one active
if you want exact point where to give cost share your diagram
Regards Waqas Younas CCIEx2 #27815 (Routing and Switching) (Service Provider) Contact for Online Training
OMAR CANDARAVE
