multilink PPP to PPPoE
hardik17187shah
Beginner
Beginner
Dear Experts,
My client has  router 2651 connected to internet via multiple ppp link. I am going to replace this router with ASR 1002 (RP1). ASR 1002 dont have any serial port, so I believe I have to replace multilink ppp configuration to PPPoE.  I am having hardtime to find documents for PPPoE configuration on ASR 1002.
Richard Burts
Hall of Fame Community Legend Hall of Fame Community Legend
The title of the question indicates that you are using multilink PPP which is used to combine several point to point serial links into one virtual interface. If the ASR does not have support for serial interfaces then you would need to replace the serial links with some kind of Ethernet. But I wonder why you think that you need to do PPPOE. I would think that a plain Ethernet (Fast or Gig Ethernet) would do what you want.
It was important to have PPP to combine several serial interfaces into one group. But when you switch to Ethernet I wonder why you would still need anything related to PPP?
Rick
Rick
HI Richard,
Thanks for reply. Yes, It was my misunderstanding. Now I come to know they have DS3 on ASR. In old router they have three serial link.
interface Multilinkabc
  bandwidth 4608
ip address 1.2.3.4  255.255.255.252
ip access-group 1 in
ip route-cache flow
ntp disable
ppp multilink
ppp multilink fragment disable
ppp multilink links minimum 1
ppp multilink group abc
interface Serial0/0
  bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no keepalive
no fair-queue
service-module t1 remote-alarm-enable
no cdp enable
ppp multilink
max-reserved-bandwidth 100
interface Serial0/1
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no cdp enable
ppp multilink
interface Serial1/0
  bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no fair-queue
no cdp enable
ppp multilink
So, what command should I use for T3 or DS3 configuration on IOS-XE ?
Recognize Your Peers
