Multicast RP's in different AS across an MPLS WAN
fsebera
Level 4
Level 4
Hi all, It appears Multicast redundancy is a little more challenging than expected.
If the primary rendezvous point (RP) is configured on the CE of a CE-PE BGP peering MPLS cloud,
can the redundant RP be located across the MPLS cloud in a different AS on the CE of the same MPLS cloud.
(all customer prefixes are known at every point in the WAN)?
[RP(CE)_AS100]-----PE__MPLS_(AS200)__cloud__PE------[CE(RP)_AS300]
Customer__A--------|---------MPLS------------|-------Customer__A
THANKS!!!!
Frank
2 Accepted Solutions
Hello Frank,
Alright, so now I understand better, I hope - you are saying that the MPLS cloud itself is capable of carrying the multicast traffic, it is just your CE-based BGP configuration that is not using multicast address family, right?
In any case, adding the multicast address family to BGP is not the solution here in my opinion. You have indicated that you are using "anycast" - I assume you are referring the Anycast-RP.
What probably happens is that the Anycast-RP is not deployed properly, effectively segmenting your entire network into regions, each of them using its own closest RP, without the RPs actually informing themselves about the multicast sources located in their "catchment area".
Here, you will definitely need to use the MSDP to peer your candidate RP's together. Are you familiar with the following document? Please check it and let me know. Just for the sake of MSDP configuration, you will need to use the ip msdp default peer instead of ip msdp peer - as you are not going to use BGP for multicast source information dissemination, and MSDP otherwise likes to use that for RPF checks.
http://www.cisco.com/en/US/docs/ios/solutions_docs/ip_multicast/White_papers/anycast.html
As far as how do I plan on implementing the RP and the redundant RP, are you looking for the actual configs?
Yes, seeing the configs would definitely be helpful.
Thank you!
Best regards,
Peter
Hello Frank,
You are very much welcome - but I honestly believe that you've found the solution yourself, I wasn't that much of a help.
Is Bidir-PIM and Phantom-RP compatible with MSDP?
The fun with Bidir-PIM is that the RP is not a device or a function - but merely a direction of multicast flow to reach the so-called RP Link which is a network segment where the RP address sits from the IP routing point of view. However, this IP address does not need to be truly assigned to any device because this device is not performing any special task whatsoever, as opposed to the RP function in PIM-SM. This follows from the different notion of data flow in a Bidir-PIM constructed multicast distribution tree: multicast traffic can flow both up and down all branches of a single distribution tree, thereby creating a true single shared tree for an arbitrary number of senders.
This all in turn means that if there is no real device with the function of RP, there is nothing to do here with MSDP
Because the Anycast-RP is built around the notion of having multiple RPs work in parallel (and thereby back up each other), it not really applicable to Bidir-PIM. In addition, it is probably not a good idea to provide redundancy in Bidir-PIM by advertising the same IP address from multiple routers because that will lead to differently rooted distribution trees and possible issues in multicast stream delivery. The solution here appears to be what Cisco calls Phantom-RP with different netmasks which is nicely described in this document:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6552/ps6592/prod_white_paper0900aecd80310db2.pdf
So to sum it up, Anycast-RP using the same IP address and netmask advertised from multiple routers is not an option for Bidir-PIM. The Phantom-RP, on the other hand, is exactly the solution suggested for Bidir-PIM.
Best regards,
Peter
15 Replies 15
Peter Paluch
Frank,
Technically, there should be no problem in configuring your RPs as you suggest. The question, however, is whether the MPLS cloud connecting your two sites is capable of natively carrying multicast streams. I assume you are using MPLS L3 VPN that interconnects your sites.
Also, how do you actually propose to configure a backup RP? Technically, there is only a single RP for a particular multicast group. There are applications of MSDP to provide for so-called AnycastRP, or you could use the BSR or AutoRP (yuck! ) to dynamically select an RP from a number of RP candidates.
Best regards,
Peter
Peter,
You assumption is correct, we use MPLS L3 VPNs with eMBGP peering for IPv4/IPv6 UNICAST only.
We have 2 different multicast applications in use.
One-to-Many, typical video stream out to receivers
Many-to-Many, VTC conference style application where all talk and listen simultaneously (big party)
We currently don't have MBGP address-family ipv4 multicast enabled, perhaps this is one of our issues.
MSDP is not implemented and I think MSDP CE-PE peering is required to sync the RPs across MPLS cloud. --RIGHT?
