Multiple DHCP pools on Cisco 891F
hochgenub
Hi everyone,
I have a cisco 891F vpn router and would like to have more than one dhcp pool. Possible?
Current dhcp pool is 192.168.1.0/254, gateway 192.168.1.1
I would like to create a new pool with 192.168.30.0/24 with gateway 192.168.30.1
Is this possible and would really appreciate if someone guided me on this with the IOS scripts.
Many thanks in advance
31 Replies 31
Hi Georg
All devices in the office connect to an unmanaged switch via
GigabyteEthernet 4
Both pools 1.0 and 30.0. Is that alright? Or should we get a separate
switch?
I tried inserting the ip dhcp pool VLAN100 but the range 192.168.30.0 was
already assigned to the earlier VLAN pool? How should I rename or redo the
dhcp pool again?
Thanks very much
it won't work. If all devices are connected to GigabitEthernet4, than all devices will get an IP address from the 192.168.30.0/24 range, since that port is assigned to Vlan 100.
I don't know if the 891F supports subinterfaces, try the config below:
Current configuration : 3186 bytes
! Last configuration change at 15:56:09 GMT Fri Aug 20 2021 by admin1
version 15.3
hostname Pxxxc_Swww-Cisco800
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 $xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa session-id common
clock timezone GMT 8 0
--> ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp excluded-address 192.168.30.1
ip dhcp pool one
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 165.21.83.88 165.21.100.88
--> ip dhcp pool VLAN100
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
ip domain name pxxxxx.com
ip cef
no ipv6 cef
license udi pid C891F-K9 sn Fxxxxxxxxxxxxx
username admin privilege 15 secret 5 $xxxxxxxxxxxxxxxxxxxxxxxxxxxx
username admin1 privilege 15 password 0 xxxxxxxx
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
lifetime 2880
crypto isakmp key sxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx hostname kxxxxxx
crypto isakmp keepalive 30
crypto ipsec transform-set IPSEC esp-aes 256 esp-sha-hmac
mode tunnel
crypto dynamic-map sa1-dynamic 10
set transform-set IPSEC
set pfs group5
crypto map sa1 1 ipsec-isakmp dynamic sa1-dynamic
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip addres
duplex full
speed auto
interface GigabitEthernet0
no ip address
duplex full
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet4.100
encapsulation dot1q 100
ip nat inside
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 42.xx.xxxx.xxx 255.255.255.252
ip nat outside
duplex full
speed 1000
crypto map sa1
--> no interface Vlan1
ip nat inside
--> no interface Vlan100
ip address 192.168.30.1 255.255.255.0
ip nat inside
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 42.xx.xxx.xxx
route-map nonat permit 10
match ip address 101
match interface GigabitEthernet8
access-list 101 deny ip 192.168.30.0 0.0.0.255 172.31.1.0 0.0.0.255
--> access-list 101 permit ip 192.168.1.0 0.0.0.255 any
--> access-list 101 permit ip 192.168.30.1 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
transport input ssh
scheduler allocate 20000 1000
end
Hi Georg
Ok. I can whip out a spare gigabit switch and rig the 30.0 on GigEthernet
5?
Then move those devices that need 30.0 onto that switch. That will be
easier, correct?
How can I rename the Vlan pool to VLAN100? If can't, how do I remove the
whole 30.0 pool and recreate it again with the proper VLAN100 name?
adding a spare switch to GigabitEthernet5 would certainly be easier.
You don't need to rename the DHCP pool, I just thought it looks weird when the pool is named Vlan2, but the actual Vlan it serves is Vlan 100. It will work just fine as is...
Hi Georg
Thanks for your reply
Well I actually followed your example of the previous post and didn't
realise the VLAN2 and VLAN100 myself, although I did find it strange.
But to clear this up could you kindly advise me how to standardize the
VLAN100 dhcp name back to VLAN2. Which lines do I need to input to realign
things back as well as assign the VLAN2 pool to GigabitEthernet 5 please?
it is quite simple actually, you first need to delete the existing pool:
no  ip dhcp pool VLAN100
and then simply readd the new pool, with the new name:
ip dhcp pool VLAN2
Hi Georg
That's all? What about the switchports, access-list and other lines etc?
Mind running through my 'sh run' please.
How about assigning GigEthernet #5 for 30.0 pool? You are sure both dhcp
pools will have internet connectivity?
I would post these when I'm back in office and I've setup the separate
network switch and sorted the respected devices for the required pools.
Really appreciate your help
make sure the config looks like this:
version 15.3
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
ip dhcp pool one
--> ip dhcp pool VLAN2
ip cef
no ipv6 cef
encr aes 256
group 5
lifetime 2880
mode tunnel
set pfs group5
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip addres
duplex full
speed auto
no ip address
duplex full
no ip address
no ip address
no ip address
no ip address
no ip address
switchport access vlan 2
no ip address
no ip address
ip nat outside
duplex full
speed 1000
crypto map sa1
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
line vty 0 4
transport input ssh
end
I agree that a new switch on a separate interface for the new vlan is the easy way to get this to work.
As far as vlan2 or vlan100 is concerned, this is a cosmetic issue. Looking at it from the human perspective it seems better that the vlan name and the name of the dhcp pool should be the same. But looking at it from the perspective of the switch it does not matter whether the name of the pool matches the name of the vlan or not.
Rick
Thanks again everyone! I'm just marking this part of the replies as a workable solution with the cli codes and all. Of course there are later parts to assign vlan to selected GE ports in the later parts of our discussion. But this generally works! Cheers everyone
Hello
You can add multiple dhcp scopes to a single dhcp pool, just need to add the secondary and overide keywords to the addtiional scopes
Example:
ip dhcp pool DHCP
network 192.168.30.0 255.255.255.0 secondary
override default-router 192.168.30.1
network 192.168.31.0 255.255.255.0 secondary
override default-router 192.168.31.1
domain-name mynetwork.net
dns-server 8.8.8.8 8.8.8.4
lease 0 8
Kind Regards
Paul
Thanks Paul
I guess I can try that out as well on Monday
Will these command lines override the excluded IP addresses?
Thanks again
Hello
No they wont, excluded addressing isnt part of the actual pool but they do relate to them, so you be good
Note -  the default-gatway of each scope is excluded by default anyway.
Kind Regards
Paul
I believe you can also do this with inheritance. I was looking for some examples as I think I have done this in the past, but I could not find it right away. To me, something like this seems cleaner.
ip dhcp pool parent
network 192.168.0.0 255.255.0.0
lease 0 8
ip dhcp pool vlan1
network 192.168.0.0 255.255.255.0
default-gateway 192.168.0.1
ip dhcp pool vlan2
default-gateway 192.168.1.1
Hi Elliot
Thanks for the share.
But if I should want the IP pools to be permanent, what would be the
"lease" settings?
So far all the replies are very helpful and can be marked as solutions. Am
just looking for clear vlan ip dhcp pools that I can amend or adjust in the
future too.
Is there a cisco cli script to save the configuration and restart the
router? Thanks!
