multilink config problem on 2811 router
san_dec21
Hi,all
Thanks in advance.
is their any ios restriction for configuring multilink config on router 2811? i mean can i config multilink on ipbase 2811 router or i have to upgrade the ios version?
Nagendra Kumar Nainar
You can use Feature navigator tool to check the feature availability.
www.cisco.com/go/fn
HTH,
Nagendra
IPbase have a lot of restrictions and will not be able to used for fullest. Also what is the ios verison you want.
I would recommend advance service ios. Depending on your requirements.
Pravin
Hi San,
As far as I know Multilink PPP does not requires any specific feature set. It should work fine with IP Base.
-> Sushil