The MPLS cloud is private AS 65000 while the remote sites are all different private ASNs.
The MPLS cloud is setup with MDT Default 239.232.0.0 and 239.233.0.0 dynamic multipoint GRE tunnels to support our true hub and spoke environment.
Here's a sniblet of the PE1 router
sh derived-config
vrf defininition HQE
rd 10:1
address-familt ipv4
mdt default 239.232.0.0
route-target export 10:10
exit-adress-family
address-family ipv6
vrf definition HQI
rd 10:0
address-family ipv4
mdt default 239.233.0.0
route-target import 30:30
route-target import 40:40
route-target import 20:20
exit-adress-family
--snip--
interface Tunnel0
ip unnumbered Loop0
tunnel source Loopback0
tunnel mode gre multipoint
no routing dynamic
interface tunnel1
ip unnumbered f0/0.10
tunnel source f0/0.10
tunnel destination 172.31.255.254
tunnel tos 192
tunnel vrf HQI
no routing dynamic
etc
etc
etc
All data traffic flows as expected and all prefixes from remote CE peers can be found at each CE router.
Thanks for assisting! Frank
Hello Frank,
I have quite a couple of observations/questions. I apologize if some of them are outright dumb - I need to understand the environment in which you operate. Please bear with me here.
  • Who has the control over the MPLS cloud? Is it your cloud or ISP's cloud?
  • Why is there a MVRF configuration present on the PE1 router (MDT definition in the VRFs) if according to your information, the MPLS cloud supports unicast routing only?
  • Why do you have Tunnel interfaces if you are using MVRF configuration?
  • If you tunnel your multicast traffic via Tunnel interfaces, have you statically modified the multicast routing table using the ip mroute command to allow the RPF check to work correctly?
  • Once again, how exactly do you plan to implement the idea of primary and backup RP?
Best regards,
Peter
Peter,
The telecom controls their PE routers but provide configurations to us.
The MPLS cloud supports multicast; IP pim sparse-mode is configured on all the revelent CE interfaces and BGP peering is only configured for UNICAST routing.
router bgp 65010
no sync
address-family ipv4 unicast
neighbor 172.16.10.2 remote-as 65000
address-family ipv6 unicast
neighbor 172:16:10::2 remote-as 65000
One HQ CE router is the RP and mapping agent for the entire network (300 remote sites).
When attempting to configure a second router -an MPLS remote site- CE router as a redundant RP and mapping agent, multicast fails.
When a single RP is enabled, multicast flows to all receivers and all functions just fine, but when a second RP is configured, multicast no longer makes it to many remote sites. Removing the 2nd RP config and all works well again.
I was thinking the CE-PE BGP peering configurations should include BGP address-family ipv4 multicast; peering between CE-PE along with MSDP  which would be used to sync both RPs. What do you think?
We use anycast with auto-rp to enable dynamic RPs.
Thanks again for your help
Frank
Also, no static mroutes are configured, multicast uses the MDT default within the MPLS cloud.
Frank
Hello Frank,
Thank you!
Best regards,
Peter
Hey Peter,
OK, . . . now we are enjoying multicast much more!!!
As you indicated, MSDP is the solution here for this setup. The problem I was running into with my previous configurations -- I was sourcing from the wrong local address on the RP/MSDP peering WAN CE routers.
NOW, videos are being sourced and received just fine and to verify redundancy, I manually shut down the primary RP loopback address [(since there is no redundant link to the cloud as Mohamed pointed out (I didn't include to much detail as it would get very confusing very quickly), there is redundancy but that is through a different MPLS cloud] -killing the primary RP--, forcing the redundant RP to start new sessions. I then attempted to start a new video sessions (receivers) at several remote sites. Works like a champ!!
One questions though - my video setup is One-to-Many, using PIM sparse-mode, Anycast-RP, Auto-RP and now correctly running MSDP peering to educate the other down stream RPs of the active sources.  My other multicast applications is Many-to-Many using Bidir-PIM sparse-mode, Auto-RP and Phantom-RP. All configured on the same two routers at this point. While I understand there is no load sharing or load balancing with Bidir-PIM and all active many-to-many data streams always run though one RP for the duration of the session (unless the primary RP fails), with the correctly configured MSDP peering - my many-to-many applications is operating just fine as well. Oh sorry, here is my question - Is Bidir-PIM and Phantom-RP compatible with MSDP?
As far as the configs go, what would you like to see?
