Multilink Vs Serial Conf.
Gangasgar.amula
Dear All,
Whats the precedence between Multilink Configuration and Serial Configuration....
For e.g. If I have removed fair-queue (no fair-queue) from Serial link....but if I have enabled it on Multilink...
Is the link will take fair-queue or not?
Pls suggest...
Sagar.
dgahm
Level 8
Level 8
When configured for multilink the serial interface(s) will always use FIFO queuing. If you configure fair-queue on the serials the IOS will override and show suspended with FIFO.
In essence the virtual multilink interface will handle the queuing, using whichever method you select, and pass packets to the physical interface which will send them in the order received.
dgahm
Level 8
Level 8
