12-09-2012 12:53 AM - edited 03-04-2019 06:21 PM
Hi Guys;
I have a cisco 2811 with:
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(3d), RELEASE SOFTWARE (fc3)
I have one of its ports (fa0/1) configured as:
interface FastEthernet0/1
no ip address
duplex auto
speed auto
end
and ...
interface FastEthernet0/1.101
encapsulation dot1Q 101
ip address 10.26.21.2 255.255.255.0
ip pim query-interval 1
ip pim sparse-dense-mode
ip igmp version 3
end
This port is connected to a laptop, on a gigabit ethernet port. That lap top port is configuured as
10.26.21.3 255.255.255.0
with default gateway as:
The reason for doing that is that the laptop is a multicast source. My trouble is that this interface (fa0/1 and hence fa0/1.101) on 2811 is coming up. It is in up down state.
Can somebody tell me what should i do? if i just use fa0/1 and not create a sub interface, it still does not work/come up.
reagdrs
Solved! Go to Solution.
12-09-2012 06:53 AM
On the router, you have configured the router with dot1Q. The PC doesn't understand dot1Q.
Delete the sub-interface and change your config to this and try again:
duplex auto
speed auto
end
12-09-2012 05:22 AM
Am I asuming right that the line protocol is down?. If so, it is not related to L3 configuration or multicats being enabled. I would check the speed/duplex settings.
What is your laptop speed?. Is it 100 Mbps (fastethernet) or 1 Gbps (gigabitethernet0?. If the laptop is defaulting to Gbps, can you try setting to 100 Mbps?. Also try setting the duplex as full on the route rside and see if it helps.
HTH,
Nagendra
12-09-2012 06:53 AM
duplex auto
speed auto
end
12-09-2012 05:31 PM
thanks alot guys, its working.
12-09-2012 07:14 PM
what was the issue?
12-10-2012 06:48 AM
removed encapsulation from the sub interfcae and the subinterface itself.
thanks,
12-10-2012 06:53 AM
Can you please rate the post and mark it as answered, so others can benefit from it?
12-10-2012 12:46 PM
sure thanks.