THANKS SO MUCH!!!
Frank
Hello Frank,
Best regards,
Peter
Hey Peter,
Here is WAN1s' full config.
Comments welcome.
Thanks again for your assistance.
Frank
WAN1#sh run
Building configuration...
Current configuration : 11979 bytes
Last configuration change at 14:46:11 EDT Mon Jul 16 2012
NVRAM config last updated at 14:46:11 EDT Mon Jul 16 2012
configuration mode exclusive auto version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
no service dhcp
hostname WAN1
security passwords min-length 14
logging buffered 51200 debugging
logging rate-limit console 10
logging console critical
clock timezone EST -5
clock summer-time EDT recurring
no ip source-route
no ip gratuitous-arps ip cef
ip nbar pdlm flash:bittorrent.pdlm
ip nbar pdlm flash:citrix.pdlm
ip nbar pdlm flash:edonkey.pdlm
ip nbar pdlm flash:sap-app.pdlm
ip nbar pdlm flash:sap-msg.pdlm
ip nbar pdlm flash:winmx.pdlm
policy-map CONTROL-PLANE-POLICY
class COPP_2
     police 512000 8000 conform-action transmit
  exceed-action transmit class COPP_4
     police 256000 4000 conform-action transmit
  exceed-action drop class COPP_6
     police 128000 2000 conform-action transmit
  exceed-action drop class COPP_7
     police 8000 1000 conform-action drop
  exceed-action drop class class-default
     police 64000 1000 conform-action transmit
  exceed-action drop
no ip bootp server
no ip domain lookup
ip domain name --removed--
ip multicast-routing
ip multicast auto-enable
ip multicast multipath
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
login block-for 65535 attempts 3 within 1800
login quiet-mode access-class LOGIN
login on-failure log
login on-success log
ipv6 unicast-routing
ipv6 host WAN3-624 2002:AC10:1E03::1
ipv6 host PE1 172:17:10::2
ipv6 host PE2 172:17:20::2
ipv6 host PE3 172:17:30::2
ipv6 host WAN1-624 2002:AC10:A03::1
ipv6 cef
password encryption aes
ip tcp selective-ack
ip tcp synwait-time 10
ip ssh time-out 30
ip ssh source-interface Loopback0
ip ssh version 2
track 500 ip route 172.16.1.0 255.255.255.0 reachability
delay down 5 up 45
no crypto isakmp enable
interface Loopback0
description MGT
ip address 172.16.10.2 255.255.255.255
ip pim sparse-mode
ipv6 address xxxx:xxxx:4F:FFFF:FFFF:FFFF:FFFF:F/128
ipv6 ospf 1 area 0
interface Loopback1 description 6to4 ip address 172.16.10.3 255.255.255.255
interface Loopback3 description 6TO4 no ip address ipv6 address xxxx:xxxx:4F:FF80::1/60 ipv6 ospf 1 area 0 !
interface Loopback64 description 6TO4 no ip address ipv6 address xxxx:xxxx:4F:FFE1::1/64 ipv6 ospf network point-to-point ipv6 ospf 1 area 0
interface Loopback90
ip address 172.31.255.254 255.255.255.255
ip pim sparse-mode
interface Loopback99
ip address 172.16.0.98 255.255.255.252
ip pim sparse-mode
ip ospf network point-to-point
interface Tunnel2002
description Dynamic 6to4 Tunnel
no ip address
no ip redirects
ipv6 address 2002:AC10:A03::1/128
ipv6 ospf 1 area 0
tunnel source Loopback1
tunnel mode ipv6ip 6to4
interface FastEthernet0/0
description DO NOT SHUT
no ip address
load-interval 30
interface FastEthernet0/0.5
description BACKUP
encapsulation dot1Q 5
ip address 172.18.250.1 255.255.255.252
ip nbar protocol-discovery
ip pim sparse-mode
ipv6 address 172:18:250::1/126
interface FastEthernet0/0.6
description MGT
encapsulation dot1Q 6 native
interface FastEthernet0/0.10
description To MPLS cloud
encapsulation dot1Q 10
ip address 172.17.10.1 255.255.255.252
ip pim sparse-mode
ipv6 address 172:17:10::1/126
interface FastEthernet0/0.16
description From MPLS cloud
