Multiple DHCP pools on Cisco 891F
hochgenub
Hi everyone,
I have a cisco 891F vpn router and would like to have more than one dhcp pool. Possible?
Current dhcp pool is 192.168.1.0/254, gateway 192.168.1.1
I would like to create a new pool with 192.168.30.0/24 with gateway 192.168.30.1
Is this possible and would really appreciate if someone guided me on this with the IOS scripts.
Many thanks in advance
which ports on the router are the clients connected to that are supposed to get a 192.168.1.0/24 address ? Currently, only port GigabitEthernet4 is assigned to Vlan 100, so anything connected to this port will get an IP address in the 192.168.30.0/24 range. Anything connected to any of the other ports should get an IP address in the 192.168.1.0/24 range. Can you post the output of:
sh interfaces brief
Also, make the changes marked in bold to your configuration:
Current configuration : 3186 bytes
! Last configuration change at 15:56:09 GMT Fri Aug 20 2021 by admin1
version 15.3
hostname Pxxxc_Swww-Cisco800
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
clock timezone GMT 8 0
--> ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp excluded-address 192.168.30.1
ip dhcp pool one
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 165.21.83.88 165.21.100.88
--> ip dhcp pool VLAN100
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
ip domain name pxxxxx.com
ip cef
no ipv6 cef
license udi pid C891F-K9 sn Fxxxxxxxxxxxxx
username admin privilege 15 secret 5 $xxxxxxxxxxxxxxxxxxxxxxxxxxxx
username admin1 privilege 15 password 0 xxxxxxxx
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
lifetime 2880
crypto isakmp key sxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx hostname kxxxxxx
crypto isakmp keepalive 30
crypto ipsec transform-set IPSEC esp-aes 256 esp-sha-hmac
mode tunnel
crypto dynamic-map sa1-dynamic 10
set transform-set IPSEC
set pfs group5
crypto map sa1 1 ipsec-isakmp dynamic sa1-dynamic
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip addres
duplex full
speed auto
interface GigabitEthernet0
no ip address
duplex full
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
switchport access vlan 100
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 42.xx.xxxx.xxx 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
interface Vlan100
ip address 192.168.30.1 255.255.255.0
ip nat inside
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 42.xx.xxx.xxx
route-map nonat permit 10
match ip address 101
match interface GigabitEthernet8
access-list 101 deny ip 192.168.30.0 0.0.0.255 172.31.1.0 0.0.0.255
--> access-list 101 permit ip 192.168.1.0 0.0.0.255 any
--> access-list 101 permit ip 192.168.30.1 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
end
31 Replies 31
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_01110.html
                    - Presuming you  can create more then one pool , according to examples.
 M.
Hi M.
Thanks for the reply. I've read that article many times too.
I may be wrong (as currently I'm working-from-home) but I believe my cisco
router only has one fast ethernet 0 port.
Hence can't create VLANs?
Thanks again
Perhaps the output of show version and of show ip interface brief might shed some light on what might be available?
Rick
I have the below sample configuration for the 891 on file, not sure if it matches your router exactly, but I believe you can manually create the Vlan interfaces, and then assign switchports to the Vlans...
Building configuration...
Current configuration : 6951 bytes
! Last configuration change at 09:42:57 PCTime Wed Jul 11 2012 by User
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname yourname
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$MGyU
no aaa new-model
no ip source-route
ip dhcp pool VLAN1
dns-server 8.8.8.8
ip dhcp pool VLAN2
dns-server 8.8.8.8
ip cef
no ip bootp server
no ip domain looku
ip domain name yourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn FGL16082051
username User privilege 15 secret 5 $1$872L$usBjgP2KGGnEv48KleE1h0
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
switchport access vlan 2
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
ip address dhcp
ip nat outside
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingres
duplex auto
speed auto
no ip address
no ip redirects
no ip unreachable
no ip proxy-arp
ip flow ingress
duplex aut
speed auto
interface Vlan1
ip tcp adjust-mss 1452
interface Vlan2
ip nat inside
interface Async1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet8 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet8 dhcp
logging trap debugging
no cdp run
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.30.0 0.0.0.255
control-plane
line con 0
login local
transport output telnet
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Thanks for the share George Pauwen
I think this is quite the result I was looking for!
May I have a step-by-step guide on how to set this up please? I'm not too
familiar with the CLI lines for cisco devices and wouldn't want to disrupt
the devices on the current dhcp pool..
Cheers
good to know that this sample config might be what you are looking for...
The below is how you would set up the DHCP pool for the new Vlan. The easiest would probably be for you to post the output of 'sh run', so we can fill in the bits and pieces that are needed.
