Multihomed NAT Balancing Problem
Ellad Yatsko
Hello!
I've trouble with NAT. CE has two uplinks. Two ISPs, two /30 networks. I'd like to utilize both connections in the following manner:
interface FastEthernet0/0.101
 description UL:pe.m34:gi0/1.1206
 encapsulation dot1Q 101
 ip address 194.87.6.70 255.255.255.252
 ip nat outside
interface FastEthernet0/0.102
 description UL:pe.m34:gi0/1.1207
 encapsulation dot1Q 102
 ip address 194.87.6.74 255.255.255.252
 ip nat outside
 description DL:users
 ip address 192.168.0.1 255.255.255.0
 ip nat inside
! ip nat inside source list 101 interface FastEthernet0/0.101 overload ip nat inside source list 102 interface FastEthernet0/0.102 overload access-list 101 permit ip 192.168.0.0 0.0.255.255 any access-list 102 permit ip 192.168.0.0 0.0.255.255 any !
! ip route 0.0.0.0 128.0.0.0 194.87.6.69 10 track 1 ip route 128.0.0.0 128.0.0.0 194.87.6.73 10 track 2 ip route 0.0.0.0 128.0.0.0 194.87.6.73 200 ip route 128.0.0.0 128.0.0.0 194.87.6.69 200 !
! ip sla monitor 1 type echo protocol ipIcmpEcho 194.87.6.69 timeout 2000 threshold 10000 frequency 2 ! ip sla monitor schedule 1 life forever start-time now ! track 1 rtr 1 !
! ip sla monitor 2 type echo protocol ipIcmpEcho 194.87.6.73 timeout 2000 threshold 10000 frequency 2 ! ip sla monitor schedule 2 life forever start-time now ! track 2 rtr 2
As supposed - "the first half of Internet" - "on the left",   the rest - "on the right". And also there is redundancy - if one of the links goes down its route is automatically moved on the remaining "live" link. Addresses 0...127.x.x.x are routed to exit through Fa0/0.101 and NATted to 194.87.6.70, addresses 128...223.x.x.x are routed to exit through Fa0/0.102 and NATted to 194.87.6.74. Reverse traffis will come in the same interface as the traffic destined TO Internet passed through - because of SrcIP (194.87.6.70, 194.87.6.74) becomes DstIP and packet routed by provider to the corresponging interface (Fa0/0.101,Fa0/0.102).
The problem is: when both links are alive, the SrcIP on the second (Fa0/0.102) is NATted to 194.87.6.70 instead of expected 194.87.6.74.This leads to the following traffic distribution:
- traffic destined to 0.0.0.0/1 goes "in/out" through Fa0/0.101
- traffic destined to 128.0.0.0/1 goes "out" through Fa0/0.102, but returns back through the Fa0/0.101.
As I invesigated, in both cases NAT translates SrcIP according to the first rule, i. e. this one:
Because conditions are true - SrcIP=192.168.x.x falls under both access-lists 101 and 102. So it picks THE FIRST AVAILABLE RULE for translation.
Is there way to make NAT to translate exactly to the address OF OUTGOING interface (no to the addres OF THE RULE)? Can I bind interface to access-list rule, or tracking object to the NAT rule? Another ways?..
Kind regards,
Ellad
3 Accepted Solutions
try route maps as listed below:
ip nat inside source route-map ISP1 interface FastEthernet0/0.101 overload
ip nat inside source route-map ISP2 interface FastEthernet0/0.102 overload
route-map ISP1 permit 10
match ip address 1
match interface FastEthernet0/0.101
route-map ISP1 permit 20
route-map ISP2 permit 10
match ip address 1
match interface FastEthernet0/0.102
route-map ISP2 permit 20
In addition, I would implement the EEM script below to clear the NAT translations for the tracked inside gobal IP addresses in case the tracked objects change state:
event manager applet CLEAR_NAT_ISP_1
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation inside 194.87.6.70"
event track 1 state up
action 2.0 cli command "clear ip nat translation inside 194.87.6.74"
event manager applet CLEAR_NAT_ISP_2
event track 2 state down
event track 2 state up
12 Replies 12
Ellad Yatsko
I forgot to say about platform:
ce.sudo.gaz.m34#sh ver | i image|memory
System image file is "flash:c2600-advipservicesk9-mz.124-25d.bin"
Cisco 2650XM (MPC860P) processor (revision 1.0) with 118784K/12288K bytes of memory.
ce.sudo.gaz.m34#
You're right Jose! Super! It's working! :-) Thanks a lot!
Deepak Kumar
Can you check CEF for load balancing algorithm?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
You know, I think CEF is not a cause because we have two DIFFERENT routes, not the same ones. So, there is no place for ECMP. The task was to bind NAT Address to Transit Interface.
rais
Level 7
Level 7
How about:
access-list 101 permit ip 192.168.0.0 0.0.127.255 any
access-list 102 permit ip 192.168.128.0 0.0.127.255 any
HTH.
No, it is not good idea, they will be NATted to the same IP. Besides, what will be during a link failure? One half of internal user will be left without an access to Internet. Not a good idea.. :-(
match ip address 1
match ip address 1
Yes! :-) The same as previous, but I'm not sure we need "permit 20"statements.
the permit 20 statements are needed to allow everything else in case of a failure.
Thanks a lot!
