11-10-2011 12:46 PM - edited 03-04-2019 02:14 PM
Our HQ Location dont support high bandwidth pipe served by ISP, so will go ahead with 3 different ISP at 2MB each.
Goal is to provide Email / Application access to Remote office using site to site VPN.
In Total will have 10 to 15 Branch offices each with around 25 to 35 users
Each ISP will give
Existing hardware we got are
Can we use the above hardware to terminate all 3 ISP link and use the Router for site to site VPN.
Our Lan Core is Cisco 3560 which is uplink to 3X2950 user switch
Kindly advice on how should we terminate the link and use each ISP for VPN.
thanks
Joe
11-10-2011 03:09 PM
short answer - yes, you can try.
Actually the 2821 has enough performance for your requirmets (I believ it can route upto 100Mbit with all features).
But I'd suggest instead of c2950 purchase two additional FE modules for your c2821 or a single 8 port switch module. Usually you don't want to see an additional device between your edge router and ISP router.
May I ask why do you get 3 different ISP and just one with 3 times 2 Mbit? Because You will never get a near equel loadsharing between all 3 ISP.
11-11-2011 01:44 AM
i agree with the above post
having three ISPs, differnt IP ..etc will add more complexity tot he design and configurations
it is better if you have one or two of redundancy three will be too complex
hope this help
11-11-2011 09:43 AM
Let me give more details to clear out
We can get only Two ISP with this scenario
Oracle Application accessibility / performance is given more importance hence site-to-site vpn needs Two different ISP.
Please help
thanks
Joe