encapsulation dot1Q 16
ip address 172.17.16.1 255.255.255.252
ip pim sparse-mode
ipv6 address 172:17:16::1/126
interface FastEthernet0/0.100
description To CORE1
encapsulation dot1Q 100
ip address 172.16.10.254 255.255.255.252
ip pim sparse-mode
ip ospf priority 0
ipv6 address xxxx:xxxx:4F:FFFF:FFFF:FFFF:FFFF:1/127
ipv6 ospf 1 area 0
router ospf 10
router-id 172.16.10.2
log-adjacency-changes
redistribute connected subnets
redistribute bgp 10 subnets
passive-interface default
no passive-interface FastEthernet0/0.100
network 172.16.0.96 0.0.0.3 area 0
network 172.16.10.2 0.0.0.0 area 0
network 172.16.10.3 0.0.0.0 area 0
network 172.16.10.252 0.0.0.3 area 0
network 172.17.10.0 0.0.0.3 area 0
network 172.31.255.254 0.0.0.0 area 0
router bgp 10
bgp router-id 172.16.10.2
no bgp default ipv4-unicast
bgp log-neighbor-changes
neighbor 172:17:10::2 remote-as 65535
neighbor 172:17:16::2 remote-as 65535
neighbor 172:18:250::2 remote-as 20
neighbor 172:18:250::2 description WAN2 via Backup link
neighbor 172:18:250::2 password --removed--
neighbor 2002:AC10:1E03::1 remote-as 30
neighbor 2002:AC10:1E03::1 description 6to4 Tunnel, WAN3
neighbor 2002:AC10:1E03::1 ebgp-multihop 3
neighbor 2002:AC10:1E03::1 password --removed--
neighbor 172.17.10.2 remote-as 65535
neighbor 172.17.16.2 remote-as 65535
neighbor 172.18.250.2 remote-as 20
neighbor 172.18.250.2 description WAN2 via Backup link
neighbor 172.18.250.2 password --removed--
address-family ipv4
   redistribute ospf 10
   neighbor 172.17.10.2 activate
   neighbor 172.17.10.2 soft-reconfiguration inbound
   neighbor 172.17.10.2 route-map DEFAULT in
   neighbor 172.17.16.2 activate
   neighbor 172.17.16.2 soft-reconfiguration inbound
   neighbor 172.18.250.2 activate
   neighbor 172.18.250.2 soft-reconfiguration inbound
   neighbor 172.18.250.2 route-map BACKUP in
   no auto-summary
   no synchronization
   network 0.0.0.0
   network 172.16.10.0 mask 255.255.255.0
exit-address-family
address-family ipv6
   neighbor 172:17:10::2 activate
   neighbor 172:17:10::2 default-originate
   neighbor 172:17:10::2 soft-reconfiguration inbound
   neighbor 172:17:10::2 prefix-list SITESUM out
   neighbor 172:17:10::2 filter-list 1 in
   neighbor 172:17:16::2 activate
   neighbor 172:17:16::2 default-originate
   neighbor 172:18:250::2 activate
   neighbor 172:18:250::2 default-originate
   neighbor 172:18:250::2 soft-reconfiguration inbound
   neighbor 172:18:250::2 prefix-list SITESUM out
   neighbor 172:18:250::2 route-map WAN2-PREPEND in
   neighbor 172:18:250::2 filter-list 2 in
   neighbor 2002:AC10:1E03::1 activate
   neighbor 2002:AC10:1E03::1 prefix-list 6TO4 out
   aggregate-address xxxx:xxxx:4F:FFC0::/58 as-set summary-only
   redistribute ospf 1 include-connected
   no synchronization exit-address-family
no ip forward-protocol nd
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 172.16.10.253 20 track 500
ip route 172.16.10.0 255.255.255.0 Null0
ip as-path access-list 1 permit ^65535_ ip as-path access-list 2 permit _20$
no ip http server
no ip http secure-server
ip pim bidir-enable
no ip pim dm-fallback
ip pim autorp listener
ip pim send-rp-announce 172.16.0.97 scope 255 group-list MTM bidir
ip pim send-rp-announce Loopback90 scope 255 group-list OTM
ip pim send-rp-discovery FastEthernet0/0.100 scope 255
ip msdp peer 172.16.20.2 connect-source Loopback0
ip msdp default-peer 172.16.20.2 prefix-list OTM-MSDP-PEERS
ip msdp originator-id Loopback0
ip access-list standard ADMIN
