Multiple E1
chenoi2007
Hai there...need some guideline.
current setup i have 8 branch and 8 E1 line connecting to HQ (4 router which have 2E1 port each).
iam thinking to replace all the 4 router at HQ with only 1 new router.
my question,
what is the best solution, do i need to have 8E1 port on this new router or is there a way i can minimize the E1 port? can i create subinterface i E1 port?
i dont want to use frame relay as i need 2M dedicated lease line to branch.
please do help me TQ
spremkumar
Level 9
Level 9
You can think about going on for Cisco 2811 or
Cisco 2821 or Cisco 2851 series router with HWIC-4T cards to have your E1 links terminated onto them.
regds
does HWIC card support E1..PPP?
what is the different WIC,HSWIC,VWIC...does all the card support E1...
can i used my fast eth port as my wan port? emm confuse right now..please help me...
As indicated above, use 2 x hwic-4t with external E1 DSU.
Or, 4 x vwic-2mft-e1 without external DSU.
The other card are not applicable to your needs.
