multiple IP addresses on WAN interface
rga-rga-rga
We have Cisco ASA 5505 box.
We have a /29 subnet available.
At this moment one of IP addresses in this rage is assigned to VLAN2 used for outside interface.
My question is how to set up following:
  • all outgoing traffic from VLAN10 (for employees) will go out using one IP, xxx.xxx.xxx.1
  • all outgoing traffic from VLAN20 (for visitors) will go out using second IP, xxx.xxx.xxx.2
  • all outgoing traffic from VLAN10 host yyy.yyy.yyy.yyy (mail server, webmail, ...) will go out using third IP, xxx.xxx.xxx.3
  • all specified incomming traffic to xxx.xxx.xxx.3 will be NATted to internal host yyy.yyy.yyy.yyy in VLAN10
The main purpose is to have specific public IP address for mail server only not to get to any black list,
and to give visitors different outgoing IP address than for our internal users.
You're looking for PBR (Policy-Based Routing).
Not supported on ASA.
I guess you can use the static NAT to manipulate the traffic, for example:
route outside1 0 0 1.1.1.1 10
route outside2 0 0 2.2.2.2 20
All traffic is going to be sent via outside1 because of the lower metric.
However if you add:
static (inside,outside2) tcp 0.0.0.0 smtp 0.0.0.0 smtp
Will cause all SMTP traffic to be sent via the outside2 interface (even when the default gateway points out the outside1 interface).
Federico.
outside1 and outside2 are same interface?
How can I set them up?
I need to let users to use SMTP and have outgoing address x.x.x.1
but to have outgoing address x.x.x.2 for mail server only.
Let's say you have this:
Inside --- ASA --- Outside
Inside = VLAN 1
Outside = VLAN 2
I want to make 10.10.10.0/24 go through the ASA and use IP 1.1.1.1
I want to make 10.10.20.0/24 go through the ASA and use IP 2.2.2.2
I want to make 10.10.30.0/24 go through the ASA and use IP 3.3.3.3
The configuration would be like this:
access-list one permit ip 10.10.10.0 255.255.255.0 any
nat (inside) 1 access-list one
global (outside) 1 1.1.1.1
access-list two permit ip 10.10.20.0 255.255.255.0 any
nat (inside) 2 access-list two
global (outside) 2 2.2.2.2
access-list three permit ip 10.10.30.0 255.255.255.0 any
nat (inside) 3 access-list three
global (outside) 3 3.3.3.3
Even with only a single physical outside interface, the ASA can use different IPs to PAT different traffic based on the source IP.
The same can be done with TCP/UDP ports.
Federico.