permit 192.168.xxx.xxx log
permit 192.168.xxx.xxx log deny  any log
ip access-list standard ANY permit any
ip access-list standard LOGIN
permit 192.168.xxx.xxx deny  any log
ip access-list standard MTM
permit 239.255.0.16 0.0.0.15
ip access-list standard NO-ZERO
deny  0.0.0.0
ip access-list standard OTM
permit 239.255.0.0 0.0.0.15
ip access-list extended CRITICAL
remark _____________________________
permit tcp host 172.17.30.1 host 172.17.30.2 eq bgp
permit tcp host 172.17.30.2 host 172.17.30.1 eq bgp
remark Include MFR packets deny
  ip any any ip access-list extended DEFAULT
permit ip any any
ip access-list extended IMPORTANT
permit udp host 192.168.xxx.xxx 172.16.xxx.xxx 0.0.xxx.xxx eq snmp
permit ip host 192.168.xxx.xxx 192.168.xxx.xxx 0.0.xxx.xxx
permit udp host 192.168.xxx.xxx 192.168.xxx.xxx 0.0.xxx.xxx eq snmp
permit icmp host 192.168.xxx.xxx 192.168.xxx.xxx 0.0.xxx.xxx
permit udp host 192.168.xxx.xxx 192.168.xxx.xxx 0.0.xxx.xxx eq ntp
permit pim any any deny  ip any any ip access-list standard WAN2-NETS
permit 172.16.20.0 0.0.0.255 permit 172.16.2.0 0.0.0.255
remark Use the Backup link "Vlan-5" to reach WAN2, if Backup link down, use MPLS Cloud
ip access-list standard ZERO
permit 0.0.0.0
ip access-list extended NET-WK-MGT
permit tcp 192.168.x.x 0.0.x.x 172.x.x.x 0.x.x.x eq 8008
permit tcp 192.168.x.x 0.0.x.x 172.x.x.x 0.x.x.x range 48000 48020
permit icmp host 192.168.xxx.xxx any echo
permit icmp 192.168.x.x 0.0.x.x any echo-reply
permit udp host 192.168.x.x any eq snmp log
permit udp host 192.168.x.x any eq snmptrap log
permit udp 192.168.x.x 0.0.x.x any eq ntp
permit udp any any eq domain
deny  udp any any eq 5355 log
deny  ip any any log
ip access-list extended NORMAL
permit icmp any any echo
permit icmp any any echo-reply
deny  ip any any
ip access-list extended UNDESIRABLE
permit udp any any eq ntp
permit udp any any eq snmptrap
permit tcp any any eq 22
permit tcp any any eq telnet
permit eigrp any any
permit ospf any any
permit udp any any eq rip
deny  ip any any
ip prefix-list OTM-MSDP-PEERS seq 20
permit 172.16.20.2/32
logging history debugging
logging facility syslog
logging source-interface Loopback0
logging 192.x.x.x
logging 192.x.x.x
access-list 1
permit 172.x.x.x 0.x.x.x
access-list 1
deny  any
log snmp-server engineID local xxxxxxxxxxxxxxxx
snmp-server group --snipped-- v3 priv match exact read --gone-- access --removed--
snmp-server view --omitted-- internet included
snmp-server enable traps tty
ipv6 route 2002:AC10:1E03::1/128 Tunnel2002
ipv6 route xxxx:xxxx:4F:FFC0::/58 Null0
ipv6 router ospf 1
default-information originate always
ipv6 prefix-list 6TO4 seq 20 permit 2002:AC10:A03::1/128
ipv6 prefix-list 6TO4 seq 30 permit xxxx:xxxx:4F:FF80::/60
ipv6 prefix-list SITESUM seq 20
permit xxxx:xxxx:4F:FFC0::/58
route-map BACKUP permit 10
description Perfer WAN2 nets over backup link. "Permit 20" accepts all other nets.
match ip address WAN2-NETS
set local-preference 150
route-map BACKUP permit 15
description Set 0/0 from WAN2 2nd, 1st is from CORE1
match ip address ZERO
set metric 25
set local-preference 50
route-map BACKUP permit 20
description Accept all other nets without changing LP match ip address ANY
route-map WAN2-PREPEND permit 10
match ipv6 address WAN2-PREPEND
set as-path prepend 10 10 10 10
route-map NO-ZERO permit 10
description Don't redistribure 0/0 into OSPF from BGP match ip address NO-ZERO
route-map NO-ZERO permit 20
description Redistribure all other nets from BGP into OSPF!
