encapsulation HDLC/PPP and link errors
Hi ,
Interfaces with encapsulation HDLC and found no CRCs and input errors. But when  we configured with encapsulation PPP then started getting CRCs and input errors.
I am serching for the reason , Appriciate if any one help here .
thanks
.Which  interface  is  causing  errors.
could  you  please  post  entire
  "sh  run"
:sh  interface  sex/y/z
~Jyoti
Jyoti,
Hmm... does Cisco install one of those already on its routers?
Best regards,
Peter
Mohamed Sobair
Level 7
Level 7
CRC and input errors have no relations with the encapsulation method on Serial interfaces. I doubt you have seen it with PPP rather than HDLC.
However, if you still see it, then it would probably be some problem with the Telco, I would say you need to ask your provider for a Loop test if possible on the WAN link.
Mohamed
