Multiple NAT pools
benlemasurier
Hey everyone,
Until today, I've had a single static IP address to the outside world, using NAT for internal machines.
interface GigabitEthernet0/0
description EXTERNAL
ip address 68.65.214.18 255.255.255.248
ip nat outside
interface GigabitEthernet0/1
description INTERNAL
ip address 192.168.0.1 255.255.252.0
ip nat inside
ip nat inside source list 15 interface GigabitEthernet0/0 overload
access-list 15 permit 192.168.0.0 0.0.255.255
ip default-gateway 68.64.214.17
Today we've upgraded our line and obtained an additional subnet from our ISP: 216.242.39.128/27. I'd like you utilize the additional block for dynamic NAT translation. Can anyone point me in the right direction?
Thanks!
Ben
(by the way, this is for a cisco 2821)
15 Replies 15
Hello @CentrepathNCC_2
My questions are;
1) How do I configure two NAT pools one for each ISP?
2) How do you configure the router to use NAT Pool for ISPa when ISPa service is available
3) How do you configure the router to use NAT Pool for ISPb when ISPa Peering fails and I'm no longer receiving a Default Route (and the floating static will be used)
@bowo
Could you show me some config sample for this multiple IP pools and bind using route map ?
I do have similar problem with this single ISP interface with 2 public ip segment that need to be NAT
The below should allow nat failover from the primary ISPa to the Secondary ISPb as/when ipsla reachability via your primary wan interface fails which is polling that external ip address.
Also it should negate IPSLA Tacking from re-restabilising if the same polled external ip then  becomes reachable via ISPa sourced from your primary wan interface.
ISP Nat with dual links, Primary/secondary
ip sla 1
icmp-echo 8.8.8.8 source-interface <ISPa interface>
ip sla schedule 1 life forever start-time now
track 1 rtr 1 reachability
access-list 101 permit icmp host <ISPa interface> host 8.8.8.8 echo
route-map ipsla
match ip address 101
set ip next-hop (next hop of ISPa interface)
set interface null0
ip local policy route-map ipsla
ip route 0.0.0.0 0.0.0.0 <ISPa interface> x.x.x.x 1 name Primary track 1
ip route 0.0.0.0 0.0.0.0 <ISPb interface>y.y.y.y. 200
ip access-list extended 100
permit ip 192.168.0.0 0.0.0.255  any
route-map LAN permit 10
match ip address 100
match interface <ISPa interface>
route-map LAN2 permit 10
match interface <ISPb interface>
ip nat inside source route-map LAN interface <isp1 interface> overload
ip nat inside source route-map LAN2 interface <isp2 interface> overload
ip nat service enable-sym-port (IOS software only)
Kind Regards
Paul