route-map DEFAULT permit 10
description Set 0/0 from MPLS 3rd, 2nd is WAN2, 1st is from CORE1
set metric 150
set local-preference 10
route-map DEFAULT permit 20
ipv6 access-list WAN2-PREPEND
permit ipv6 xxxx:xxxx:4F:FF40::/58 any
control-plane
service-policy input CONTROL-PLANE-POLICY
line con 0
exec-timeout 0 1
privilege level 15
logging synchronous
login
line aux 0
access-class 1 in
exec-timeout 0 1
no exec
speed 300
line vty 0 4
session-timeout 5
  output access-class 1 in
exec-timeout 5 0
password --missing--
logging synchronous
login transport input ssh
transport output none
line vty 5 15
session-timeout 5
exec-timeout 5 0
password --gone--
logging synchronous
login
transport input ssh
ntp logging
ntp authentication-key --removed-- md5 --deleted--
ntp authenticate
ntp trusted-key --missing--
ntp source FastEthernet0/0.6
ntp server 192.x.x.x
ntp server 172.x.x.x
end
Hello Frank,
I am writing to ensure you I will have a look at the config you have posted here in a few hours Don't worry, I haven't forgotten you.
Best regards,
Peter
Hi Peter,
No need to hurry . . . we are enjoying the successful changes with multicast - it's party time!!!
I understand MSDP and Bi-dir PIM are "ships in the night" type technologies. I have read in several different Cisco docs, the two are incompatible however, in our environment (MPLS Hub and Spoke topology) if MSDP fails due to an incorrect configuration not only does "One-to-Many" PIM sparse-mode, Auto-RP and Anycast-RP fail, it really kills our Many-to-Many, Bidir PIM sparse-mode, Auto-RP, Phantom-RP setup as-well.
In summary, both multicast implementations are now operational.
Both are fully (logically) and partially physically redundant.
Failing the primary RP (either Anycast-RP or Phantom-RP) failover functions perfectly, and mostly without end-users noticing.
If you are ready, I can rate and close this request for help!!!
Thanks again for your help.
Frank
Hello Frank,
So, finally
I wonder why this should be the case. As MSDP should not influence the operation of your Bidir-PIM at all, I do not see how the failure of MSDP should impact your many-to-many multicast application. Probably I am missing something here...
Regarding the configuration:
  • Your BGP configuration uses soft-reconfiguration inbound for several BGP neighbors. In majority of cases, this is not necessary, as all modern BGP implementations support so-called Route Refresh. This "soft-reconfiguration inbound" causes your router to store an unfiltered BGP database, increasing your memory footprint unnecessarily.  I suggest removing it. As a safety precaution, you may issue the show ip bgp neighbor X.X.X.X to find out detailed information about a particular BGP neighbor - look for a line saying "Route refresh: advertised and received". You may find more about the Route Refresh functionality here and here and here
  • Your ACL NO-ZERO and route-map NO-ZERO are not designed properly. The ACL should do permit instead of deny. Subsequently, the action of the route-map NO-ZERO block 10 should be changed to deny instead of permit
  permit 0.0.0.0
route-map NO-ZERO deny 10
Apart from this, I have no further comments on the current configuration - especially when it works
Best regards,
Peter
Mohamed Sobair
Level 7
Level 7
Hello Frank & Peter,
I would like to just add one comment to the previous post.
In AnyCast-RP , you Cant have Two different IP Addresses on the Two RPs for the Same Multicast Groups, Therfore, Frank needs to perform the following:
1- Assign a Unique Loopback Address and configure it on both CE routers, So that Both RPs announce themselves with the same Address. the Intended Multicast Recievers chooses the Shortest path RP to create a Shared Based Tree.
2- Having MSDP peering betweeen both RPs (Through Different Interfaces (Addresses) To Synch both Multicast Sources for the Same Groups.
This Setup would work, However, I dont See a benefit of Having AnyCast-RP Connected on different ASs , Specially if there is Only one Single exit point to the MPLS Cloud as Shown by Frank drawing. This is because if One RP fails, the Entire Local domain fails, since the Local Groups will not be able to Reach the redundant RP.
Mohamed
Hello Mohamed,
Hey old friend, how have you been? Haven't seen you posting for a long time. Thanks for joining!
I agree with what you suggest. In fact, I was - up to this point - trying to understand the environment setup Frank is using. I am not sure how Frank configured the AutoRP and the AnycastRP and I am hoping that the configurations will be posted here - so no comments about the configurations until I see them.
Best regards,
Peter
