Multiflex Trunk config for data T1
jneiberger
Level 2
Level 2
I'm having trouble with a multiflex trunk configuration. This is the first multiflex trunk module I've ever tried to configure and my circuit doesn't seem to be working, yet it doesn't seem to be a problem with my carrier.
Here is my config:
controller T1 0/0/0
framing esf
linecoding b8zs
clock source line
channel-group 0 timeslots 24 speed 64
interface serial 0/0/0
ip address 10.x.y.z 255.255.255.0
Is that the correct config for a plain old full T1 for data? I can't seem to find an example of that in the documentation.
Thanks!
John
jneiberger
Level 2
Level 2
Nevermind, I'm a dork. It should be "timeslots 1-24".
I was accidentally attempting to configure a 64K fractional DS1 on channel 24. heh heh.... That's not quite what I wanted.
John
chrisserafin
Here is my MFT card config with a PRI
It might help...?
network-clock-participate wic 0
ip subnet-zero
isdn switch-type primary-ni
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
interface Serial0/0/0:0
description MCI MPLS Circuit
bandwidth 1536
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
encapsulation frame-relay
ip route-cache flow
frame-relay lmi-type cisco
max-reserved-bandwidth 90
service-policy output xxxxxxxxxxxxx1.0
interface Serial0/0/0:0.1 point-to-point
description MCI MPLS Circuit xxxxxxxxxxxxxxx
bandwidth 1536
ip address 1xx.220.198.134 255.255.255.252
ip pim dense-mode
frame-relay interface-dlci 100 IETF
cisco80211
Chris Serafin
IT Security / Cisco VoIP Engineer
chris@chrisserafin.com