Router#conf t
Router(config)#ip dhcp excluded-address 192.168.30.1
Router(config)#ip dhcp pool VLAN2
Router(dhcp-config)#network 192.168.30.0 255.255.255.0
Router(dhcp-config)#default-router 192.168.30.1
Router(dhcp-config)#dns-server 8.8.8.8
Router(dhcp-config)#end
Hi again
Thanks for your quick response.
Below is my "sh run"
Do I need to route the VLAN2 to a separate unmanaged network switch or can
the 2 dhcp pools run on the same network?
Current configuration : 2906 bytes
! Last configuration change at 16:00:12 GMT Mon Aug 9 2021 by admin1
version 15.3
hostname Pxxxxxc_Sxx-Cisco800
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp excluded-address 192.168.1.2 192.168.1.30
ip dhcp pool one
ip domain name pxxxxxxxxxxxx.com
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FXXXXXXXXXXX
username admin privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxx
username admin1 privilege 15 password 0 xxxxxxxxxx
encr aes 256
group 5
lifetime 28800
crypto isakmp key sxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxa hostname kyoten2
mode tunnel
set pfs group5
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex full
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address 42.xx.xx.yyy 255.255.255.252
ip nat outside
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
interface Vlan100
ip address dhcp
interface Async3
no ip address
encapsulation slip
no ip http server
ip route 0.0.0.0 0.0.0.0 42.xx.xx.yyy
access-list 101 deny ip 192.168.1.0 0.0.0.255 172.31.152.0 0.0.0.255
access-list 101 permit ip any any
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
transport input ssh
end
with VLAN2 I assume you mean Vlan 100 (the Vlan interface you have created) ?
Either way, you don't need any additional routing (as long as whatever clients exist in Vlan 100 are directly connected to your router.
In the configuration below, interfaces GigabitEthernet4 and 5 have been assigned to the new Vlan. Here is what the config should look like (important parts marked in bold):
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
--> ip dhcp excluded-address 192.168.30.1
ip dhcp pool one
--> ip dhcp pool two
--> network 192.168.30.1 255.255.255.0
--> default-router 192.168.30.1
--> dns-server 8.8.8.8
ip cef
no ipv6 cef
encr aes 256
group 5
lifetime 28800
mode tunnel
set pfs group5
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex full
no ip address
no ip address
no ip address
--> switchport access vlan 100
no ip address
no ip address
ip nat outside
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
--> interface Vlan100
--> ip address 192.168.30.1 255.255.255.0
--> ip nat inside
--> ip virtual-reassembly in
interface Async3
no ip address
encapsulation slip
no ip http server
--> route-map nonat permit 10
--> match ip address 101
--> match interface GigabitEthernet8
--> access-list 101 deny ip 192.168.1.0 0.0.0.255 172.31.152.0 0.0.0.255
--> access-list 101 deny ip 192.168.30.0 0.0.0.255 172.31.152.0 0.0.0.255
--> access-list 101 permit 192.168.30.0 0.0.0.255 any
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
transport input ssh
end
I input the lines as per your suggestions but now my old 192.168.1.1 dhcp
pool isn't able to connect to the internet.
Seems now the operable gateway is 192.168.30.1
Please help! Thanks, urgent
post the current running configuration (sh run)...
Hi Georg
Below is the latest sh run. Thanks in advance!
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp pool one
ip dhcp pool VLAN2
ip cef
no ipv6 cef
encr aes 256
group 5
lifetime 28800
mode tunnel
set pfs group5
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
duplex full
speed auto
no ip address
duplex full
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat outside
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
transport input ssh
end
Thanks for posting the running config. Based on what I see in the config I would expect that both networks should be able to access the Internet. Am I correct in understanding that devices in 192.168.1.0 can not access the Internet but devices in 192.168.30.0 can access the Internet? If so can you tell me about these questions:
- can a device in the 192.168.1.0 ping the 192.168.1.1 address?
- can a device in the 192.168.1.0 ping the 192.168.30.1 address?
- can a device in the 192.168.1.0 ping a device in the 192.168.30.0?
The only thing that I see in the config that is unique about 192.168.30.0 is in the access list 101 used for address translation. Did this exist before you added the second DHCP pool?
Rick
Hi Richard
Thanks for your reply
> yes, you are correct. Devices on 192.168.1.0 cannot access internet but
they can still see each other in the same pool. Those in 30.0 cannot see
devices on 1.0 but can access internet.
> yes
> no
> no
> no. The access list 101 was added the same time the 30.0 pool was created.
Any fix for this please?
Thanks again!
sh interfaces brief
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp pool one
ip cef
no ipv6 cef
encr aes 256
group 5
lifetime 2880
mode tunnel
set pfs group5
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip addres
duplex full
speed auto
no ip address
duplex full
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat outside
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
interface Vlan100
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
transport input ssh
end
